VentureRider.Org Baggershield.com
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > General Discussion > Watering Hole
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,857 Entries 0
Members Entries
Threads 52,712 Reviews 0
Threads Reviews
Posts 628,322 Polls 46
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
Reply
Thread Tools Display Modes
  #1
Old 02-24-2010, 04:52 PM
surf52 surf52 is offline
Default stereo upgrade
has anyone found a way to upgrade the stereo system on rsv?
  #2
Old 02-24-2010, 04:56 PM
rumboogy rumboogy is offline
2009 Venture-S
rumboogy has a Profile Picture
Default
That's the $64,000 question...and the money ain't been given away yet!!
  #3
Old 02-24-2010, 05:09 PM
Cougar's Avatar
Cougar Cougar is offline
MM RSV Hannigan Trike 778
Cougar has a Profile Picture
Supporting Member
Location: Find Cougar on Google Maps! Near Iowa City,Iowa
Default
The only up-grade I did was to place an amp in my trunk
seems to help.
There is a write-up I did on it in the Vtech Section.
Trust me I have tried ALL the speakers and still nothing
is any better then the Polk 401's (YET)! not I still will not give
up on this project. I was able to get the two 5x10 retro sounds
into my fairing but the sound still sucked!
Now you keep looking for us will ya?
Jeff
  #4
Old 02-24-2010, 05:14 PM
kwisor kwisor is offline
1999 rsv
kwisor has a Profile Picture
Default
hello
i have tryed the amp upgread removed it i have put a equlizer in the tape deck spot removed it the best thing i have done i put a edset on the head set and use a bose earbuds and i can listen to the best sound in my helment at any speed and i use a ipod touch with 2700 songs
bumble bee
kevin wisor
1999 rsv
jax fl
  #5
Old 02-24-2010, 06:33 PM
Freebird's Avatar
Freebird Freebird is offline
ADMIN - 2013 Road Glide Ultra
Freebird has a Profile Picture
Supporting Member
Default
I agree with Kevin and tried the same things. I finally gave up after finding the Edsets.
__________________
  #6
Old 02-24-2010, 08:28 PM
Whitlow Whitlow is offline
Default
Someone fill me in on the Edsets what are they where can I get them etc?
Thanks
  #7
Old 02-24-2010, 08:32 PM
Freebird's Avatar
Supporting Member
Default
http://www.edsets.com
They are the best I have used. I like the speakers they come with but they also have a jack where you can plug in earbuds if you prefer.
__________________
  #8
Old 02-24-2010, 08:33 PM
scarylarry scarylarry is offline
2009 RSV 2011 Kaw Voyager
scarylarry has a Profile Picture
Default
http://edsets.com/
All I know is what I read here..Never use them
  #9
Old 02-24-2010, 09:22 PM
camos's Avatar
camos camos is offline
~89 & 90 Ventures Royale~
camos has a Profile Picture
Supporting Member
Default
Jeff
Perhaps the problem is not so much the speaker but the enclosure. Putting a sound deadening foam around and behind the speaker can help get betterr sound out the front by reducing the bad sound from the fairing enclosure. Try some pillow foam which might work ok. Another thing that can affect the quality of sound from a speaker is using minimum 16 gauge wire rather than the 22 gauge wire that often comes in systems.
__________________
Cheers, Clive
~ 90 Venture Royal ~ 96 xv1100 Virago ~
"We have met the enemy and he is us." - POGO
  #10
Old 02-25-2010, 04:20 AM
Cougar's Avatar
Supporting Member
Default
Yep, even tried the foam behind them. ( a tad better )
added heaver wire when I installed the amp.
  #11
Old 02-25-2010, 10:13 AM
KiteSquid's Avatar
KiteSquid KiteSquid is offline
MMX Ti GL1800 Airbagger
Location: Find KiteSquid on Google Maps! King George, Virginia
Default
IMHO the best way to improve the sound from the Clarion stereo installed in these bikes is to sell the RSV and buy a new Honda Goldwing. I will not be doing this upgrade.
  #12
Old 02-25-2010, 11:03 AM
Cougar's Avatar
Supporting Member
Default
`yep
  #13
Old 02-25-2010, 11:20 AM
outlawauto38 outlawauto38 is offline
outlawauto38 has a Profile Picture
Default
i have the polk 401s with bass blockers and boom mats on all 4 speakers. bazooka made a plug and play amp and speaker kit for the rsv i was gonna try but, last i heard got2mnytoys had one but wasnt having very good luck with it. maybe you can ask him if he ever got the bugs out of it. i would go with the polks for shure, i tried another brand but they sounded worse than stock. i was trying to do it cheaper but ended up going with the polks anyway and really like them, but, you can only get so much out of a 4 inch speaker. if you do it i would put in the boom mats and base blockers in since you will allready have it apart, every little bit helps.
  #14
Old 02-25-2010, 06:21 PM
Bummer's Avatar
Bummer Bummer is offline
2006 RSV
Bummer has a Profile Picture
Supporting Member
Default
The biggest problem with the Polks is that they can handle a lot more wattage than the stock speakers, so the stock amp has a bit of trouble driving them. My current stereo related quest is to find an amp that will fit where the cassette goes. Something around 60 watts per channel. That way the stock stereo acts as a pre-amp with the power amp doing the work. This should not only increase the amount of sound out of the speakers, but keep the stock stereo lower in its range, yielding cleaner sound.
The combinations of Polk speakers (400 series then) and an Alpine power amp worked great on my First Gen. It didn't have a CB so I used that space for the power amp. Todays amps are much bigger so it's become more of a problem to find a place to put one. Luckily the cassette has volunteered to live in the basement to make space for an amp. Now all I have to do is find one that fits.
__________________
Steve
  #15
Old 02-25-2010, 06:52 PM
2009 Venture-S
Default
Just for curiosity sake...and from a lay person (so speak in beginners english)...
How many channels
How many Watts
Maximum dimensions
Power requirements
Could you provide that information.
Also..would the dimensions you provide be ONLY for the Cassette Deck bay or would you consider mounting in other locations?
Also...would it be possible to connect the stock system directly to the amp and run the amp that way (see I told you I was a layperson).
Thanks for any info...maybe if enough of us look...someone might find something.
Wally
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
gps and fm stereo tonyc Watering Hole 0 06-05-2009 09:20 PM
stereo upgrade javaventure General Tech Talk 1 07-22-2008 06:07 AM
Stereo Rear Speaker Upgrade? Pilot Watering Hole 16 01-17-2008 04:25 PM
2nd Gen Stereo Kit jryan Second Generation Venture Tech Talk 5 12-25-2007 07:45 PM
Stereo question CrazyHorse First Generation Venture Tech Talk 3 09-11-2007 09:50 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
