User Tag List
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: 83 clutch stack
  1. #1
    Join Date
    Mar 2017
    Papillion
    NE
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default 83 clutch stack
    Well I got 3 weeks in about 1800 miles out of the old girl before the clutch decided it was done. I've searched and searched and I can't come up with the parts list I need to replace the stack and Gasket and anything else I might need before I start that job? Do any of you have that information handy?
    Do I need the bent nose ring pliers if I'm not doing a master cylinder to do this job?
    Also I have yet to find a way to bookmark or save post that I want to keep for later referral. Is there somewhere on this site to build my own Library?
    I put the new heavy duty springs in this spring. Now I know it's the stack because cruising on the highway at 60, roll the throttle to full and the tach jumps to about 7.5 and then the speedometer catches up.
    Sent from my SM-T580 using Tapatalk
  2. #2
    Join Date
    Mar 2008
    London E3 3RG
    United Kingdom
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 83 clutch stack
    What are the bits you are after ? Clutch plates ? You should be able to get them anywhere - a quick search for Venture Royale Clutch Plates showed these up, even in the UK: http://www.ebay.co.uk/itm/like/26262...192&rmvSB=true The other choice would be to put a washer under each spring of course, but that depends on how heavy the clutch is already.
    If I can get the gasket in the UK from Ebay, they should have hundreds available in the USA: https://www.ebay.co.uk/itm/Athena-Clutch-Cover-Gasket-fits-Yamaha-XVZ-1200-TD-Venture-Royale-1984-1985/141778896960?epid=1860344540&hash=item2102ae4840:m :mTQju_DPLZkFYK4VIJBs2mw
    Am I missing something ?
    Just because you can doesn't mean you should.
  3. #3
    Join Date
    Dec 2014
    Bear Island, NB
    Canada
    NB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes, lots of options. I installed a Barnett clutch kit in my '84 and am very pleased with it. These can be found on eBay - not cheap mind you (see link following). The gasket you can get from any of the online Yamaha parts sellers - I use PartShark.
    https://www.ebay.ca/itm/Barnett-Clut...-/302350155121
  4. Thanks s.tyler58 gave thanks for this post
    Likes s.tyler58 liked this post
  5. #4
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Talk to skydoc_17
    TAANSTAAFL
  6. Likes SpencerPJ liked this post
  7. #5
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    First off, I have seen posts over the years that Skydoc17 sells the perfect set-up. I agree with luvmy40.
    I like this link to get part numbers, then scour the interweb for deals
    https://www.yamahasportsplaza.com/oe...-xvz12tk-parts
  8. Thanks s.tyler58 gave thanks for this post
  9. #6
    Join Date
    Aug 2006
    Windsor WI
    WI
    Post Thanks / Like
    Mentioned
    18 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by s.tyler58 View Post
    You have certainly been through struggles with that bike! If you are going to have to open up the clutch anyway, perhaps you should open it up and see what it looks like before order new clutch parts. Might be that something else in the actuating department is preventing the clutch from fully engaging and new clutch parts are not necessary. Just a thought.
    zag
  10. Thanks s.tyler58 gave thanks for this post
    Likes SpencerPJ, s.tyler58 liked this post
  11. #7
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    I'm not entirely sure that the MK1 clutches and the MK2 clutches are the same. I think they changed them to the single diaphram spring set up in 86 and used that through the production of Royal Stars as well. I agree with everyone else, I'm running the skydoc kit on my 88 and theres absolutely no slip! Just be sure it will work with yours.
    If it wont, I do believe the barnett conversion will!
    Good luck!
    If you dont like the way im livin', you best leave this long haired country boy alone...
  12. #8
    Join Date
    Aug 2006
    Arcade, NY
    NY
    Post Thanks / Like
    Mentioned
    58 Post(s)
    Tagged
    0 Thread(s)
    Chaharley is correct, the MK1 and MK2 clutches are different...
  13. #9
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Do you mean it slips like a beast? or theres no pull when you pull the clutch lever?? Is it froze up?
  14. #10
    Join Date
    Mar 2017
    Papillion
    NE
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by zagger View Post
    You have certainly been through struggles with that bike! dag
    I've also developed a puddle below my left front Fork. Last time it was the anti dive this time looks like it's the top seal. I haven't tried to clean anything yet to see what the jack is going on there but will be addressing it while it's up on the jack.
    Sent from my SM-G935V using Tapatalk
  15. #11
    Join Date
    Mar 2017
    Papillion
    NE
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Chaharly View Post
    The pull is fine. It slips like a beast. I can hold highway speeds just fine. I have developed a new habit of driving around 60 miles an hour at around 36 3700 RPM instead of 32 hundred. But in 5th gear 65 miles an hour and then go full throttle. Tach jumps up, speedometer slowly starts to catch up to where the tach is.
  16. #12
    Join Date
    Mar 2017
    Papillion
    NE
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    And I need to get my shifter linkage length dialed-in. Right now I believe the adjustment screw is as short as it can go and so there's a lot of slop and it's hard to get into first year by shifting down with my heel. Remember that I have a reverse shift pattern.
    I've also developed a puddle below my left front Fork. Last time it was the anti dive this time looks like it's the top seal. I haven't tried to clean anything yet to see what the heck is going on there but will be addressing it while it's up on the jack.
    So that means I'll be pulling that left side cover off where the slave is again so I can get to that adjustment. I had a drip from there over the kickstand for about a week and then once I got to ride and got going I wiped it clean and I haven't had a drip so that's weird but I'll see what it was while I have the cover off
    I did get almost 2,000 miles in 3 weeks while she was running. Now I know why she's worth all the work. ( she'll never be worth all the money though)
  17. #13
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I clean mine it seems yearly. I use an old 35mm film negative, slides in easily, and cleans out the funkies, usually bug splat. I have never replaced either side, and both sides have leaked.
  18. Thanks s.tyler58 gave thanks for this post
  19. #14
    Join Date
    Jan 2018
    Snohomish County
    WA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SpencerPJ View Post
    Me too. I've found that most of the time leaks are crap between the seal and the tube, there isn't really a surface or enough action on those seals to wear them much, they lead a pretty easy life. If they're old and stiff that's one thing, but if they're still pliable then cleaning almost always does the trick for me. Gaiters are nice, they keep stuff off the tubes and eliminate cleaning, if you like the look.
  20. Likes SpencerPJ liked this post
  21. #15
    Join Date
    Mar 2017
    Papillion
    NE
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 7 lakes View Post
    They were just redone 3 years ago less less than 3,000 miles
Similar Threads
  1. Clutch replacement. Question about torquing up clutch spring plate
    By Midnight in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 10-21-2014, 11:13 AM
  2. clutch clutch clutch missing disk?
    By MikeWa in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 05-02-2012, 08:10 PM
  3. Clutch, Clutch basket, Clutch bearing?
    By puppy in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 09-02-2010, 09:12 PM
  4. Replies: 25
    Last Post: 08-30-2010, 01:51 PM
  5. Clutch Stack Up order
    By Seaking in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 08-16-2010, 09:48 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
