cimmer Posted May 23, 2017 Share #1 Posted May 23, 2017 (edited) I know there has been some confusion on what seals are needed to rebuild the stock calipers on the 86-93, ie MKII Ventures. I thought I would document it so there would be no confusion least for me.. The right front caliper and the rear caliper both use part # 1KT-25803-00 for their seals. It takes 2 of these part numbers to rebuild one caliper as the package only contains 2 pressure seals and 2 dust guide seals and a small tube of red grease. It stands to reason they would be the same since they are linked together from the factory. The left front caliper uses part # 1NL-W0047-00 for its seals. Again it take 2 of these part numbers to rebuild one caliper as the package only contains 2 pressure seals and 2 dust guide seals and a small tube of red grease. The red grease is used on the seals during insertion of the piston to help them slide in easier and not damage the seals. I hope this helps to clear things up a bit as the parts fiche or service manual is not the best in showing what is needed for which caliper. Rick F. Edited May 25, 2017 by cimmer Link to comment Share on other sites More sharing options...
Bob K. Posted September 13, 2018 Share #2 Posted September 13, 2018 The right front caliper and the rear caliper both use part # 1KT-25803-00 for their seals. It takes 2 of these part numbers to rebuild one caliper as the package only contains 2 pressure seals and 2 dust guide seals and a small tube of red grease. It stands to reason they would be the same since they are linked together from the factory. When you say "they are factory linked from the factory", what is factory linked? Do you mean the individual pistons within the caliper or are you talking about the linked braking system? (On my '93, the rear and front left are linked. The front right is operated only by the right brake handle.) Link to comment Share on other sites More sharing options...
cimmer Posted September 15, 2018 Author Share #3 Posted September 15, 2018 I misspoke.. you are correct it is the rear and left front.. Rick F. Link to comment Share on other sites More sharing options...
Bob K. Posted September 15, 2018 Share #4 Posted September 15, 2018 I'm not sure how you figured all of that out, cimmer! I spent about 20 minutes on the fiche at PartShark and finally gave up. I ordered the www.brakecrafters.com rebuild kits for the front and rear. Link to comment Share on other sites More sharing options...
cimmer Posted September 16, 2018 Author Share #5 Posted September 16, 2018 Part of it was trial and error.. I helped beta the Partscrafter kit with the guy that owns it and actually I prefer that kit as it gives you new o-rings for the caliper halves. They are not available from Yamaha as they dont want you separating the halves but I like to hone out the bores and make sure they are clean before reassembling them. Plus it is nice to order one item and have everything in one kit to rebuild the front calipers. Good luck Rick F. Link to comment Share on other sites More sharing options...
dna9656 Posted September 16, 2018 Share #6 Posted September 16, 2018 All; IMHO https://www.brakecrafters.com/ is the best place to go; you get ALL the parts Here is the front application; now all the discriptions are Mark's, the man that runs the store. Call him with any questions, you'll find out right away he's not from these here parts.... The kit comes with everything you need: Bleeder, a sexy little dust cap for your sexy new bleeder, seals, red grease, copper washers. I bought my own tub of red grease (EBay) because I might have to buy a kit that doresn't provide the red grease some day... Link to comment Share on other sites More sharing options...
Prairiehammer Posted October 10, 2018 Share #7 Posted October 10, 2018 I have compiled this chart showing the Yamaha parts needed to rebuild the MKII calipers. 1986-1993 XVZ Caliper Parts.xlsx Link to comment Share on other sites More sharing options...
