mother Posted September 7, 2007 Posted September 7, 2007 i have removed the control unit and resoldered the pins on the circuit board, and the all check out okay. the E-1 code still comes up when i turn on the key to the accessory position. anyone have this happen before and where is the best place to start? Cheers, Scott
Guest ReinyRooster Posted September 7, 2007 Posted September 7, 2007 I had the same issue. All I had to do was tighten all connections and clean all around the compressor unit and it stopped.
Thom Posted September 7, 2007 Posted September 7, 2007 i have it too , i gess i did not solder it rite for the 2nd time , i just wigle the plug and it works .
sarges46 Posted September 7, 2007 Posted September 7, 2007 It took me two times to get it right when I did mine. I missed some pins I guess. I did every pin I could find even if they didnt look bad. Thats over a year and no problems since.
Thom Posted September 9, 2007 Posted September 9, 2007 guess what i just read the manual , it said make sure batt. is fully charged , da , i am charging it now and i just got done resolderd the pins , charge your batt. and see if that works
