Rdfroese Posted June 4, 2015 Share #1 Posted June 4, 2015 I have the will but not the aptitude; nonetheless I was able to remove and replace a starter [that stopped working without warning] on my 1986 Venture! I was excited; especially when it turned the engine over after installation. That's always a good thing obviously. Drained the coolant out of the 19mm bolt on bottom of water pump; removed the two hoses in front, unfastened the thermostat assembly, backed the elbow out of the water pump, removed bolts from starter and removed electrical cable and "argued" the starter out of its hole with a bit of leverage and finally got it out. I did not remove radiator nor an exhaust pipe, not did I take thermostat housing apart. I am very thankful for the help I found on these pages. It was really good to know about getting a starter that is a four brush versus the original two brush. Together with my new Deka AGM battery and four brush starter I should not have to worry much about getting it to start in the future. Link to comment Share on other sites More sharing options...
ReinyRooster Posted June 4, 2015 Share #2 Posted June 4, 2015 It is very satisfying to be able to sit back after a job is complete.....and of course even more satisfying when it works!!LOL! Congratulations. Link to comment Share on other sites More sharing options...
