Red Ryder Posted May 28, 2019 Share #1 Posted May 28, 2019 Hey all, it has been several years since I owned a RSV again, but I cannot get the Cruise Control to Set. I believe I'm doing it correctly. I turn the switch to On, the Set and Res lights display then the On light remains. I press Set, even held it a few seconds, and Does Not set. Even pressed Set, then immediately Resume, but did not Set. Any Idea's? Thanks- Link to comment Share on other sites More sharing options...
RDawson Posted May 28, 2019 Share #2 Posted May 28, 2019 Check clutch and brake switches are closing. Push forward on the levers to make sure they return fully. It only works in 4th and 5th gear. Link to comment Share on other sites More sharing options...
Red Ryder Posted May 28, 2019 Author Share #3 Posted May 28, 2019 Thank You Ronnie, I did have problems with front brake handle not releasing properly, and brake light staying on. Might need better cleaning of brake and clutch since the bike sat for a few years. Appreciate your quick response, Later- Link to comment Share on other sites More sharing options...
Patch Posted May 29, 2019 Share #4 Posted May 29, 2019 not sure about the fourth gear? I used mine in third above 60 klm is the rule I know. Link to comment Share on other sites More sharing options...
RDawson Posted May 29, 2019 Share #5 Posted May 29, 2019 not sure about the fourth gear? I used mine in third above 60 klm is the rule I know. On the VR that works but the RSV is only 4-5th. No idea why they changed that. Link to comment Share on other sites More sharing options...
Patch Posted May 29, 2019 Share #6 Posted May 29, 2019 Hmm! Sucks Link to comment Share on other sites More sharing options...
wrscomncents Posted June 4, 2019 Share #7 Posted June 4, 2019 Hey all, it has been several years since I owned a RSV again, but I cannot get the Cruise Control to Set. I believe I'm doing it correctly. I turn the switch to On, the Set and Res lights display then the On light remains. I press Set, even held it a few seconds, and Does Not set. Even pressed Set, then immediately Resume, but did not Set. Any Idea's? Thanks- I have a similar problem but mine will actually set after a few tries. Here is the post I placed. Scroll down to Du-Rron's reply. I haven't had a chance to do the job yet but I think it will correct my problem when I do. Maybe it will correct yours. https://www.venturerider.org/forum/showthread.php?140936-Cruise-control-speedometer Link to comment Share on other sites More sharing options...
Red Ryder Posted June 5, 2019 Author Share #8 Posted June 5, 2019 Thank You John, I like what Du-Rron posted, will try that. Later- Link to comment Share on other sites More sharing options...
