VentureRider.Org Jake Wilson
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > Trike & Sidecar Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,703 Entries 0
Members Entries
Threads 52,219 Reviews 0
Threads Reviews
Posts 622,204 Polls 45
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
Reply
Thread Tools Display Modes
  #1
Old 07-22-2011, 04:50 PM
hojo hojo is offline
Default voyager trike problems
Hi I'am new to biking bought a 2003 royal star venture with a voyage kit on it.Had all kind of problems with it.I took it to a voyage dealer he relined it back up and tighten loose bolts.He said wheels were toed in more then likly from voyage.He corrected that problem,however in some curves it's hard hard hard to handle.I talk to three trike builders in our area .They tell me voyage trike kits are real problem.That not much can do for them. That even a product like ez steer won't help. I live in cleveland tn. so roads are windy.I was told by two trike builders not to wast anymore money. The problem is the three wheels work against each orther in a tight turn, no why to slove this.
  #2
Old 07-22-2011, 09:04 PM
steamer's Avatar
steamer steamer is offline
99 rsv,99rsvm/t
steamer has a Profile Picture
Supporting Member
Default
I had the voyager kit on my RSV.It takes a while to get the setup right.First thing is to make sure it is centered.Then you have to play with the pre-load. I found that if you increase the pre-load to 3/4 inch, it works really well on our bikes. This is very important,MAKE SURE THERE IS ON AIR PRESSURE IN THE REAR SHOCK when setting the pre-load. after setting the pre-load pump up the shock as desired. My bike handled much better when set up this way. another thing is the trike tire pressure,I set mine to around 15psi. You can play with this to improve the ride and handling. as for the loose nuts,use locktite.
The Following User Says Thank You to steamer For This Useful Post:
  #3
Old 07-22-2011, 09:09 PM
steamer's Avatar
99 rsv,99rsvm/t
Supporting Member
Default
One thing I forgot to mention, The voyager trike kit now handles all most as good as my Motortrike venture. All trike builders will tell you the samething about the voyager kits. After all they want to convert your bike to a trike.
  #4
Old 07-22-2011, 09:55 PM
Default voyage trike problems
Thanks for the information .Did you change the rake?
  #5
Old 07-22-2011, 11:32 PM
gunboat gunboat is offline
Godspeed our Friend
Supporting Member
Default
hi larry
i have a '99 motor trike w/o the rake kit. i have installed 1" & 1/2 risers on the handle bars. this seams to help with the steering. i have drove it in the texas hill country
on the 3-sisters (fm's 337,336,and 335) some of the best twisties in the state. with no big problems. there are post's here about changing the handle bars out to flanders or td's. the rake kit from haggan is $1,000. and rakes the front end out another 6" for a total of 12".
carbon one (larry) and other trike riders say this is the best mod to do on the trike to help with steering ( like having power steering ).
don c.
  #6
Old 07-23-2011, 12:04 AM
fishrepair fishrepair is offline
Supporting Member
Supporting Member
Default Voyager trike kit
I HAD TROUBLE WITH MY VOYAGER TRIKE KIT AND HAD TO HAVE IT ADJUSTED SEVERAL DIFFERENT TIMES. I FINALLY MADE A PIECE FOR EITHER SIDE THAT BOLTS TO THE SIDE OF THE BIKE AND TO THE FRAME OF THE KIT. THIS TOOK CARE OF MY PROBLEMS AND IT RIDES LIKE A TRIKE WITH A STRAIGHT AXLE NOW. THERE'S NOT MUCH LEAN IN CURVES, AND IT'S A GOOD BALANCED RIDE . I WILL BE GLAD TO SEND YOU PICTURES IF YOU GIVE ME YOUR EMAIL ADDRESS.
  #7
Old 07-23-2011, 02:52 AM
Pegasus1300's Avatar
Pegasus1300 Pegasus1300 is offline
90 Goldwing TriKing Trike
Pegasus1300 has a Profile Picture
Supporting Member
Location: Find Pegasus1300 on Google Maps! Spring City,UT
Default
Has anyone who has tried a voyager kit also put a car tire on with the kit? Seems like a logical addition to me.You aren't going to lean much if any and you would get a better/wider contact patch for power delivery/breaking.
__________________
Happy TRAils/NSD
Paul
  #8
Old 07-23-2011, 05:30 AM
thanks fishrepair email is lawrencewaibel@yahoo.com
  #9
Old 07-23-2011, 05:42 AM
thanks happy trails i have a car tire on back of bike.i was told it should come off.the car tire is flat surface therefore with the voyager tires being flat sureface they work against each orther in turning.that also they don't stop as good mostly on wet road . i was told never put one on front of bike .that they could kill you on wet surface.
  #10
Old 07-23-2011, 07:36 AM
steamer's Avatar
99 rsv,99rsvm/t
Supporting Member
Default
If you install the ez steer on the voyager you better not plan on removing the trike kit and ride 2 wheels.It will not handle worth a darn.
  #11
Old 07-27-2011, 03:48 PM
Put close to a 1000 miles on last week.I went to ky. Stearns and Cumberland falls.Then took 25 back to tn.I had problems three times on turns that worried me. I order risers for handel bars. THANKS TO ALL for help
  #12
Old 07-27-2011, 04:33 PM
steamer's Avatar
99 rsv,99rsvm/t
Supporting Member
Default
Quote:
Originally Posted by gunboat View Post
hi larry
don c.
Hey Don, does your's pull a tad to the right when riding on secondary roads?
  #13
Old 07-27-2011, 06:28 PM
Godspeed our Friend
Supporting Member
Default
hi bob
can't realy say about the pull to the right on secondary roads as of yet. but will keep and eye out. i do have a slight lean to the right on level ground but i need to check the ladder bar's for proper ajustment.
don c.
  #14
Old 07-29-2011, 11:54 AM
kj5ix's Avatar
kj5ix kj5ix is offline
01 RSV Yellow Trike
Default
hi bob
don c.
Don; this link is for the GL1800 MT Trike, but the Ladder Bar System is the same concept on all of their kits. The adjustments should be similar if not the same. The Safety Bar up front, and the Lateral Brace adjustments are the same as far as play goes. Maybe it will help in some areas on your Trike. I wrote it in 08, and there are addendum's that haven't been added, but they are for their new IRS which is an entirely different system.
http://www.junkmaster.com/kj5ix/MTServiceManual.pdf
  #15
Old 05-06-2012, 05:35 PM
rabbit86 rabbit86 is offline
97 HD Sportster 883
Default
Quote:
Hi,
I am also having problems with my voyager kit on a HD Sportster. Could you send me the picture of what you did.
Thanks,
smithrogerw76@aol.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C/T on a Voyager Trike? DONATALIE The Darksiders 2 06-21-2009 07:52 AM
voyager trike kit nyjerry Trike & Sidecar Talk 0 08-25-2008 09:12 PM
Voyager Kit Problems FROG MAN Trike & Sidecar Talk 3 07-21-2008 10:08 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
