guns_usn_20 Posted July 28, 2019 Share #1 Posted July 28, 2019 I am going to order my rear brake pads . My question is, is there any advantage to using the sinitered brake pads? Will they damabe the rotor? Thank you in advance Jim Bell Link to comment Share on other sites More sharing options...
Du-Rron Posted July 28, 2019 Share #2 Posted July 28, 2019 I am going to order my rear brake pads . My question is, is there any advantage to using the sinitered brake pads? Will they damabe the rotor? Thank you in advance Jim Bell I am using the EBC FA123V Semi-Sintered brake pad that I believe stops just as well as the factory brake pad and is more forgiving on the rotors than a full-sintered (factory) brake pad. https://www.revzilla.com/motorcycle/ebc-fa123v-semi-sintered-rear-brake-pads Link to comment Share on other sites More sharing options...
