User Tag List
Results 1 to 12 of 12
Thread: Mystery Leak Solved
  1. #1
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Default Mystery Leak Solved
    After removing and replacing my clutch cover I couldn't stop it from leaking so I cleaned everything up real nice, put a brand new gasket on and low and behold she's leaking again. I got down with my light and upon inspection found a crack in my clutch cover... Will one off a 1200 fit? and can I replace the inside chrome part so it doesn't say YICS and says 1300 like its supposed to? I dont think I should JB Weld this particular spot, and I dont know about getting it welded either.
    Click image for larger version.
Name:	cracked case 2.jpg
ID:	113005Click image for larger version.
    If you dont like the way im livin', you best leave this long haired country boy alone...
  2. #2
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Mystery Leak Solved
    I don't know about the 12s swap but it can be welded small machine shop or I know of a yard in BC that has some 13s
    Patch
  3. #3
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Steven G. View Post
    Patch
    BC as in British Columbia?
    Is that scrap yard a "U-Pull It" sort of deal or could I contact them and have them send one?
  4. #4
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    They ship.
    1 250 392 2442 Dave
  5. Thanks Chaharly gave thanks for this post
    Likes Chaharly liked this post
  6. #5
    Join Date
    Dec 2014
    Bear Island, NB
    Canada
    NB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    All kinds of 1300 clutch covers on eBay for around $30, and gaskets. Just a matter of finding a cover that's in decent shape. A 1200 cover won't work as they aren't deep enough to accommodate a 1300 clutch basket.
  7. Thanks Chaharly gave thanks for this post
  8. #6
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    67 Post(s)
    Tagged
    0 Thread(s)
    12's won't work on a 13. They are shallower. But... a 13 will fit a 12....
  9. Thanks Chaharly gave thanks for this post
  10. #7
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    18 Post(s)
    Tagged
    0 Thread(s)
    Looks like there is another crack in the engine where the bolt threads in??
    2007 Yamaha Royal Star Venture 23k miles
    1989 Yamaha Venture Royale 6k miles
    1985 Kawasaki ZN700 4cyl shaft 5k miles
  11. #8
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    216 Post(s)
    Tagged
    0 Thread(s)
    Bummer!
    Got any good pics with the cover off? that might be fixable.
    Jeff Borowski . . Had 88 Venture standard, now 2011 Silverado 4x4
    There are 10 kinds of people that understand binary, those that do, and those that don't.
    Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
  12. #9
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BlueSky View Post
    Just a seam. No oil's comin out of it or anything
    Quote Originally Posted by Flyinfool View Post
    Bummer!
    It definitely would be fixable. But I stopped into our local welder and he's gonna want just as much as one of those used ones off ebay so I'll probably just go the ebay route
  13. Likes BlueSky liked this post
  14. #10
    Join Date
    Sep 2006
    Litchfield County
    CT
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Crack in casing....put on side stand, Clean it remove, cover and the inner casing paint...yes your insides are painted. Use acetone, rough up the surface with #40 making the crack obvious. Make sure all it bone dry non-oily. Now your choice... JB Qwik weld or Permatex ultra. I personally like JB Qwik Weld for cracks. Or you can try from the outside
    My 87 Venture, still a corner carving, tire smoking, beast
  15. Likes Chaharly liked this post
  16. #11
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jasonm. View Post
    You don't think it'll be any issue with it being right by a bolt?
  17. #12
    Join Date
    Sep 2006
    Litchfield County
    CT
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Torque on almost all casing bolts is 87in/lbs. reason the crack ,there is you have thinner than normal casting. Do not over torque bolts.
Similar Threads
  1. Oil leak mystery.
    By camos in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 06-11-2014, 08:22 PM
  2. Coolant leak mystery
    By tz89 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 05-02-2014, 09:32 PM
  3. mystery fork leak
    By mike042 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 08-20-2013, 11:12 AM
  4. whining solved
    By junkyardog53 in forum Watering Hole
    Last Post: 10-01-2011, 07:00 PM
  5. clutch mystery solved by Squidley on Tx maint day
    By massey130 in forum Watering Hole
    Last Post: 03-30-2010, 09:19 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
