User Tag List
Results 1 to 6 of 6
Thread: Will Longer Intake Manifold Bolts in Short Bolt Spots Cause Problems?
  1. #1
    Join Date
    Nov 2015
    USA
    WY
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Will Longer Intake Manifold Bolts in Short Bolt Spots Cause Problems?
    When I removed the intake manifolds on my '93, the two short bolts were on cylinder #1 in the outside spot and cylinder #3 in the outside spot. They've been like that since I bought the bike in 2001. I reinstalled them that way.
    However, I just discovered that the short bolts are supposed to be on cylinder #2 in the outside spot and cylinder #3 in the outside spot. That means I've been running a long bolt in that cylinder #2 spot for 17 years. I've never noticed a problem.
    https://www.venturerider.org/forum/s...arb-boot-bolts
    Click image for larger version.
    What are the consequences of having a long bolt in a short bolt position?
  2. #2
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Will Longer Intake Manifold Bolts in Short Bolt Spots Cause Problems?
    Quote Originally Posted by Bob K. View Post
    The longer bolt will break through into the head nut recess, with the likelihood of an oil leak at the intake port.
Name:	too long bolt damage.jpg
    Go here for an example and the fix:
    http://www.bikersassociationofnorthd...renovation.htm
    Scroll down in his post to the identified problem.
    Kevin M. Campbell Hidden Content
    1974 Honda CB750, 1991 Venture Royale "the Tuxedo"
    Hidden Content
  3. Thanks videoarizona, cowpuc gave thanks for this post
    Likes Bob K., cowpuc liked this post
  4. #3
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    124 Post(s)
    Tagged
    0 Thread(s)
    A very enjoyable read about the VMax build.
    Thank you, Kevin!
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
    "Some mistakes are too much fun to only make once." - Well worn saying
    "Great ideas often receive violent opposition from mediocre minds." Albert Einstein
  5. #4
    Join Date
    Nov 2015
    USA
    WY
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Interesting. The long bolt has been there since I purchased the bike--presumably installed incorrectly by the previous owner or his motorcycle shop--however, I've never noticed any problems or oil leaking into the #2 cylinder. No oil burning, no fouled plug, no buildup in the intake portion above the intake valve, no loss of oil.
    Oil does leak out of the hole when the bolt is removed, but as I understand from other posts, this is normal, and that's why the bolt needs sealant on it during reinstallation. Is that correct?
    I'll swap the bolts and see what happens.
    Is there anything in particular I should keep an eye out for?
  6. #5
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Only thing I can think of is that the torque for the short bolt is about half that of the longer bolt. Don't strip it out!
    Frankly, I'm not sure I would mess with it. The minor damage done by the incorrect long bolt will not be fixed by the substitution of the correct shorter bolt.
    As an aside: the parts diagram is the reason for the (probably) many examples of the long bolt in the wrong location. Notice, even though the part number describes a 16 mm long bolt, the diagram clearly shows the longer (20mm) bolt in that location.
    Hidden Content
  7. Likes Bob K. liked this post
  8. #6
    Join Date
    Nov 2015
    USA
    WY
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Prairiehammer View Post
    I noticed that, too! #7 is supposed to be the short bolt, but in the fiche, it's drawn as longer than the #6 bolt. Dang artists!
Similar Threads
  1. Intake manifold boots
    By wrscomncents in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 04-16-2018, 07:46 PM
  2. intake carb boot bolts
    By rona81564 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 07-06-2013, 10:48 AM
  3. Problem, Intake Manifold
    By GeorgeS in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 05-17-2009, 12:59 AM
  4. Intake Manifold Boots (Question)
    By crockettrider in forum General Tech Talk
    Last Post: 10-10-2008, 11:56 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
