RSV stalls out while riding
Bike starts and runs great. Problem is after 20 min of riding the bike will just stop running. I've spent 5 min on the side of the road trying to start it and all that happens is the starter turns over. No bag no rumble. Nothing but starter. Up until today I've been able to get it going after it sits for about 20 min. Spark plugs are new. And system is charging. Not sure where to go next.
Sent from my SM-G920W8 using Tapatalk
First I would make sure the tank vent is clear and not causing the tank to vapor lock, when it stalls and you safely pull to the side of the road remove gas cap and listen for the sound of air being sucked into the tank.
Second I would check to see if I hear the fuel pump clicking to fill up the carbs while the engine is cranking, it sounds like the fuel pump bit is on its way out. That is a common problem with some RSVs, You can just replace the points or replace the whole pump.
Good luck, Craig
  • 3 weeks later...
