VentureRider.Org RoadRunner Magazine
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > Second Generation Venture Tech Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,567 Entries 0
Members Entries
Threads 51,677 Reviews 0
Threads Reviews
Posts 615,190 Polls 45
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 06-13-2011, 11:16 AM
SilvrT's Avatar
SilvrT SilvrT is offline
2013 Victory CCT
SilvrT has a Profile Picture
Supporting Member
Default Dunlop E3 Tire Pressure
Just curious what ya'll are running for pressure (front & rear) on your E3's ... what seems to work best?
Dunlop MFG shows max load front @ 41psi and 40psi for rear.
__________________
( Life's a Venture on my Victory! )
"Courage is the discovery that you may not win, and trying when you know you can lose."
  #2
Old 06-13-2011, 11:58 AM
Slab_Ryder Slab_Ryder is offline
2008 Burgundy RSV
Default
On my 08 Venture, 40, 40
The Following User Says Thank You to Slab_Ryder For This Useful Post:
  #3
Old 06-13-2011, 12:29 PM
Seaking Seaking is offline
Supporting Member
Seaking has a Profile Picture
Supporting Member
Default
I tend to run 40 in front and 41 in the rear tire and get lots of miles from my tires.
Depending on your weight, your cargo and so forth, the pressures should differ a bit.. Don't forget that the manufacturer's suggest tire pressure is for a "typical rider" of 160 lbs.. and for me and I'm sure a lot of others out there, that was ages ago.. cough cough..
however, a while back an old savvy mechanic showed me that to get the right tire pressures, or darn close.. At midday on a nice sunny day, run the bike up the highway on a nice paved surface and after a while, pull over quickly and put your hand on the tire and on the pavement.. the tire should not be hotter than the pavement.. His whole reasoning behind that is that if your pressure is too low, the sidewalls flex more, causing friction that causes heat felt on the tire.. when the pressure is proper, the tire is still warm to the touch but not hotter than the pavement.. I thought it sounded odd at first but after going through 2 sets of tires prematurely, set at manufacturer's recommended pressure, I then tried his advice and pumped up the pressures.. and my tires have always lasted a long time.. and handling was much better..
This works for me, however, others might think it's bunk.. but I don't go through tires as much as others
__________________
  #4
Old 06-13-2011, 12:36 PM
SilvrT's Avatar
2013 Victory CCT
Supporting Member
Default
Good advice! ... I'll give that a try as to me, it makes sense.
__________________
  #5
Old 06-13-2011, 02:24 PM
CMIKE's Avatar
CMIKE CMIKE is offline
Heavily Sedated...
Default 36-40 e3
Do not exceed pressure listed on the tire.
In the E3 I run 40 in the rear and 36 in the front.
The Following User Says Thank You to CMIKE For This Useful Post:
  #6
Old 06-13-2011, 02:56 PM
SilvrT's Avatar
2013 Victory CCT
Supporting Member
Default
Is that when cold or hot?
__________________
  #7
Old 06-13-2011, 05:53 PM
Rick Haywood's Avatar
Rick Haywood Rick Haywood is offline
2000 MM Edition #689
Rick Haywood has a Profile Picture
Supporting Member
Location: Find Rick Haywood on Google Maps! Eureka, Illinois
Default
This is what I run also. I get close to 18,000 out of mine. I just replaced the rear due to a screw in the tire and it had 16,200 on it and could have went a couple more or so.
__________________
Love Ya Rick & Shirley
  #8
Old 06-13-2011, 06:21 PM
LilBeaver LilBeaver is offline
2001 RSV
LilBeaver has a Profile Picture
Supporting Member
Default
Fully loaded I'll go 41/40 (F/R), no question.
When it is just puttering around I have found that anything lower than 36 on the front doesn't 'feel right' (for me) but I like to keep it above 37 for normal use.
As for the rear and puttering around I'll do anywhere between 38 and 40 in the rear. I tend to do closer to 38 when checking it in my garage in the summer as my garage is typically 20-40 degrees cooler than outside.
Lately I have just been maintaining the 41/40 and am happy with the ride.
  #9
Squidley's Avatar
Squidley Squidley is offline
'02 RSMV '79 FLH '86 VR
Squidley has a Profile Picture
Supporting Member
Default
Quote:
Always check your pressures when the tires are cold.
__________________
Gunboat....I eagerly await the day we can ride together again, Godspeed my brother
  #10
Old 06-13-2011, 06:23 PM
2001 RSV
Supporting Member
Default
Quote:
How the heck do we do that in Texas?
  #11
Old 06-13-2011, 07:26 PM
SilvrT's Avatar
2013 Victory CCT
Supporting Member
Default
I agree ... just wanted to ensure his readings were cold.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dunlop E3 tire fitment on second gen BlueVenture87 Second Generation Venture Tech Talk 7 09-30-2010 10:13 PM
Tire pressure Brake Pad Second Generation Venture Tech Talk 22 03-15-2010 09:57 PM
Tire air pressure jrcain32 Watering Hole 1 03-06-2009 04:35 PM
Dunlop Tire Sale Squidley Watering Hole 0 02-01-2009 09:46 AM
tire pressure? bisquit General Tech Talk 16 04-21-2007 02:42 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
