User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 4 of 4
Thread: Fuel leak help
  1. #1
    Join Date
    Jan 2018
    San Carlos, Sonora
    Mexico
    AZ
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Fuel leak help
    One of the little nipples (41) on the fuel line T (43) is leaking. Anyone have a similar problem and were you able to find a source for the nipples other than Yamaha?
    The numbers refer to the Yamaha parts site, carb section. Picture attached.
    In any event it appears I will have to pull the carbs and split one pair apart to make repairs.
    Living in Mexico is great until you need parts for your ride.
  2. #2
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    104 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Fuel leak help
    What you are showing is a seal, and I would kind of doubt that it would leak, at least that would not be my first thought. I would suspect the T more so, or maybe just a separation between the two.
    It's nice to be the same
    But
    It's great to be different!
  3. #3
    Join Date
    Oct 2017
    edmond
    OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Try partzilla.com
  4. #4
    Join Date
    Feb 2010
    Salisbury
    MA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just fixed mine. it started leaking while I was on vacation.
    I looked all over, and the only place was either the stealership, or the online parts store.
    mine were 10 bucks a piece, and look like they may cost a penny to make..
    and you do have to break apart the carbs to replace it, but, you can loosen the main bolts, but only take off the nuts on the side you are splitting apart, be careful where the 2 carbs join as one for the throttle, there is a spring in there.. not how it goes back in..pull apart far enough to pull out the leaky side of the T replace seal, put back in and wiggle it around...blow in main fuel tube and check for a leak, once carbs are out it takes about and hour to split fix and reassemble..
    good luck...
    Chuck
    You know you've had a good night when you wake up outlined in chalk.
    00 Royal Star Venture
    02 Kawasaki Voyager XII
    02 Honda Shadow A.C.E
    83 Honda V65 Magna
Similar Threads
  1. Fuel leak
    By Grez007 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 04-22-2017, 10:41 AM
  2. Fuel Leak
    By FROG MAN in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 07-15-2012, 12:51 PM
  3. Fuel Leak
    By rumn1 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-10-2010, 10:05 PM
  4. Fuel Leak
    By DCSC in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 06-08-2010, 05:11 PM
  5. Fuel Leak
    By Col Chubbs in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 06-04-2009, 08:27 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
