VentureRider.Org RoadRunner Magazine
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > Royal Star and Royal Star Tour Deluxe Tech Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,769 Entries 0
Members Entries
Threads 52,391 Reviews 0
Threads Reviews
Posts 624,123 Polls 46
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 04-27-2009, 03:33 PM
RSTD RSTD is offline
Default Spark plug change
How do you change the spark plugs on a 2006 RSTD?
  #2
Old 04-27-2009, 04:10 PM
Eck's Avatar
Eck Eck is offline
Moderator - 2002 Goldwing
Eck has a Profile Picture
Supporting Member
Default
  1. Remove the gas tank
  2. Remove the two forward engine dog bones under the forward side of the gas tank
Now you can get to the front ones.
  • The rear ones I removed the drivers seat and made sure I had all the access room I needed.
  #3
Old 04-27-2009, 04:33 PM
SilvrT's Avatar
SilvrT SilvrT is offline
2013 Victory CCT
SilvrT has a Profile Picture
Supporting Member
Default
Quote:
ummmmmmm... the same way you change 'em on a 2005RSTD....
__________________
( Life's a Venture on my Victory! )
"Courage is the discovery that you may not win, and trying when you know you can lose."
  #4
Old 04-27-2009, 09:31 PM
RandyR's Avatar
RandyR RandyR is offline
2008 RSTD
RandyR has a Profile Picture
Supporting Member
Default
While we are on this topic. The owners maintenance schedule calls for changing spark plugs every year or 8,000 miles. That seems to be very soon/often.
So I am wondering what other riders are really doing in this regard, and what type plugs seek to work best. I've usually used NGKs in previous bikes.
  #5
Old 04-28-2009, 11:00 AM
Chinto Chinto is offline
06 Royal Star Venture
Default
I changed my plugs for the first time this past winter at 16,000 on my 06 RSV. I am sure the plugs could have gone a lot more. I agree the 8,000 mile recommendation is wasteful especially with what you must do to get them. Since the stock plug (NGK) worked very well I simply replaced with the same plug. I bought them however at the local NAPA store instead of at the dealer. Much cheaper. Since I had the tank off for other 16,000 mile maintenance work it made sense to change the plugs at the time.
  #6
Old 04-28-2009, 11:09 AM
similost similost is offline
Default
I got 20,000 miles on the set of platinums in my Roadstar.. I check them every now and then.. they still look good, and the bike runs great... why trash what still looks to be in good condition and works great?
  #7
Old 01-17-2010, 03:12 PM
Jethroish Jethroish is offline
Jethroish has a Profile Picture
Default
I had to dismount the rear brake fluid resevior to get the dogbone off the right side. Maybe I would not have needed to if I wanted to use a regular allen wrench, but I was using an allen socket.
  #8
Old 01-17-2010, 03:40 PM
V7Goose's Avatar
V7Goose V7Goose is offline
Admin/Mod - 2005 RSV
V7Goose has a Profile Picture
Supporting Member
Location: Find V7Goose on Google Maps! Ruidoso area, NM
Cool 8,000 miles seems too often
I can't say why Yamahaha says to change the plugs every 8,000 miles, as that seems way too often for me, too. My personal preference is to use standard plugs and change them somewhere between 16,000 and 25,000 miles (I do not think the exact interval is important).
If you use platinum or iridium plugs, you should be able to get a minimum of 50,000 between changes, and possibly up to 100,000. The extended change interval is the ONLY benefit from those expensive plugs. I personally find changing the plugs very simple, and I prefer to change them on a regular basis so I can observe the way the engine is running; that is why I do not waste money on special plugs.
Goose
__________________
V7Goose - Patriot Guard Rider
Venture Riders meet on Channel 29!
Iron Horses in the stable: 05 RSV QuickSilver, 79 Guzzi G5 LAPD, 75 Guzzi Eldorado Police, 73 Guzzi Ambassador/hack
  #9
Old 01-17-2010, 04:09 PM
dave_wells's Avatar
dave_wells dave_wells is offline
06 RSTD / 2000 RSV
dave_wells has a Profile Picture
Supporting Member
Location: Find dave_wells on Google Maps! Canal Winchester
Default Try this b4 removing tank
No need to remove the tank
I change my plugs ever spring
1 --- Remove the seat
2 --- Unbolt the remove the 3 bolts holding the tank on
3 --- fold up a towel put it up between the frame and the tank
this will give you clearance to remove the front mounts and
Then you can remove the plugs
I usually blow out any debris that may into the plug hole b4 pulling the plugs
In the pictures I used cut tennis balls.
Dave
__________________
Dave Wells
Canal Winchester Ohio
https://www.facebook.com/dave.wells.1694
Once in a while you get shown the light, in the strangest of places if you look at it right
Reply
Tags
spark plug rstd
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
spark plug changes? painterman67 General Tech Talk 16 10-16-2008 06:49 PM
Need some spark plug boot help Thainglo First Generation Venture Tech Talk 13 09-09-2008 06:06 PM
No Spark on plug wires shadow First Generation Venture Tech Talk 10 08-10-2008 08:16 PM
Correct spark plug...? rwalker First Generation Venture Tech Talk 2 07-26-2008 09:07 PM
Spark Plug Change Interval awsmsrv General Tech Talk 2 04-21-2007 12:16 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
