User Tag List
Results 1 to 11 of 11
Thread: empty weight for sidecar
  1. #1
    Join Date
    Aug 2006
    Malvern, AR
    AR
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default empty weight for sidecar
    I have a 2000 Yamaha Ventura with a Motorvation Formula II sidecar. Seats two and has a wide stance. I have to use it sometimes without the better half. Any suggestions for amount of weight I should consider when empty?
    Thanks,
    labill
  2. Likes stickhandle2 liked this post
  3. #2
    Join Date
    May 2013
    Welland
    Canada
    ON
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Default Re: empty weight for sidecar
    We have just gotten a Ural in the past few weeks, when it is just me on the bike and the side car is empty, I usually put about 75# in it as ballast. I have ridden with only 25# in it but I feel more secure with the 75.
    Mike
  4. #3
    Join Date
    Aug 2006
    Winneconne
    WI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I no longer keep ballast in the car - just take it extra easy on the right hand turns. Most places recommend 50-100# ballast to start, reducing it as you feel comfortable. That's a wide car, so it should have less tendency to fly.
    I also have a 2000 Venture and was considering adding a sidecar to it. I looked at your profile pic - looks like it seats 2 dogs!
    Did you buy the bike w/ car, add the car yourself or have it done? How do you like the Motorvation II ?
    BTW - if you have wife on the pillion seat and the dogs in the car - you should be adding ballast anyway. Unless your wife is really tiny & weighs less than the combined wt. of the 2 dogs - you should add ballast so the wt. in the tub is greater than the wt. of your wife. The car should always carry the heavier passenger and since you can't put 1 dog on the pillion - you need to add ballast to balance the rig.
  5. Likes stickhandle2 liked this post
  6. #4
    Join Date
    May 2013
    Welland
    Canada
    ON
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Red1 View Post
    Great point by Red on the extra weight if you have a passenger on the bike, I second that. With our rig I am down to just 25# and that will be removed soon. Always careful on the turns.
    Mike
  7. #5
    Join Date
    Aug 2006
    Malvern, AR
    AR
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the suggestions with the dogs. They ride locally only but still weigh more than wife.
    Bought the sidecar a few years back because the wife could not handle long trips on back. Put a V max rear in and boy did that make a difference with power.
    Still miss the twisties.
  8. #6
    Join Date
    Aug 2006
    Malvern, AR
    AR
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bought the bike in 2002. Added the car a few years back. Bought it from Motorvation in Sibley, IA. Great car.
  9. Likes Red1 liked this post
  10. #7
    Join Date
    Aug 2006
    Winneconne
    WI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by labill View Post
    Yeah, there's no more scraping the floorboards with a hack. I originally considered adding a car to my Venture. Interesting idea on the V-max rear end - good to know. Did you have to do any other suspension or front end changes for the car?
  11. #8
    Join Date
    Aug 2006
    Malvern, AR
    AR
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry for the delay.
    Did not change front end. Its muscle and I learned to use the sidecars own brake for right turns and sharp curves and the weight of the car itself for left curves. The only front addition was the need for a shock stabilizer to stop low-end wobble which is bad.
  12. Thanks Red1 gave thanks for this post
  13. #9
    Join Date
    Jul 2011
    Valencia
    PA
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    www.sidecar.com
    Very helpful site that is just about sidecars.
  14. Thanks stickhandle2 gave thanks for this post
  15. #10
    Join Date
    Aug 2006
    West Branch
    MI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I usually put two 40 lb. Weights, but really do not need to with electric lean.
    Hey Red1, still have my sidecar for sale.
    Later-
    "Sometimes, it is Fun to let them slowly pass by,
    then Smile, as they wipe the Drewl off their face!"
  16. #11
    Join Date
    Aug 2006
    Malvern, AR
    AR
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Have gone out without anyone in car. As suggested easy on turns and no problems.
    Just put on new tires. Decided to go back to the thinner tire on the front that I had before the car. Right after I did that the bracket holding the front wheel stabilizer broke in the garage as I was parking. I decided while waiting for the new bracket to try again without the stabilizer. Was I surprised, no shake or wobble. Must be the thinner front tire.
    I am going to try it without for a while. Will keep the stabilizer with me just in case I have to put it back on.
Similar Threads
  1. Shock was empty but no leak?
    By CantWin1 in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 09-27-2012, 02:12 PM
  2. EMPTY
    By jaymacdoo in forum Watering Hole
    Last Post: 09-19-2012, 01:17 PM
  3. Is your bowl 1/2 full or empty
    By MidlifeVenture in forum General Tech Talk
    Last Post: 11-22-2010, 11:28 PM
  4. Empty nesters
    By Naugh-T in forum Watering Hole
    Last Post: 08-10-2010, 08:57 PM
  5. empty room for Eureka Springs
    By Cinderella in forum Watering Hole
    Last Post: 09-11-2008, 07:45 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
