VentureRider.Org Motorcycle Gear
Home Venture History VR Members Map Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > GPS, Audio, Electronics
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 11,011 Entries 0
Members Entries
Threads 45,566 Reviews 0
Threads Reviews
Posts 537,439 Polls 30
Posts Polls
Content 0 Files 0
Content Files
Links 62 Ads 0
Links Ads
More...
  #1
Old 09-23-2009, 12:58 PM
Goofeychuck Goofeychuck is offline
Default just got my headsets help!
How can I tell if the cb works? I can hear them.
  #2
Old 09-23-2009, 01:28 PM
LilBeaver's Avatar
LilBeaver LilBeaver is offline
2001 RSV
LilBeaver has a Profile Picture
Supporting Member
Default
Get on the expressway, tune to a channel with someone on it (I use 19) and politely ask for a radio check.
__________________
Drive as if everyone is out to kill you... Because they are!
"The best alarm clock is sunshine on chrome"; "Most motorcycle problems are caused by the nut that connects the handlebars to the saddle"
- Provinces/States "Ventured" (or winged through)
  #3
Old 09-23-2009, 01:33 PM
gibvel's Avatar
gibvel gibvel is offline
99 RSV & 96 XV1100
Supporting Member
Default
1st, before keying up the mic., check to make sure that the antenna with the big black "load" in the middle is one the left side (when sitting on the bike) of the bike and the wire is running to the black box under the trunk.
Then do what LilBeaver said. Unless you know a CB operator somewhere around you. I have a handheld so I can check. Maybe go to a truck stop. I'm sure the people in the truck stop would have a CB they wouldn't mind helping you check yours with.
  #4
Old 09-23-2009, 09:25 PM
Sideoftheroad Sideoftheroad is offline
'99 2nd Gen
Sideoftheroad has a Profile Picture
Supporting Member
Default
Just a curiosity question. Does it make a difference if the cb antenna is on the left or right? When you are riding the antenna height is the same.
  #5
Old 09-23-2009, 09:29 PM
LilBeaver's Avatar
2001 RSV
Supporting Member
Default
Quote:
As long as the antenna wires run to the appropriate units, no, it does not matter. The antenna with the black deal in the middle needs to go to the CB box under the trunk and the AM/FM antenna (without the black deal in the middle) should have a wire that runs up front to the radio amplifier box.
__________________
  #6
Old 09-23-2009, 10:01 PM
Freebird's Avatar
Freebird Freebird is offline
ADMIN - 1999 RSV
Freebird has a Profile Picture
Supporting Member
Default
If your antennas are on the wrong side, they are most likely NOT going to the correct units as the stock cable from the CB would not reach the unit if it's mounted on the wrong side.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
headsets painterman67 GPS, Audio, Electronics 6 07-17-2009 01:30 PM
what headsets to look for????????????? painterman67 GPS, Audio, Electronics 4 06-21-2009 01:52 PM
IMC Headsets Ken Parker GPS, Audio, Electronics 1 06-11-2008 01:26 PM
Use of headsets in USA 1154 GPS, Audio, Electronics 4 05-26-2008 08:51 PM
Headsets Ramblingman General Tech Talk 9 08-24-2006 09:24 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
