grubsie Posted July 30, 2018 Share #1 Posted July 30, 2018 My front brakes recently developed a rubbing noise. The sound is similar to when you first apply the brakes lightly and you get that noise that sounds like holes in the rotor rubbing against the pads. Like a ZZZZZ as the rotor spins through the pads. It's very slight and doesn't seem to drag on the front wheel and the bike freewheels like normal. If I apply the brakes while cruising along the noise gets louder for a while and slowly goes back to a very slight rubbing noise but never goes completely away. It's almost like the pistons in the calipers aren't backing off enough after braking. I took both calipers off the rotors and the pistons slide in and out with little effort. They weren't dirty but I cleaned them anyway and tried again with the results being the same. So now my thinking is the master cylinder isn't creating enough vacuum to pull the pistons back enough. I also noticed that when I apply the front brake with a strong grip and keep squeezing, I can slowly bring the lever all the way to the throttle handle even though it is resisting very strongly. I tried the same thing on my Road Star and no matter how hard I squeeze, I can only get the lever to go so far. Does this make sense to anyone? Link to comment Share on other sites More sharing options...
camos Posted July 30, 2018 Share #2 Posted July 30, 2018 It's almost like the pistons in the calipers aren't backing off enough after braking.With the cover off the MC do you see the back squirt when releasing the lever? If not then that little hole might be plugged. I also noticed that when I apply the front brake with a strong grip and keep squeezing, I can slowly bring the lever all the way to the throttle handle even though it is resisting very strongly. It might just be a little dirt in the MC or it might need to be rebuilt. Link to comment Share on other sites More sharing options...
steamer Posted July 30, 2018 Share #3 Posted July 30, 2018 Sounds like the master cylinder is leaking by. Rebuild or replaceMy front brakes recently developed a rubbing noise. The sound is similar to when you first apply the brakes lightly and you get that noise that sounds like holes in the rotor rubbing against the pads. Like a ZZZZZ as the rotor spins through the pads. It's very slight and doesn't seem to drag on the front wheel and the bike freewheels like normal. If I apply the brakes while cruising along the noise gets louder for a while and slowly goes back to a very slight rubbing noise but never goes completely away. It's almost like the pistons in the calipers aren't backing off enough after braking. I took both calipers off the rotors and the pistons slide in and out with little effort. They weren't dirty but I cleaned them anyway and tried again with the results being the same. So now my thinking is the master cylinder isn't creating enough vacuum to pull the pistons back enough. I also noticed that when I apply the front brake with a strong grip and keep squeezing, I can slowly bring the lever all the way to the throttle handle even though it is resisting very strongly. I tried the same thing on my Road Star and no matter how hard I squeeze, I can only get the lever to go so far. Does this make sense to anyone? Sent from my SM-J320V using Tapatalk Link to comment Share on other sites More sharing options...
7 lakes Posted July 30, 2018 Share #4 Posted July 30, 2018 Steamer is right, you need to service the internals, a caliper and master rebuild are both indicated here. The only way that you can bottom out the lever like that is if the master is bypassing internally, meaning that it is on borrowed time. Link to comment Share on other sites More sharing options...
Condor Posted July 30, 2018 Share #5 Posted July 30, 2018 Try a new set of pads.... Link to comment Share on other sites More sharing options...
grubsie Posted July 30, 2018 Author Share #6 Posted July 30, 2018 Sounds like the master cylinder is leaking by. Rebuild or replace Sent from my SM-J320V using Tapatalk Going with what you say. Just ordered a MC rebuild kit. I did a test run today that convinced me it's the master cylinder. A little unorthodox but Did it anyways. Pulled one of the left caliper off the rotor and placed a piece of metal that same thickness as the rotor in between the pads. Taped it in place and wired secure the caliper to the front fork and took the bike down the street with only the right caliper working. And the results and noise was still there. Got back to my shop and swapped the setup so that the right caliper was off the rotor and the l3eft was on the rotor and got the same results. Link to comment Share on other sites More sharing options...
Marcarl Posted July 30, 2018 Share #7 Posted July 30, 2018 Just to be informed: when releasing the brake handle the MC does not bring the pads back, all you are doing is releasing the pressure on the pads so that they no longer bind on the rotor. They will continue to contact the rotor to keep the rotor clean and dry. Now the continued compression of the MC is an issue, and has been answered already, and it's good to see that you are taking action in that dept. Link to comment Share on other sites More sharing options...
djh3 Posted July 31, 2018 Share #8 Posted July 31, 2018 When I changed pads on the back of my RSV and went with a different compound it had a zzz kind of sound. Come to think of it the XCT does the same thing. Nothing dragging, systems were bled and all good, just makes the goofy sound sometimes Link to comment Share on other sites More sharing options...
snyper316 Posted July 31, 2018 Share #9 Posted July 31, 2018 When I changed pads on the back of my RSV and went with a different compound it had a zzz kind of sound. Come to think of it the XCT does the same thing. Nothing dragging, systems were bled and all good, just makes the goofy sound sometimes HH pads? Link to comment Share on other sites More sharing options...
VentureFar Posted July 31, 2018 Share #10 Posted July 31, 2018 HH pads? I went with HH pads on the front of my Gen 2 and I feel it stops shorter. VentureFar... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
snyper316 Posted July 31, 2018 Share #11 Posted July 31, 2018 I went with HH pads on the front of my Gen 2 and I feel it stops shorter. VentureFar... Sent from my iPhone using TapatalkMy venture has all HH pads and when I hit the door pedal I know it. I have linked system still too. HH pads seem to make a world of difference. Sent from my LG-M255 using Tapatalk Link to comment Share on other sites More sharing options...
sydem Posted July 31, 2018 Share #12 Posted July 31, 2018 I have the same problem being able to get the handle to the grip. If I pump it seems to hold better. Where are rebuild kits available? Link to comment Share on other sites More sharing options...
Rafterd Posted July 31, 2018 Share #13 Posted July 31, 2018 Just to be informed: when releasing the brake handle the MC does not bring the pads back, all you are doing is releasing the pressure on the pads so that they no longer bind on the rotor. They will continue to contact the rotor to keep the rotor clean and dry. Now the continued compression of the MC is an issue, and has been answered already, and it's good to see that you are taking action in that dept. I wondered who was gonna say that. That is exactly right. What you described, your master cylinder needs rebuilt. Be sure to clean out the little holes in the master cylinder. Had mine all but lock up at 70mph one day, did lock up when I got to 20mph. The relief hole stopped up, put pressure on the calipers, the more they overheated, the harder they gripped. Link to comment Share on other sites More sharing options...
Rafterd Posted July 31, 2018 Share #14 Posted July 31, 2018 I have the same problem being able to get the handle to the grip. If I pump it seems to hold better. Where are rebuild kits available? Bought mine off ebay. Also get the Babbitt’s app. Get anything you want there. Link to comment Share on other sites More sharing options...
grubsie Posted August 22, 2018 Author Share #15 Posted August 22, 2018 Installed the new master cylinder rebuild kit. The good news. I can no longer get the brake handle to touch the handlebar. The bad news, the problem of the brake rub noise was still there. Bought some used calipers off ebay and the noise is gone. Doesn't make sense to me but that's OK as the brakes are back to normal. Link to comment Share on other sites More sharing options...
