User Tag List
Results 1 to 4 of 4
Thread: Second Gen. Heavy Duty Clutch Spring & Full Disc Upgrade Kit!
  1. #1
    Join Date
    Apr 2008
    Duncansville
    PA
    Post Thanks / Like
    Mentioned
    40 Post(s)
    Tagged
    1 Thread(s)
    Default Second Gen. Heavy Duty Clutch Spring & Full Disc Upgrade Kit!
    When you roll on the throttle of your Second Gen. RSV or RSTD does the
    clutch slip? When you "briskly" go from first to second gear does your
    clutch slip? Do you ride 2 up often? Are you trying to pull a trailer and is
    your clutch slipping? Are you thinking about paying $300.00 plus the
    install for a Barnett Clutch, well think again! The stock Yamaha clutch is
    a high quality part and will last
    up to 100,000 miles. The problem is not
    your clutch; It's the clutch basket diaphragm spring and that "wimpy"
    half disc that has failed. So here's the fix! Install an aftermarket, thicker
    clutch diaphragm spring, and full clutch disc and never worry about that
    RSV or RSTD or RSTC clutch again! The heavy duty clutch diaphragm spring
    puts 25% more clamping force on the clutch discs than the stock RSV
    clutch spring. Here's my deal, you get a brand new .070 thick heavy duty
    clutch diaphragm spring, (name brand) a new full clutch friction disc to
    replace the half disc, and a brand new, genuine Yamaha replacement
    clutch cover gasket, everything you need to do this install for $
    100.00
    including shipping in the USA!!! I will include complete written
    instructions, and i have a picture file that can be downloaded!
    what a deal!! If you have some miles on your current set of friction discs,
    check my other MEMBER VENDOR Classified Ads for the remaining 7 genuine Yamaha friction
    discs for $
    80.00, Making this upgrade basically, a brand new, better that
    stock clutch! This upgrade can be done in less than 2 hours, doesn't
    require the removal of the clutch basket, can be done with a 10mm
    and 12mm wrench and an allen wrench, and a pair of needle nosed pliers
    and side cutters and you will loose very little engine oil! Shipping in the
    48 states is free, outside the us is at actual cost! I accept paypal and checks!
    Thanks for viewing my ad.
    Earl (skydoc_17)
    Attached Thumbnails Attached Thumbnails CLUTCH UPGRADE KIT 2G.jpg   CLUTCH SPRING THICKNESS.jpg
    Hidden Content
    I WOULD RATHER RIDE MY BIKE TO THE LIMIT, THAN HAVE MY BIKE LIMIT MY RIDING. BUT THAT'S JUST ME.Hidden Content
  2. Thanks Drews gave thanks for this post
    Likes Drews liked this post
  3. #2
    Join Date
    Jul 2018
    Colchester
    CT
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Second Gen. Heavy Duty Clutch Spring & Full Disc Upgrade Kit!
    Hi Earl, are you still offering the clutch upgrade? My clutch slips a little in 5th gear when i hammer it. The whine has gotten worse as well so i hope this might scale it back a little. i have a 2006 RSTD.
    Thanks,
    Dave
  4. #3
    Join Date
    Oct 2019
    Henrico
    VA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Earl, are you still offering the clutch upgrade? Does this help the whine?
    Thanks
  5. #4
    Join Date
    Aug 2019
    San Diego
    CA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Do you still offer this?
Similar Threads
  1. Second Gen. HD Clutch Spring Upgrade Kit
    By dfitzbiz in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 11-07-2014, 01:05 PM
  2. Report on Another Successful Clutch Spring Upgrade
    By V7Goose in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 05-21-2014, 01:41 PM
  3. Replies: 25
    Last Post: 08-30-2010, 01:51 PM
  4. Issue With Second Gen. Clutch Spring Upgrade!
    By skydoc_17 in forum Watering Hole
    Last Post: 04-07-2010, 10:16 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
