User Tag List
Results 1 to 5 of 5
Thread: Bleeding the clutch
  1. #1
    Join Date
    Apr 2014
    Newcastle
    Canada
    ON
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Bleeding the clutch
    I just wanted to post this as I read every thread that referenced the clutch not working. I had an issue with the clutch ever since I replaced the fluid last season. I decided to rebuild the master after my first test ride of the season this year because the clutch was engaging almost immediately when the lever left the hand grip. The rebuild went through without a hitch however I couldn't get the clutch to work and the lever was very soft. After trying everything up to and including splitting the faring to see if the fluid was making to the joint between the hard and rubber line, I decided to try bleeding the system one more time.
    That brings me to the point of this post.
    I read some old threads and my two take-away quotes from those were:
    1 - "I used almost a whole bottle of fluid before I got all the air out"
    2 - "bleed it and then bleed it again and when you think you've bled it enough, keep bleeding it"
    Now, I may not have the quotes exact but the points are made. I want to assure anyone else who finds themselves in my shoes without anyone close by to give them moral support - bleed the darn thing and just when you thing you've bled it as much as you can, keep bleeding. And have a full bottle of fluid on hand. You will get all the air out and that lever will eventually work!
    Thanks for all of you who have posted in the past to help educate those of us that are newer to the Venture family. This community is well worth the $12/year!
  2. Thanks flyday58, Du-Rron, Mikealiasmike gave thanks for this post
    Likes videoarizona, Bob K. liked this post
  3. #2
    Join Date
    Jan 2014
    Post Falls
    ID
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That is why I went Harbor freight and bought a vacuum bleeder,it takes all the guess work out of bleeding,also much faster,and only cost about 30 bucks.
  4. #3
    Join Date
    Jun 2010
    Buckley, Washington
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    I use the Condor method of reverse bleeding the clutch. One Baby Nasal Aspirator ($5.00). Remove the bleeder. Cut the end off so it fits nicely inside the hole with a good firm seal. Remove some of the old fluid from the resorvior by the handle bar with the Aspirator. Empty and Fill the Aspirator with new fluid and place in the hole and firmly but slowly squeeze the Apirator. If there is air in the line you will hear the bubble noise being pushed up and out. Watch the Resorvior that it does not over flow. Repeat as needed. Works every time.
  5. Likes suds liked this post
  6. #4
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default
    I had issues once, and the most simple sure way is: Loosen Reservoir lid, squeeze clutch lever slowly until all the way to bars, tie off with rope, and let sit overnight. All the air will naturally come out. Tighten reservoir lid, untie lever, and you should be go to go.
  7. Likes kinsmd69, videoarizona, Bob K. liked this post
  8. #5
    Join Date
    Aug 2006
    Lake City
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Bleeding the clutch
    5 years later than the last post but it works. Cap off or loose and tie handle down.
Similar Threads
  1. clutch bleeding
    By Dr. Psycho in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 09-24-2011, 02:58 PM
  2. bleeding the clutch
    By CaptainJoe in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 02-03-2011, 02:52 PM
  3. Bleeding the Clutch
    By Motorpig in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 11-01-2010, 03:42 PM
  4. Clutch bleeding help
    By cb1313 in forum Watering Hole
    Last Post: 10-29-2010, 09:45 AM
  5. Clutch Bleeding
    By 93 venture in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 08-12-2007, 11:06 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
