Russ Posted April 11, 2023 Share #1 Posted April 11, 2023 Hey all, i've been searching all over and i'm trying to find out what the actual rider and passenger weight capacity is for the 07 Venture. the manual states 410 lbs, if I remember correctly, however i've seen some things that lead me to think this is an under-estimate. I want to take my 17 year old for a ride, but seeing as he outweighs me, i know we'll be busting that 410 mark, so i wanted to find out what ya'lls experience has been regarding the actual combined weight capacity. thanks in advance! Link to comment Share on other sites More sharing options...
etcswjoe Posted April 11, 2023 Share #2 Posted April 11, 2023 I don't think you will have an issue; I have exceeded your passenger weight on a regular basis, with full saddle bags while pulling a 400-pound trailer. Link to comment Share on other sites More sharing options...
Russ Posted April 12, 2023 Author Share #3 Posted April 12, 2023 thank you for this confirmation. between the two of us, we're around the 570 mark, so i was concerned. now to figure out how much air to put in that rear shock. 😉 Link to comment Share on other sites More sharing options...
Marcarl Posted April 13, 2023 Share #4 Posted April 13, 2023 23 hours ago, Russ said: thank you for this confirmation. between the two of us, we're around the 570 mark, so i was concerned. now to figure out how much air to put in that rear shock. 😉 Fill it up, to I think 55lbs. Best check the manual though, you don't want to over capacity. Link to comment Share on other sites More sharing options...
N3FOL Posted May 25, 2023 Share #5 Posted May 25, 2023 Pump up your tires close at least closer to the max psi. On my '07, I always keep it at 40 all year round. Link to comment Share on other sites More sharing options...
