VentureRider.Org Motorcycle Superstore
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > Second Generation Venture Tech Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,765 Entries 0
Members Entries
Threads 52,370 Reviews 0
Threads Reviews
Posts 624,015 Polls 46
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 02-23-2012, 09:05 AM
Eagle77 Eagle77 is offline
06 Black Cherry RSV
Default Where do I start-----Starter problems
I have an 06 Venture. Got on the bike yesterday and get 1 click at the starter. I charged the battery and still the same 1 click. Took the battery in and it checks out as good and fully charged. Checked battery connections and still only one click at the starter. Everything else works,lights are bright and etc. I am not sure where to look for the problem. Any advise is appreciated.
  #2
Old 02-23-2012, 09:58 AM
twigg twigg is offline
1986 Venture Royale
Default
Quote:
The "click" is usually the solenoid.
Do all the panel lights dim when it clicks? That would suggest that the starter is trying to turn and drawing full (or more) power.
Connections are the main cause .... battery to solenoid, solenoid to starter, engine ground to battery.
Check and clean.
If that doesn't fix it then your starter motor has an issue. It may be "stalled".
Rock the bike (ignition off) in gear until the engine turns a bit ... Try again with the starter.
If that fails to fix it, the starter needs to come off for repair.
  #3
Old 02-23-2012, 11:47 AM
06 Black Cherry RSV
Default
I am back at it this morning. It sounds like the click I am hearing is coming from under the battery. Like maybe a relay or something. Lights are not dimming when starter button is pressed. I am now thinking maybe a relay or loose connection to or from relay.
Thanks for your reply.
  #4
Old 02-23-2012, 11:52 AM
Cougar's Avatar
Cougar Cougar is offline
MM RSV Hannigan Trike 778
Cougar has a Profile Picture
Supporting Member
Location: Find Cougar on Google Maps! Near Iowa City,Iowa
Default
you will see under the battery box lift it out and check it. got mine pulled right now.
check those connections.
Jeff
  #5
Old 02-23-2012, 11:53 AM
Cougar's Avatar
Supporting Member
Default
The other plug-ins if your on the left side of the bike look in there and you will see a black panel box to the left with plugs as well two bolts holding that on as well.
  #6
Old 02-23-2012, 11:55 AM
eusa1's Avatar
eusa1 eusa1 is offline
Supporting Member
eusa1 has a Profile Picture
Supporting Member
Default
you can access the relay from behind the left passenger floorboard mounting plate "black plastic"
__________________
YES I AM "THE DIAMOND CUT GUY"
check pictures and videos on facebook/the diamond cut guy
royalstarventure03@yahoo.com
  #7
Old 02-23-2012, 12:09 PM
gscbertrand's Avatar
gscbertrand gscbertrand is offline
1984xvz1200dt
Supporting Member
Default
Did you check the solenoid? If you can get to the 2 connections jump them together with an old screw driver with the ignition key in the run position. If the bike starts I would get a new solenoid. Good luck with with the hunt for a cure.
__________________
I'm so broke I can't afford free advice.
  #8
Old 02-23-2012, 12:48 PM
Yammer Dan's Avatar
Yammer Dan Yammer Dan is offline
Supporting Member
Supporting Member
Default
Take apart all connections, clean them and put them back togather.
__________________
1st GENS RULE
Faded Blue is the fastest.
"Blue Beast" will live forever
  #9
Old 02-23-2012, 12:55 PM
06 Black Cherry RSV
Default
First thanks for all the ideas. What I found is that the click is from the starter relay. I pulled the relay off the bike and checked this and ran a test according to my Clymer manual and found there is no continunity across the posts. I think this means the relay is bad.
  #10
Old 02-23-2012, 01:35 PM
1986 Venture Royale
Default
There will be no continuity normally, and continuity when you apply 12V to the low side.
If it clicks, and when "clicked" there is no continuity, then it is bad.
  #11
Old 02-23-2012, 03:41 PM
06 Black Cherry RSV
Default
That is the conclusion that I came to . I have ordered a new relay
Thanks everyone for your help.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1983 Venture 1200 Starter Problems? wes21827 Poor Man Tips and Fixes 1 07-25-2011 07:19 AM
1st Start in 2011 - Won't Start Golf&Venture First Generation Venture Tech Talk 14 04-04-2011 01:53 PM
2 Problems-starter and taillights CAZCO First Generation Venture Tech Talk 11 11-02-2008 08:38 AM
Starter access, problems? Gearhead First Generation Venture Tech Talk 10 01-03-2008 02:44 PM
Starter Problems Freebird Computer, Lights, Horns, Other Electrical 0 08-31-2006 04:06 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
