User Tag List
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: 1986 Venture Royale Issues
  1. #1
    Join Date
    Aug 2015
    Flaxton
    ND
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default 1986 Venture Royale Issues
    Hi,
    I have a 1986 Venture Royale, that I have had for just a bit and just started riding. The air suspension is not working, is that easy to replace? When the bike warms up, I start having shifting issues, I cannot get it into Neutral. Shut it down, start is up when it cools off and I can shift into neutral and start it. Any solutions?
    Thanks,
    Jim
  2. #2
    Join Date
    Jul 2013
    Omaha
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Default
    With engine stopped and wheels not rolling there is usually pressure on transmission preventing it from shifting to neutral. If you're going to neutral shift before you get stopped or move the bike forward or back to free the pressure on the transmission when you want to shift to neutral. VR doesn't have automatic neutral finder like my Vulcan 2000 and some other models.
  3. Thanks Tatonka82 gave thanks for this post
  4. #3
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    132 Post(s)
    Tagged
    0 Thread(s)
    Default
    Air ride only works with the key in the ACC position. If that doesn't work for you then we need more info. Does the control light up and what error codes are you getting.
    Neutral can be a pain at times, often easier to find from 2nd than from 1st. Try changing the clutch fluid and making sure the clutch is properly bled. If the clutch doesn't release properly it'll be hard to find neutral.
    Nothing in this life
    will
    Get in the way of my future
  5. Thanks Tatonka82 gave thanks for this post
  6. #4
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    46 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Tatonka82 View Post
    Depends on what part of the C.L.A.S.S. (air leveling system) is not working. Does the controller light up and display anything besides "psi"? As Marcarl says, the CLASS can be operated only when the keyed ignition switch is at the ACC position.
    If the controller does not turn on, check the CLASS fuse. It is a glass fuse within a rubber waterproof in-line fuse holder.
    Click image for larger version.
Name:	CLASS fuse holder 1a.JPG
    Again as Carl says; probably requires a fluid flush and bleed of the clutch hydraulic system. I lost the capability to disengage the clutch completely on my then new to me 1990 when I was riding it home from the seller's business. Old water contaminated fluid was the cause.
    Kevin M. Campbell https://www.facebook.com/Prairiehammer
    1974 Honda CB750, 1991 Venture Royale "the Tuxedo"
  7. Thanks Tatonka82 gave thanks for this post
  8. #5
    Join Date
    Aug 2015
    Flaxton
    ND
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks Gentlemen. You will get a kick out of this, I called a "premiere" Yamaha dealer in ND. The service person asked me if a Venture Royale was a boat, and when updated replied with the stock, we don't work on bikes that old. I asked, what about boats?
  9. #6
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    289 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yup, most dealers will not touch a bike more than 10 years old.
    Most of there mechanics are probably not old enough to have ever seen a NEW 1st gen Venture.
    Jeff Borowski . . Had 88 Venture standard, now 2011 Silverado 4x4
    There are 10 kinds of people that understand binary, those that do, and those that don't.
    Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
  10. Likes madirishman13 liked this post
  11. #7
    Join Date
    May 2010
    Lizella
    GA
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    Both local dealers to me will work on 1st gens, but plainly told me they won't work on restoring Mike's 1st gen. Too many problems that will likely lead to more problems. Both stated when he finds a reliable 1st gen they will happily do work on it.
  12. Likes videoarizona liked this post
  13. #8
    Join Date
    Aug 2015
    Flaxton
    ND
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Fluid
    Quote Originally Posted by Prairiehammer View Post
    What is the best fluid to flush with a DOT 3? Which brand do you like?
  14. #9
    Join Date
    Aug 2015
    Flaxton
    ND
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Which is the best fluid to flush with a DOT 3, but any brand preference?
  15. #10
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    46 Post(s)
    Tagged
    0 Thread(s)
    Default
    DOT3 or DOT 4 brake fluid. No brand preference.
    Just a FYI: When dealing with brake fluid around these Ventures, treat the brake fluid as if it were a plastic eating acid, because it is. Protect the bike with impermeable plastic and absorbent towels or such. Immediately wash any spills from the bike with copious amounts of soapy water and clear water rinse. Because spilled brake fluid will migrate into cracks and crevices and remain invisible, but will cause irreparable harm to the ABS plastic.
  16. Likes Pasta Burner liked this post
  17. #11
    Join Date
    Aug 2015
    Flaxton
    ND
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks for the heads-up. I will figure up a plan.
  18. #12
    Join Date
    Aug 2015
    Flaxton
    ND
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Air Error
    I checked out the error code on the air ride, which gives me a code of E4.
  19. #13
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    289 Post(s)
    Tagged
    0 Thread(s)
    Default
    The E4 error code is very common.
    Pull out the controller and resolder all of the connector pins to the circuit board. The solder cracks from old age and gives a bad connection.
  20. #14
    Join Date
    Aug 2006
    Renton
    WA
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Default
    Also, the Air Ride, Control Head, Cable, about 3 inches from head, is a Pull Apart Plug. Check the Pins in those plugs for
    being LOOSE. You might have to RE - Solder the pins, with a " Small Soldering iron " .
    While you are working on your bike, Open, and Clean, EVERY Electrical PLUG, you can get your hands On !!
    If your bike still has an Lead Acid, old style battery, get a new AGM type Dry Cell !!! Money Well Spent !!
    Clean ALL the Electical Switches in both handle bar units, with Electrical Contact Cleaner , ( Its a good thing to do )
  21. #15
    Join Date
    Feb 2020
    Edmonton
    Canada
    AB
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 1986 Venture Royale Issues
    Hi Iím having a code E1 on my air ride can anyone help with this??
    '83 Venture 1200 Black
    '86 Venture Royale 1300 Gold
Similar Threads
  1. 1986 Venture Royale Rescue
    By twigg in forum Watering Hole
    Last Post: 07-11-2012, 05:54 PM
  2. My new 1986 Venture Royale
    By JohnT in forum Picture Folder
    Last Post: 05-12-2012, 10:11 PM
  3. 1986 Venture Royale
    By kevin-vic-b.c. in forum Watering Hole
    Last Post: 10-19-2009, 10:35 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
