BratmanXj Posted May 31, 2018 Share #1 Posted May 31, 2018 Buddy tried to add a bluetooth amp to his '96 Wing Aspencade and now his audio is going haywire. Speakers are cutting in and out. From what I can tell the Wings don't have front to rear fader abilities, speakers are only split left to right? Does anyone have access to a wiring diagram for a '96 Goldwing? Link to comment Share on other sites More sharing options...
okscott Posted June 11, 2018 Share #2 Posted June 11, 2018 Had a similar problem on my Goldwing. Sprayed all the connections under the plastic cover on the tank with electrical contact cleaner and fixed my issue. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Eck Posted June 11, 2018 Share #3 Posted June 11, 2018 Suggest you contact Steve Sanders Goldwing forums.. Steve knows the earlier Goldwings inside and out... Link to comment Share on other sites More sharing options...
BratmanXj Posted June 11, 2018 Author Share #4 Posted June 11, 2018 We figured it out, sorta. Based on some of the crimps and connectors someone has been into the wiring before. We ended up pulling new lines to each of the speakers and removing the bodged wiring. Link to comment Share on other sites More sharing options...
