Stephenj Posted January 18, 2018 Share #1 Posted January 18, 2018 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F250839625790 Bought this 5 pin headset to Communicate to my passenger which also has won the trouble I’m having a plugged it in and when I pull the TX button does not click onJust wondering if I am doing something wrong this should not be very complicated any help would be appreciated thanks Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RDawson Posted January 18, 2018 Share #2 Posted January 18, 2018 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F250839625790 Bought this 5 pin headset to Communicate to my passenger which also has won the trouble I’m having a plugged it in and when I pull the TX button does not click onJust wondering if I am doing something wrong this should not be very complicated any help would be appreciated thanks Sent from my iPhone using Tapatalk Have you Checked the volume control? The button is only used for the CB unless you have mic mutes installed. The intercom is on all the time. Link to comment Share on other sites More sharing options...
Stephenj Posted January 18, 2018 Author Share #3 Posted January 18, 2018 Have you Checked the volume control? The button is only used for the CB unless you have mic mutes installed. The intercom is on all the time. Not real sure about Mic mutes I was under the impression plug and play Supposed to be made for this bike I have a front headset and rear headset and yes if you unplug the headset system and turn the CB on you can see the TX on radio control also this is all 2007 Royal Star venture Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RDawson Posted January 18, 2018 Share #4 Posted January 18, 2018 With key in run position push the select button unti IC shows on the display. Using the up arrow button set the intercom volume to 20. You should then be able to just speak in the mic to test the headsets. If this doesn't work there are write ups in the tech library to troubleshoot the system. I've not had to go there yet personally. Others here can chime in on that. Link to comment Share on other sites More sharing options...
RDawson Posted January 19, 2018 Share #5 Posted January 19, 2018 Let us know how it goes. Someone here will point you in the right direction. Link to comment Share on other sites More sharing options...
Stephenj Posted January 19, 2018 Author Share #6 Posted January 19, 2018 With key in run position push the select button unti IC shows on the display. Using the up arrow button set the intercom volume to 20. You should then be able to just speak in the mic to test the headsets. If this doesn't work there are write ups in the tech library to troubleshoot the system. I've not had to go there yet personally. Others here can chime in on that. I will try that will keep you posted Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Stephenj Posted January 19, 2018 Author Share #7 Posted January 19, 2018 Let us know how it goes. Someone here will point you in the right direction. Thank you I really appreciate it Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Stephenj Posted January 20, 2018 Author Share #8 Posted January 20, 2018 Thank you I really appreciate it Sent from my iPhone using Tapatalk You’re the man ,done exactly what you said and worked perfectly Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RDawson Posted January 21, 2018 Share #9 Posted January 21, 2018 You’re the man ,done exactly what you said and worked perfectly Sent from my iPhone using Tapatalk Glad it's working. I had the same issue on my 07. Link to comment Share on other sites More sharing options...
videoarizona Posted January 26, 2018 Share #10 Posted January 26, 2018 If you don't have a manual, suggest you search this site for the link and download the user manual. The audio set up is a bit complicated at first, but after use it becomes quite easy.... Lots of good stuff you can do... Link to comment Share on other sites More sharing options...
RDawson Posted January 26, 2018 Share #11 Posted January 26, 2018 Experiment with volume settings to cut wind noise through the mics. I've tried the balloon trick that didn't really work for me, has helped some people. I'm getting ready to order the mic mutes for that and an Amplirider to adjust phone volume. The tech library has write ups I used to link a GPS, phone, and a Bluetooth receiver to the factory setup so I can use the phone, stream music, and get directions through the headsets along with the intercom. I'll probably use the mic mutes to turn off the back seat directions too. Link to comment Share on other sites More sharing options...
BruceyE Posted September 21, 2020 Share #12 Posted September 21, 2020 Sometimes mine works and sometimes it doesn't I'm thinking that maybe there's a bit moisture in it. Link to comment Share on other sites More sharing options...
