User Tag List
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Thread: Engine noise
  1. #1
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Engine noise
    Was wondering as I am coming from a wing does anyone notice lifters sound a little loud when accelerating when bike is warm. This my first air cooled bike runs great was out in 32 Celsius for a 400 km ride .So curious is this normal.It does not affect performance and when cruising at 70 MPH
    It is quiet and smooth also not noticeable when idling only on accelerating
  2. #2
    Join Date
    May 2018
    Cape Coral
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Engine noise
    Quote Originally Posted by ZOEYDOG View Post
    Yes you will here the top end of the engine on most V-Twins. Nothing to worry about.
  3. #3
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by American View Post
    Thankyou sorry about the 2 posts can't figure out how to delete one
  4. #4
    Join Date
    Mar 2007
    HERE AND THERE
    MI
    Post Thanks / Like
    Mentioned
    652 Post(s)
    Tagged
    0 Thread(s)
    Zoey, IMHO - under a load/during accellaration is usually where spark knock will peak its ugly head if its gonna happen. No idea what your using for fuel and/or what spec is for fuel grade on the new one but for an experiment you may want to try some higher octane fuel just to see if it helps.
    TIP AND PUC'S MILLION MILE VENTURE adVENTURE FOR OUR adVENTURES AND REPAIR ADVICE SEARCH YOUTUBE: PUC PUC AND TWEEKS
  5. #5
    Join Date
    Jul 2016
    Black Hills
    SD
    Post Thanks / Like
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    The 3rd gen is still new to us, but generally speaking Puc is correct as usual! It is indeed normal for air cooled mills to have a little more audible mechanical sound. The water jacket enjoyed by liquid cooled engines also makes for great sound deadening. Like that buttery smooth, eeriely quiet wing you just came off of. If your hearing pinging, or pre-ignition/detonation (not exactly the same thing but oft used interchangeably) then that could be ****ty fuel/wrong grade, faulty timing or excessive heat in the combustion chamber, which is not unheard of with traditional air cooled engines. I would not suspect a mechanical fault on a brand new bike but if what your hearing is a pinging, esp when hot, I would probably take it in to be assessed since its a brand new machine, but if what your hearing is a faint lifter/valve train noise then that could be the normal sound of an air cooled twin, or air cooled almost anything. If the dealer has another Venture or Eluder maybe they will allow you to tale a spin to get her good and hot amd see if it sounds similar. Good luck and congrats on the new scoot!
  6. #6
    Join Date
    May 2018
    Cape Coral
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    He is likely not hearing spark knock but rather the upper valve train is what he is hearing, Yamaha to my understanding even designed the valve covers to provide some sound deadening to help quite down top end of the engine.
    Spark knock is easy to identify, it will be like a pinging sound like if you go to your silverware drawer in your kitchen and grab a hand full of silverware and dropped it back down into the drawer by sliding out of your hand the metallic sound it makes is very close to what engine ping sounds like.
    I can hear the upper valve train on my Star Venture and it is not engine ping. If you want to try and deaden the sound some more a full synthetic oil like Redline might help a little bit but you are likely always going to hear some sound from the upper valve train on this engine. I rather like it myself, the mechanical sound it emits is like music to me. Those eight valves all playing a symphony of mechanical engineering. Between that and the low rumble of he stock exhaust this bike makes perfect engine music.
    As to the fuel just put in premium, the cost difference to fill up the 6.6 gallon tank is at most two dollars if you ran the tank completely dry
  7. Likes Chaharly liked this post
  8. #7
    Join Date
    Apr 2018
    Rockwell
    NC
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Mind if I “chime in” here? First, the bike was DESIGNED to run in PREMIUM ONLY. Any lesser grade WILL give you issues. Second, while I know there are some superior lubricants out there, the Yamaha WARRANTEE states that “ONLY Genuine Yamaha Products MUST be used.” If you want to go synthetic (as I do) you’ll have to use Yamaha’s Synthetic. Failure to use ORIGINAL YAMAHA SPECIFIED products is cause for loss of Warrantee coverage!!
    JJust RE-READ the Warrantee. After it specified “YAMAHA ORIGINAL PARTS”, it said “LIKE & KIND”. I must’ve missed that. So, that being said; as long as it meets or exceeds Yamaha’s specifications we’re GOOD TO GO! Of course that means the next oil change I AM SWITCHING to MOBIL 1 SYNTHETIC!
    THANK YOU Freebird for causing me to revisit what I thought I’d read.
  9. Likes GreenMtnHunter liked this post
  10. #8
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ChiefGunner View Post
    Youll HAVE to wait 5 years before you can try something else.
    READ the warranty requirements!
    I've never heard of a warranty depending on buying the manufacturers brand oil. Must have something to do with how hot the oil gets.
    2007 Yamaha Royal Star Venture
    1989 Yamaha Venture Royale
    1985 Kawasaki ZN700 4cyl shaft
  11. #9
    Join Date
    Aug 2006
    Oberlin, OH
    OH
    Post Thanks / Like
    Mentioned
    202 Post(s)
    Tagged
    0 Thread(s)
    Yamaha can say what they want but it would never hold up in court. This has been beaten many times. As long your chosen oil meets the specs required, they cannot deny warranty based on you using a different brand. I use Mobil 1 synthetic in everything I own and will continue to do so. There are consumer laws that make that very clear and Yamaha and other manufacturers very well know it and would never choose to fight that battle.
  12. Thanks cowpuc, Drews gave thanks for this post
    Likes cowpuc, 7 lakes, Drews liked this post
  13. #10
    Join Date
    Apr 2018
    Rockwell
    NC
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Freebird View Post
    Im just quoting them. It’s not my view.
  14. #11
    Join Date
    Mar 2007
    HERE AND THERE
    MI
    Post Thanks / Like
    Mentioned
    652 Post(s)
    Tagged
    0 Thread(s)
    I only mentioned spark knock as a possibilty cause normal valve train noise is usually not load dependent in my little bit of experience.
    I am no Strat motor expert but I do seem to recall hearing about valve noises being produced by them do to automatic decompressors on the exhaust lobes of the cams.. I know for a fact (techs at Sturgis told me so) that the SVTC shares valve/top end parts with the other 113's and I wonder if the design for decompressing the engine for start up was carried over and if that is what is being heard..
  15. #12
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Thanks everyone for their info. It is definitely not pinging That sound I know makes sense it could be valve train noise.I only use premium but may switch stations also does not decrease performance. Had first service done at 1300 KMS and they used Yamalube and a Yamaha filter. Loving this new bike out handles my 2001 wing one or two up. On the highway in the wind not near as much blowing around it is so far best machine I have owned.
  16. Thanks cowpuc gave thanks for this post
    Likes cowpuc liked this post
  17. #13
    Join Date
    May 2018
    Cape Coral
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Actually Yamaha could win a court case against you on this, the kicker is Yamaha is required to provide the oil for free for the duration of the warranty period per the Magnuson-Moss warranty act.
    A manufacture may control what part you are allowed to use but in exchange for that while the vehicle is under warranty the manufacture has to provide said part(s) free of charge to the customer because they are denying the customer choice of aftermarket parts.
    I bet no one is getting free oil from Yamaha during the warranty period.
  18. Likes Yoopermoose, Drews, Chaharly liked this post
  19. #14
    Join Date
    Mar 2018
    Centennial
    CO
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    While I know there are some superior lubricants out there, the Yamaha WARRANTEE states that “ONLY Genuine Yamaha Products MUST be used.”
    Can you post a pic of this from the warranty? I'm ashamed to say I can't find my copy.
    That said, in the specifications in the owner's manual (page 11-1), it states "Recommended brand: YAMALUBE". It does not say "Required".
    Also, in the YES warranty (various forms found here: https://www.yamaha-motor-yes.com/tsncs.jsp), it says (in the 48-state version), "Follow Yamaha guidelines for the quality and type of fuel, oil, and lubricants used. Failure to follow guidelines in the appropriate owner’s manual may result in denial of certain claims." Quality and type; brand is not specified, nor is there at that point a recommendation for YAMALUBE.
    The only gap I have in my documentation is the text of the base 1-year warranty. I'd be very curious to see the wording therein.
  20. #15
    Join Date
    Jul 2016
    Black Hills
    SD
    Post Thanks / Like
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    Sounds like your golden then. Its a completely different engine than the 1800 6 pot and this is just one of those differences that fall under normal operation. You may notice I said valve sounds rather than noise. I have owned plenty of air cooled cars and bikes and the sound of a properly adjusted valve train does not offend me, I find it almost musical. On this bike and oils, I think i would only use oils that meet mfr requirements, regardless of oil brand, at least until there are more of these on the road and more is known about the durability of this new line of engines. Giving a mfr any grounds for denial of warranty may not be a great move IMHO, at least not just yet. For a mfr to legally deny a warranty claim they must prove that what you did contributed to the failure. If you have an engine failire while using oil outside mfr specs you may very well be sole owner of the hot oily pieces scattered all over the blacktop. Brand of oil is not the issue, but correct spec is. Just like if you ise "incorrect" oil and then experience an electronic failure there is precious little chance a judge would allow a mfr to void your claim. It may vary from state to state but this is what I have seen. As the miles pile on and if certain failures become known they may have a hard time denying a claim anyway. I would wait a bit before playing with oil specs, just my .02.
Similar Threads
  1. Engine noise
    By ZOEYDOG in forum Star Venture and Eluder Tech Talk ( '18 - Present)
    Last Post: 05-07-2018, 10:40 PM
  2. engine noise through headset
    By dragonwood in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 08-18-2012, 12:33 AM
  3. Engine Noise
    By Eagle77 in forum General Tech Talk
    Last Post: 11-02-2009, 03:53 PM
  4. New info on engine noise
    By 1 - UP in forum Watering Hole
    Last Post: 01-26-2009, 05:53 AM
  5. Engine noise
    By hydraulicman in forum General Tech Talk
    Last Post: 09-05-2007, 12:36 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
