User Tag List
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Comparison of Gen1, MK1/MK2; My thoughts
  1. #1
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Default Comparison of Gen1, MK1/MK2; My thoughts
    I just picked up an '86 Venture Royale after riding the '83 Venture Standard for 4 years or so. Aside from the cosmetic differences, here is what I see at first blush as far as performance comparison.
    The '83 1200 is snappier with more aggressive acceleration and more agile.
    The '86 1300 is more stable at highway speeds, though the '83 is far from unstable.
    The '86 runs cooler, at least the temp gauge on the '86 stays much further down in the green than the '83. Maybe different temp range on the gauge?
    The acceleration and stability may have as much to do with the fact that the '83 has a short wind screen and the '86 has the factory spec screen. I know the '86 is slightly heavier so that would have some slight effect on both.
    Other than the displacement, are the engines identical? Cams, timing, valves, etc?
    As far as the Royale amenities go;
    I can take or leave a radio on any motorcycle. If it's there I'll use it sometimes. If it's not there, I don't miss it.
    I love an intercom system for road trips. It remains to be seen if I will prefer the wired intercom over the Team Ride bluetooth system that I used to run.(batteries are done and not replaceable in that cheaper system) I need to transfer the head sets from the 33 year old matching helmets to our modular helmets. I hope the mic boom is long enough to work with them.
    I'll likely never use the CB but it is a nice insurance policy for backing up the cell phones in emergency situations.
    The CLASS is a major plus! I love being able to quickly switch from one up soft suspension to two up loaded settings.
    BTW, the '86 either has progressive fork springs installed or the factory springs were better than those in the '83. The front end is much stiffer than the '83, even with little air pressure.
    The larger capacity luggage is a major plus, but not being able to quickly remove the trunk or side bags is a major minus in my book. Not a deal breaker by any stretch but still a bit of a downer on what, in all other areas is a fantastic ride.
    I miss having the stowage area in the main fairing but I'll get used to using the smaller bags mounted on the fairing. They are not waterproof, as it turns out! They may be improved with an application of Camp Dry.
    Well, that's what I see at first. I'll see how different doing tires and other routine maint. is this weekend.
    TANSTAAFL
  2. Thanks cowpuc gave thanks for this post
    Likes cowpuc liked this post
  3. #2
    Join Date
    Mar 2007
    West Coast
    MI
    Post Thanks / Like
    Mentioned
    629 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Comparison of Gen1, MK1/MK2; My thoughts
    I know the carbs are different on em but not so sure on Valve or Ignition Timing or whether any of the top end parts are different. I also know the MK1's will turn 12's in the quarter, top 130 fairly easily and pulls solid from bottom R's to top R's and the need to stay in R's above 3 grand to make the smaller 1200 perform effeciently/effectively when two up and loaded is a myth (it'll lug at the bottom with the best of any Big Twin and slay em at the top), not sure on the MK2's?
    I also got a hunch that come tire swappin time (especially at road side or in a dealership parking lot in the desert heat) you will miss the 20 minute wheel off time of the simplisity of the MK1 but will LOVE the advantage of top opening - much bigger bags. Hey Rich,, maybe devise a quick detach for the bags on the MK2?
    I also got a sneaking hunch you are gonna LOVE the brake updating on the 2 as well as the clutch, the tranny (bye bye 2nd gear ??'s), the water pump, and the frame but maybe not the seat = oh gosh I LOVE the MK1 OEM seat!!
    I am with ya on the hype of all the bling and add on's and am more of a "give me the simplisity of just two wheels and a motor" lop eared touring varmint myself Rich but definitely see why some folks like the stuff and glad they do = anything to keep our sport alive.. Being relocated to strickly local riding these days and a good mix of demo riding therein,, I am anxiously waiting for the chance to play on the new Wing with it's slimmed down MK1 sporty touring bike look to see if Honda is taking a shot at going back to slimmer days = sort of opposite of what you are having fun playing with.
    Good thread brother! Looking forward to hearing what other club members have to say about it all! Also, all the very best in your Venture adVenture!! Keep em rolling my friend
    Remembering my brother and friend:
    "I'm not Yammer Dan" - Yammer Dan
    Proverbs 18:24 - "There is a friend that sticketh closer than a brother"..
    Miss you bro - Puc
    Life is just one step after another..on a rocky hill side-Sly
  4. Thanks luvmy40 gave thanks for this post
    Likes luvmy40 liked this post
  5. #3
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    I didn't mention the brakes in the OP because I did not want to compare them to the delinked brakes on the '83.
    However, if memory serves, the original linked brakes on the '83 were better than what the '86 is showing me now. I'll wait to pass judgement on the '86 until I flush and bleed the current brakes. I have a feeling the brake fluid is as old as the tires, which are 18 and 19 years old. The pads are GTG and the rotors are pristine.
    I will be delinking the brakes this winter. No question. I'll probably upgrade the clutch as well.
    Also forgot to mention that the clutch pull is so light that i thought at first it was not working. It does work perfectly and she shifts through the gears nearly silently with no clunk at all at any speed up or down.
    TANSTAAFL
  6. Likes cowpuc liked this post
  7. #4
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    97 Post(s)
    Tagged
    0 Thread(s)
    From my experience the '83's have more get, and the MKII's have more grunt... Even though they had 100cc's less displacement, they were Yamaha's 'beta' model and were tuned and cam'd more for performance. I know my low serial numbered '83 would haul my butt around into triple digits without even straining... When they came out with the '84's they had backed off on the performance issue a little, redesigned the choke which they dumped in '85, and gave it a bit more grunt. On the mark two's they became more of a pure touring bike instead of a sports tourer.... Hence the 1300cc displacement. More CC's equal more torque... My 2...
  8. Likes cowpuc liked this post
  9. #5
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cowpuc View Post
    My '83 had all the aftermarket chrome including the huge rear skirt and crash bars which adds considerable time to removing the rear wheel, so that will probably be a wash.
    TANSTAAFL
  10. Likes cowpuc liked this post
  11. #6
    Join Date
    Mar 2007
    West Coast
    MI
    Post Thanks / Like
    Mentioned
    629 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by luvmy40 View Post
    There's a pretty quick fix for those future issues ya know
    Click image for larger version.
ID:	117078Click image for larger version.
ID:	117077Click image for larger version.
ID:	117076Click image for larger version.
ID:	117075Click image for larger version.
ID:	117072Click image for larger version.
ID:	117073Click image for larger version.
ID:	117074Click image for larger version.
    Miss you bro - Puc
  12. Likes big-norm, videoarizona liked this post
  13. #7
    Join Date
    Jul 2016
    Black Hills
    SD
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    I've not ridden a MKI but I can confirm that the linked brakes on the MKII were in fact quite crappy. Delinking makes a world of difference.
    The luggage space was the main reason I looked for the MKII and I use every bit of it sometimes. Oddly a MKII will hold a lot of groceries.
  14. #8
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    I forgot to mention the cruise control!
    I'm not sure i like it. It's much more cumbersome to work with than a simple throttle lock. It also feels like it adds resistance to the throttle twist.
    TANSTAAFL
  15. #9
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Bags, I've never even had my bags on, but then again I have never been out of state with it. My concern with my 83 at 42k miles is.. the dreaded upcoming 2nd gear issue.
  16. Thanks cowpuc gave thanks for this post
    Likes cowpuc, big-norm liked this post
  17. #10
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Another difference made itself known this afternoon. I was aware but really hadn't thought about the fuel petcock having a reserve setting.
    On the ride home from work at 70 mph on the freeway, she suddenly lost power and was bogging like she was fuel starved. I looked at the fuel level gauge and it was at half a tank. She never stalled, just wouldn't run over 3500 rpm. My fist thought was the fuel pump had died. Then I remembered the reserve petcock. I pulled over to check the petcock position. Sure enough, it was in the run position. I tried to switch it to reserve and it wouldn't budge. Then I remembered the factory tool kit in the right side bag had a pair of pliers in the case. Switched to reserve, started her up and waited for a break in traffic. When I hit the throttle, I almost cried. she bogged down and barely started to move. Then, all of a sudden I was hanging on for my life as the after burners kicked in!
    Evidently the reserve tank is half the main tank.
    I'll just leave it in the reserve position from now on. BTW, I got 36.7 MPG on this tank.
    TANSTAAFL
  18. #11
    Join Date
    Mar 2017
    Dexter
    KY
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    There's just something about the feel of those burners. Guess that's why I never got over about 33 mpg on my 86. Not to mention short rear tire life.
    Faded Blue is the fastest.
  19. #12
    Join Date
    Mar 2007
    West Coast
    MI
    Post Thanks / Like
    Mentioned
    629 Post(s)
    Tagged
    0 Thread(s)
    ,, might not be a bad idea to pull the seat, remove the fuel sending unit on top of the tank and take a peek at whats laying in the bottom of the tank = be a shame to suck up a bunch of nasty stuff off the bottom of a tank that hasn't been used for a while!!
    Miss you bro - Puc
  20. Likes WRIDR liked this post
  21. #13
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Actually, the 1986 Royale is substantially heavier than a 1983 Standard (the lightest of all the Ventures).
    The advertised dry weight of the 1983 Standard is 670 pounds.
    The advertised dry weight of the 1986 Royale is 732 pounds.
    That is a 62 pound difference! About a 10% increase in weight!
    Kevin M. Campbell Hidden Content
    1974 Honda CB750, 1991 Venture Royale "the Tuxedo"
    Hidden Content
  22. #14
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Prairiehammer View Post
    The odd thing is it's much easier to get the '86 up on the center stand than the '83.
    TANSTAAFL
  23. #15
    Join Date
    Dec 2007
    Victoria
    TX
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    And being one who has stripped the intercom/radio in its entirety, most of the cruise system, and the Class air compressor system from a Royale, that box seems a lot heavier than 62 pounds. I bet the weight of the larger luggage is pretty much insignificant. I can feel the difference between it and my still stock Royale.
    Hidden Content A curve is not the end of the road, unless you fail to turn!
    See my gallery of the RatRod in progress!
Similar Threads
  1. Lowering my Gen1 seat
    By cabreco in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 02-12-2015, 01:55 PM
  2. Gen1 Patches
    By bendtdj in forum Watering Hole
    Last Post: 07-13-2013, 06:14 PM
  3. gen1 o-ring oil pressure
    By sandman in forum Watering Hole
    Last Post: 06-15-2013, 10:53 AM
  4. How many gen1's??
    By islandmech in forum Watering Hole
    Last Post: 04-19-2011, 12:46 AM
  5. Sharing my GPS mount for a Gen1
    By justfun1 in forum GPS, Audio, Electronics
    Last Post: 03-05-2011, 12:17 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
