edtheguy Posted August 23, 2016 Share #1 Posted August 23, 2016 Replaced the rectifier yesterday . This morning on way to work, noticed Volt meter pegged ,lights seem unusually bright. Do I have a problem? Link to comment Share on other sites More sharing options...
bongobobny Posted August 23, 2016 Share #2 Posted August 23, 2016 Uhhhh, probably! With bike running, measure across the battery. At idle you should see around 12.8 to 13.3 volts. As you rev it up you should see around 13.8 to 14.2 volts. Both ranges are a give or take a tenth or two. Should you be reading some ridiculous number like 15 volts or so, your NEW R/R is NFG! Do not use! Replace immediately before you fry your battery and possibly other electrical items on the bike!!!!! Link to comment Share on other sites More sharing options...
edtheguy Posted August 27, 2016 Author Share #3 Posted August 27, 2016 Thanks will check it. Supposedly rectifier is brand new . Wonder if my volt meter is screwy? Anyway will check it out ,thanks . Link to comment Share on other sites More sharing options...
ChurchBuilder Posted August 27, 2016 Share #4 Posted August 27, 2016 I burned up a $150.00 battery by over charging for a couple of weeks so defiantly check with a volt meter Sent from my SCH-I545 using Tapatalk Link to comment Share on other sites More sharing options...
cowpuc Posted August 27, 2016 Share #5 Posted August 27, 2016 Uhhhh, probably! With bike running, measure across the battery. At idle you should see around 12.8 to 13.3 volts. As you rev it up you should see around 13.8 to 14.2 volts. Both ranges are a give or take a tenth or two. Should you be reading some ridiculous number like 15 volts or so, your NEW R/R is NFG! Do not use! Replace immediately before you fry your battery and possibly other electrical items on the bike!!!!! IMHO - our school master guru Bongo is 100,000,000,000 percent right on the money - dont run er no more till ya drop a meter on the battery!!! I have noticed a fair amount of variances in the dash volt meters over the years but never had one peg out PLUS - noticing the lights are brighter is a positive give away that she's over producing = regulator problems of some sort.. Might not be a bad idea to check the ground to the rectifier - could be as simple as a bad connection.. This brings back memories,, back in the 6 volt Yamaha Enduro days Mom Yam used the battery to shunt off voltage spikes - get a weak battery, over rev the motor a little and POOF - 15 dollar headlight and all those cute little 6 volt tach/speedo bulbs = exit - stage left:big-grin-emoticon:... ,, thinking our dear friend Bongo is trying to keep something like that from happening to your bikes much more expensive highly sensitive digital devices there brother:thumbsup: I love Bongo - he's a really nice guy Link to comment Share on other sites More sharing options...
edtheguy Posted August 28, 2016 Author Share #6 Posted August 28, 2016 Found a probe with my digital multimeter. Low battery equals erroneous display . All good now thanks . Link to comment Share on other sites More sharing options...
edtheguy Posted September 6, 2016 Author Share #7 Posted September 6, 2016 Is it possible that I have some other problem? Lights still brighter than normal, volt meter pegged at 4000 rpm. Checked voltage at battery showing 13.5 to 14.5 volts even at 4000 rpm. Note this is with bike sitting. Seems like something else is going on when riding. Any thoughts? Link to comment Share on other sites More sharing options...
Marcarl Posted September 6, 2016 Share #8 Posted September 6, 2016 Make sure that you not only check the battery posts, but also the connectors to the cables. Also check the positive to a ground other than the cable, so go to the body or engine, this will show if you have a good main ground. It's also possible that you have got used to things being dim and that now they are brightened up as they should be, but with the gauge pegging out I would think otherwise until I fully checked it out. Link to comment Share on other sites More sharing options...
bongobobny Posted September 6, 2016 Share #9 Posted September 6, 2016 There is a possibility your new R/R is regulating at to high a voltage, it sounds a little high. Start bike, disconnect battery and THEN read what the "Regulated" voltage is. Could be it is regulating more like 15 volts (too high) and the battery is bringing it down to what you are reading. Yup, like Carl said, and try reading it closer to the R/R away from the battery... Link to comment Share on other sites More sharing options...
