blaine1 Posted July 17, 2015 Share #1 Posted July 17, 2015 starts well(new battery) but idle speed increases as it warms up) Has someone have any idea bike has been setting for a while blaine Link to comment Share on other sites More sharing options...
Prairiehammer Posted July 17, 2015 Share #2 Posted July 17, 2015 1. Partially plugged pilot circuit on one or more carbs. 2. Air/vacuum leak. 3. Initial cold idle speed set too high. Lower the idle to under 950 rpm. Link to comment Share on other sites More sharing options...
blaine1 Posted July 17, 2015 Author Share #3 Posted July 17, 2015 it runs real good idling you run it it runs faster the longer you run it would try seafoam Link to comment Share on other sites More sharing options...
Flyinfool Posted July 17, 2015 Share #4 Posted July 17, 2015 How fast is faster. What speed is it idling cold and what does it speed up to hot? How are you using the choke? Some speed increase is normal Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 17, 2015 Share #5 Posted July 17, 2015 My 85 did that a few years ago. I Sea-Foamed it hard and it finally quit it. Link to comment Share on other sites More sharing options...
blaine1 Posted July 17, 2015 Author Share #6 Posted July 17, 2015 i am looking to buy the guy told me this when i talked to him it has 39000 k on it will here it for my self in the morning will let you know blaine Link to comment Share on other sites More sharing options...
blaine1 Posted July 18, 2015 Author Share #7 Posted July 18, 2015 i bought the bike turned the idle down sea foam will let set for the night the air ride pimps but will not hold have to pump it up every time any thoughts what to look for blaine the body is a little cracked ant tires are bad only paid 1200 for it so i have a little leaway Link to comment Share on other sites More sharing options...
blaine1 Posted July 18, 2015 Author Share #8 Posted July 18, 2015 it came with xvz13s xvz13ds service manual i think i am going to need it Link to comment Share on other sites More sharing options...
Great White Posted July 18, 2015 Share #9 Posted July 18, 2015 For the air suspension, make yourself a little soap and water solution in a squirt bottle. Then trace down all the places there's joints in the air lines. Squirt a little of your solution on the joints and when/if it bubbles you've found your leak... Link to comment Share on other sites More sharing options...
blaine1 Posted July 19, 2015 Author Share #10 Posted July 19, 2015 Link to comment Share on other sites More sharing options...
Karaboo Posted July 20, 2015 Share #11 Posted July 20, 2015 Did you get the T-bird as part of the deal? Link to comment Share on other sites More sharing options...
