User Tag List
Results 1 to 15 of 15
Thread: PCW Clutch upgrade
  1. #1
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default PCW Clutch upgrade
    Hello fellas!
    Got a few questions I can't find an answer to by searching these forums.
    As suspected I did the PCW clutch upgrade and replaced the DOT 4 fluid as it was dark. Not too hard of a job as I'm only mechanically inclined with little to no experience. However, once the upgrade was done I discovered the clutch friction zone is now only about 1/2 inch at the end of clutch handle travel when the clutch handle is let out. It hooks up just fine. No slip when applying hard acceleration in higher gears. Is this clutch handle friction zone area correct? I would think the friction zone area should be close to the handle for better/easier control.
    Also, I did line up the friction plate notches but did not consciously set the plates in the basket as described with the plate notches in the slot with 2 dots/marks. Is this mandatory for proper/safe operation?
    Hopefully your input will negate the need for another opening of the clutch compartment.
    Thanks,
    Mark
    Sent from my SM-G920V using Tapatalk
  2. #2
    Join Date
    Jan 2016
    Stephenville
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default Re: PCW Clutch upgrade
    Clutch is not bread properly. Start at the master cylinder. Be sure to place a rag under it. Pump leaver 3 times and hold.
    Loosen the 12mm banjo bolt at the end of the master cylinder. Watch for air and fluid, retighten the bolt, then release the lever. Repeat till no air comes out. Watch the fluid level. Then go to the slave cylinder behind the left rear cylinder a black rubber plug. Attach a clear hose to the bleeder top and use an 8mm wrench to loosen. Pump clutch lever 3 times and hold, loosen bleeder valve and watch for air bubbles in the hose. Repeat 5-6 times or until no air bubbles come out.
    Be sure to close bleeder valve between each cycle. Don’t let the master cylinder go dry, or you can start all over. Be sure not to get brake fluid on painted or plastic surfaces. Good luck.
    Hidden Content
    Bill Donohue
    2001 RSV 44689 miles
  3. Likes DaNetFlunky liked this post
  4. #3
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey Rafterd! Seems I missed anything about bleeding at the banjo connection. I pumped it up and cracked that joint open and it spit like a snake. Air and fluid. Subsequent tries yielded only fluid. Checked the slave bleeder valve which only yielded fluid. Started the engine and tested the friction zone. It seems closer to the handle. It's getting ready to rain here but you can be sure I'll be checking it out asap on the road.
    Thank you sir!
  5. #4
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Now about this: anyone?
  6. #5
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    104 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by DaNetFlunky View Post
    I kind of thought at one time, that perfection in line up shouldn't matter a whole lot,, I was wrong and ended up doing as instructed and solved my then happening issue. I have more issues today but that's another story, and there are no instructions to follow, only deletions.
    It's nice to be the same
    But
    It's great to be different!
  7. #6
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Marcarl, what were the issue that were cleared up?
  8. #7
    Join Date
    Nov 2014
    San Angelo, TX.
    Texas
    TX
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Look at 8:15 in Video 8 for your answer.
    https://www.venturerider.org/forum/s...-Repair-Videos
    If you remove the half-disk and install a full disk (no wire no belleville washe) you will lose clutch lever travel and that is part of the deal. I reinstalled the half disk back into mine.
  9. Thanks DaNetFlunky gave thanks for this post
    Likes DaNetFlunky, Steven G. liked this post
  10. #8
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    270 Post(s)
    Tagged
    0 Thread(s)
    As mentioned, if you replaced the half disc with a full disk, the friction zone will get a lot narrower and be moved out toward the beginning of lever travel. It only takes a couple good days of tooling around in heavy city traffic to teach your fingers the new clutch engagement point, after that you will not even notice it much.
    Jeff Borowski . . Had 88 Venture standard, now 2011 Silverado 4x4
    There are 10 kinds of people that understand binary, those that do, and those that don't.
    Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
    Hidden Content Hidden Content
  11. Thanks DaNetFlunky gave thanks for this post
  12. #9
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ahh! Thanks to du-Rron and Flyinfool I'm in tall cotton! Don't have to open that unit. I'm good with the engagement out at the end as long as that is where it's supposed to be. I got a big hand so.... Notta probleemo! Let's ride!
  13. #10
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, now my ocd checks in and I do have to open that unit and check the assembly like DuRron alluded to when looking at the video he suggested.
    Dang nab it!
  14. #11
    Join Date
    Jan 2016
    Stephenville
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Thank you sir!
    Fantastic!!
    Bill
    Hidden Content
    Bill Donohue
  15. #12
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, the video explained that the clutch should be assembled in a specific way....or....180 degrees out from that specific way. I had assembled the clutch 180 degree out, which worked of course, but I went ahead and put it back to original spec. Didn't change operation at all. The lever engages as mentioned at the beginning of lever travel, the clutch hooks up nice and tight. The cover didn't leak. I'm back in that tall cotton field! Thanks for chiming in. I appreciate it!
  16. #13
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    104 Post(s)
    Tagged
    0 Thread(s)
    I'm glad you is happy,,,, now can I go get my nap now?
    But
  17. Likes DaNetFlunky liked this post
  18. #14
    Join Date
    Jul 2011
    Charleston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, assuming naps are all done now. I have an idea. Like others I do not prefer the clutch handle operation now. I was thinking if the master cylinder plunger or clutch handle itself was modified to move the engagement zone closer to the grip it would be a bit easier to control. Any good ideas on that little piece of modification?
  19. #15
    Join Date
    Nov 2014
    San Angelo, TX.
    Texas
    TX
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    It has been mentioned that you can get used to it. I preferred the old feel so I never could.
    No belleville washer and half disk and wire means you lose that part of your cushioned clutch travel. Your only choice to get it back is to reinstall those parts. Alas, that is what I did. Do not worry, your clutch will not slip if you reinstall those parts as long as all your other disks are ok. Keep the NEW heavier spring though. That is what does the trick to keep the clutch from slipping.
  20. Likes DaNetFlunky liked this post
Similar Threads
  1. dd clutch upgrade
    By hell yea in forum Watering Hole
    Last Post: 02-02-2014, 09:29 AM
  2. Need help on 2nd gen. Clutch upgrade
    By naturbar in forum Watering Hole
    Last Post: 10-14-2013, 03:47 PM
  3. Big Thanks!!! Clutch Upgrade
    By The Black Pearl in forum Watering Hole
    Last Post: 10-12-2011, 09:31 PM
  4. Replies: 25
    Last Post: 08-30-2010, 01:51 PM
  5. So how did your clutch upgrade go?
    By Flyinfool in forum Watering Hole
    Last Post: 05-10-2010, 09:19 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
