VentureRider.Org Diamond R Accessories
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > Second Generation Venture Tech Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,857 Entries 0
Members Entries
Threads 52,713 Reviews 0
Threads Reviews
Posts 628,329 Polls 46
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 09-15-2013, 09:18 AM
bikerjohn's Avatar
bikerjohn bikerjohn is offline
2006 Midnight Venture
Supporting Member
Default oil pressure gauge troubles
Just finished installing my oil pressure gauge. worked fine and then I noticed the reading dropped to almost nothing.
First installed was around 40 to 50, I was riding back home and at full speed on the interstate it was reading 20.
Any ideas what could have cause this to happen.
It looks like everything is tight and i have noticed a leak.
Thanks
__________________
Live to Ride!
Or why Live!
  #2
Old 09-15-2013, 09:24 AM
Squidley's Avatar
Squidley Squidley is offline
'02 RSMV '79 FLH '86 VR
Squidley has a Profile Picture
Supporting Member
Default
John,
Did the pressure drop when the bike was at running temp and while you were sitting at an idle/stopped? Every Venture I have known that has an oil gauge does this. I remember several years back one of the members talking to me about only having 5 lbs of pressure when at a stop light when the bike was warmed up.
Freaks you out when it 1st happens, but this is normal on the majority of the Ventures. Another thing too is if your gauge is not a super high dollar quality unit, 5 lbs will barely make the needle move....
__________________
Gunboat....I eagerly await the day we can ride together again, Godspeed my brother
  #3
Old 09-15-2013, 09:26 AM
bikerjohn's Avatar
Supporting Member
Default
at idle i was sitting at 0 and at speed at 20
when i first installed it was around 40 to 50 at speed.
__________________
Live to Ride!
Or why Live!
  #4
Old 09-15-2013, 09:30 AM
Prairiehammer's Avatar
Prairiehammer Prairiehammer is offline
'83 Standard, '91 Royale
Prairiehammer has a Profile Picture
Supporting Member
Location: Find Prairiehammer on Google Maps! Mount Palatine, Illinois
Default
Many people who thought they wanted an oil pressure gauge on the Ventures discovered the disconcertingly low oil pressure readings and removed the gauge to relieve their anxiety. The Venture engine in all it's manifestations, as well as the VMax engine are notorious for revealing a shockingly low oil pressure reading when warmed up.
__________________
Kevin M. Campbell https://www.facebook.com/#!/Prairiehammer
1974 Honda CB750;1983 Venture Standard, 1991 Venture Royale in "Tuxedo"
Bloody Red One 1972-1975
  #5
Old 09-15-2013, 09:51 AM
Riderinthesnow's Avatar
Riderinthesnow Riderinthesnow is offline
2001 star venture
Riderinthesnow has a Profile Picture
Supporting Member
Default
Thanks
The low oil pressure reading is normal. That is why Yamaha installs a oil level gauge and not a pressure gauge. All my Venture were the same, so was my Virago. They all lived to be very high mileage bikes.
__________________
I ran out of sick time, so I called in dead
  #6
Old 09-15-2013, 05:11 PM
spear's Avatar
spear spear is offline
2004 RSV (Pearl/white)
Supporting Member
Location: Find spear on Google Maps! 32deg 23' 54"S, 148deg 49' 39"E
Default
It's important to have oil in there to begin with.
__________________
I do not try to explain why I ride motorcycles. For those who understand, no explanation is necessary. For those who don't - no explanation is possible!
  #7
Old 09-15-2013, 06:29 PM
sandman's Avatar
sandman sandman is offline
88 VR ''the MACHINE''
Supporting Member
Default
BikerJohn; If I remember correctly, take the idle pressure, say 5psi and add 10psi per 1k of rpm, so at 2000rpm say 25psi at running temp. Just remember these are volumn pumps that produce enough to protect at reduced pressure. Check your leak and look for air in line. Did you install a automotive type gauge? with plastic line or a motorcycle specific? A 100psi wont be as accurate at low pressures as a 80psi. I would like to hear from those that have digital gauges. Good luck
  #8
Old 09-15-2013, 08:50 PM
Jactana Jactana is offline
Jactana has a Profile Picture
Location: Find Jactana on Google Maps! Kamloops, B.C., Canada
Default
Those low readings are perfectly normal. My mechanic laughed when I installed the oil pressure gauge on my Venture. He predicted that it would drive me nuts, and he was right. He went on to explain that the Venture had a high volume/low pressure pump that would make most anal individuals (I'm sure he wasn't talking about me LOL) VERY ANXIOUS when monitoring it. The water temperature gauge isn't must better. We have very hot summers here, and alot of my riding is in desert conditions. I frequently saw the water temperature reach 230-240 degrees. He again explained that the Venture's thermosat doesn't even open until around 207 degrees, and the fan doesn't come on until 215 degrees, so the readings again are quite normal. Sometimes I think ignorance is bliss! Cheers, Ron
  #9
Old 09-16-2013, 12:08 AM
bikerjohn's Avatar
Supporting Member
Default
Thanks for all the replies.
Looks like your all right!!
i fired the bike up today and cold start the gauge reads 30 to 40 so when it warms up it drops.
Good to know.
Also I did notice the water temp i figured if it hasn't got to 250 and no lights on I am all right..
__________________
Live to Ride!
Or why Live!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Air Pressure Gauge SilvrT Watering Hole 32 03-22-2010 05:52 PM
Fitting for oil pressure gauge SilvrT Watering Hole 17 11-04-2009 11:10 PM
tire air pressure gauge? davepa Watering Hole 22 09-25-2009 07:54 AM
Oil pressure gauge? timgray First Generation Venture Tech Talk 8 04-02-2009 11:36 AM
Has anyone felt need for oil pressure gauge? Bigin General Tech Talk 4 01-02-2007 01:29 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
