User Tag List
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Engine noise possibly timing chain slap?
  1. #31
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Engine noise possibly timing chain slap?
    May not help but this video covers the removal of a Gen I engine.
    2007 Yamaha Royal Star Venture 23k miles
    1989 Yamaha Venture Royale 6k miles
    1985 Kawasaki ZN700 4cyl shaft 5k miles
  2. Thanks Phrog gave thanks for this post
  3. #32
    Join Date
    Apr 2019
    Hagerstown
    MD
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Marcarl View Post
    Can't say much for a 2nd gen, but my experience with 1st gens is that coming out is the easy part,,,, got to remember where you held your tongue to get it to go back in. In other words,,, if I'm allowed,,, it slid out but wrestled back in. Does that tell you something?
    Thanks! I was thinking I was going to have a similar experience... but remarkably, going in went much smoother than coming out.... still a PITA, but not as bad as the removal.
  4. #33
    Join Date
    Apr 2019
    Hagerstown
    MD
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Click image for larger version.
    Soooo, Did they change wire connectors on some of the RSV's? There's 4 wire bundles that come out near the drive shaft (pictured). The wires run under the engine somewhere but I haven't tracked where yet. Question is the wire connectors pictured, did they change for different years/models? I tried for about a 1/2 hour to connect these to the connections under the battery box before I figured out that 2 of connectors are not the same as what was on the original engine. Grrrrrrr!!!
  5. #34
    Join Date
    Aug 2006
    Oberlin, OH
    OH
    Post Thanks / Like
    Mentioned
    194 Post(s)
    Tagged
    0 Thread(s)
    As far as I know, they never changed.
  6. Thanks Phrog gave thanks for this post
  7. #35
    Join Date
    Apr 2019
    Hagerstown
    MD
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Freebird View Post
    I didn't think so either, Total of 4 clips, 2 connected without issue, but the other 2 were different. Supposedly both engines from 2005 RSVs.
    Original Engine:Click image for larger version.
    Replacement engine: Click image for larger version.
    I guess I either need to splice in the correct clips, or try to track them back under the engine. I'm really not sure where they go or what they're for.
  8. #36
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    113 Post(s)
    Tagged
    0 Thread(s)
    What is the color on the wires?
    Have you decided to come yet?
    Register soon!!
    716.778.8568
    Rally@the Shores
    July 16-19th 2020
  9. #37
    Join Date
    Apr 2019
    Hagerstown
    MD
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Black... all black. Wait, that's just the dirty greasy grime.
    Black clip has 1 black and 1 white wire
    White clip has 2 that are different shades of green... maybe 1 mint and 1 kinda seafoam green?
    I was hoping to just remove the clips and just swap them, but I think I'm gonna have to cut and splice. Good thing is that both engines have the same color wires coming off, only the clips are different
  10. #38
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    113 Post(s)
    Tagged
    0 Thread(s)
    By my chart for 99-09 Venture.
    The white serves, Speed sensor, Cruise, Master Control, Flasher relay.
    Now for the other wire,, the greenish ones there is a choice of: Black,Brown,Chocolate, Dark Green, Green, Gray, Blue, Light Green, Orange, Pink, Red, Sky Blue, White, Yellow.
    Those are all the solid colors listed.
    Check to make sure that there are no tracer colors on those wires.
    Register soon!!
    716.778.8568
    Rally@the Shores
    July 16-19th 2020
  11. Thanks Phrog gave thanks for this post
Similar Threads
  1. Possible Timing Chain Noise
    By Chaharly in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 09-14-2014, 11:15 PM
  2. Timing chain cover?
    By GOINtoHELL in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 01-08-2011, 10:31 AM
  3. STRETCHED timing chain???????
    By Jrichard in forum Watering Hole
    Last Post: 11-03-2008, 09:10 AM
  4. Timing chain tension
    By a1bummer in forum Watering Hole
    Last Post: 06-24-2008, 07:18 PM
  5. timing chain help
    By funrider in forum Watering Hole
    Last Post: 02-20-2008, 03:57 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
