VentureRider.Org Cruiser Customizing
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > Royal Star and Royal Star Tour Deluxe Tech Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,847 Entries 0
Members Entries
Threads 52,693 Reviews 0
Threads Reviews
Posts 627,893 Polls 46
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 04-05-2009, 04:35 PM
cableguy cableguy is offline
Default How do you bleed the clutch line on a 96 royal star
Just kind of wondering since i can't find a bleed spot or maybe i'm just missing it. Little help for a newbie
  #2
Old 04-05-2009, 05:05 PM
Squeeze's Avatar
Squeeze Squeeze is offline
'93 VR, '09 VMAX, '99Vmax
Supporting Member
Location: Find Squeeze on Google Maps! Stuttgart, Germany
Default
Take a Look beneath the left rear Cylinder, there's a square shaped rubber Part which covers the Bleeder Valve.
__________________
Life's too short to have bad Drinks ....
  #3
Old 04-05-2009, 09:00 PM
tazmocycle's Avatar
tazmocycle tazmocycle is offline
Supporting Member
tazmocycle has a Profile Picture
Supporting Member
Location: Find tazmocycle on Google Maps! montevallo, AL
Default
some have trouble getting the clutch bled right. you can go to the auto parts store and buy the bleeder kit that has a hand pump, bottle and hoses to bleed the clutch and brake a lot easier. you hook the pump on the bleeder and open it, then you start pumping, as the level in the resovior goes down you add new fluid till you get new fluid at the bleeder. if you hand bleed it, you may have to let it set overnight so the air works out. good luck on doing it.
  #4
Old 05-20-2012, 02:40 PM
candymut candymut is offline
Lightbulb re bleeding clutch
Quote:
I also need to know the location to bleed the clutch due to drag (it was fine a week ago but has been standing).
I have looked at the engine and can see a lot of things but i am very unsure as to the location..any chance of a photo ? as i do not have the service manual...Yet.
Thanks.
  #5
Old 05-22-2012, 09:22 AM
joboo's Avatar
joboo joboo is offline
96 RSTC
joboo has a Profile Picture
Supporting Member
Default
There are lots of posts on clutch bleeding so I will leave you to do a little research, I have posted 2 pics even though the explanation is pretty clear and there is really only one rubber cover behind the rear cylinder. If you follow the lines down from the the master cylinder under the bike they attach to the slave cylinder and the bleeder is on top of that. To make the job easier remove the fins from the rear cylinder, it allows the rubber cover to come right off and gives the access to attach tubing. The pic shows the rubber cover lifted but held by the fins. Didn't know you Brits had such good taste in bikes!
__________________
81 XS Venturer (sold)
96 RSTC
  #6
Old 05-23-2012, 03:01 PM
ToyOdie's Avatar
ToyOdie ToyOdie is offline
97 Royal Star Tour Deluxe
ToyOdie has a Profile Picture
Supporting Member
Default
I made the job much easier by installing a Speed Bleeder on the clutch at the same time I installed them on the breaks.
__________________
Stop complaining and start riding!!!
  #7
Old 05-23-2012, 11:54 PM
bikenut's Avatar
bikenut bikenut is offline
86 Ven & 06 RSV
Supporting Member
Default
When I bleed Brakes or clutches, I always suck out all that is in the masters cyl first and replace with new fluid. Then I hook up my home made bleeder that works great for me.
This home made bleeder is a clear plastic jar with a led on it. I drilled a hole in the top of the led for a hose to go thru tight and is the right size to fit the bleeders on the bike. You push the hose thru the led and to the bottom of the jar. Before closing the led put about 1/2 " brake fluid in the jar so the hose is under the fluid all the time.
Now hook the hose to the bleeder on the bike, Open the bleeder up and leave it open and then all you have to do is pump the lever on the handle bars or foot lever slowly and keep adding new fluid in the master until clear brake fluid comes out in the jar. Once you see clear brake fluid coming in the jar with no air bubbles coming out , you close the bleeder and you are done.
With this home made bleeder air can not be suck into the bleeder when you are pumping the lever because the hose is in the fluid in the jar.
Give it a try it makes life very easy when you are alone workng on a bike by yourself.
Hope this helped a little
Keep the rubber side down
__________________
Bikenut
KEITH'S MOTORCYCLE SHOP
1986 Yamaha Venture Trike & 2006 Royal Star Venture
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
clutch bleed chollahan Second Generation Venture Tech Talk 3 05-16-2008 06:31 PM
HELP! Clutch Bleed? T.J. Second Generation Venture Tech Talk 7 05-05-2008 07:37 AM
how do i bleed the clutch clay18 Watering Hole 7 02-12-2008 12:24 AM
Need help with brake bleed on 05 V-Star duke General Tech Talk 3 09-05-2007 08:35 PM
Clutch won't bleed. 6pak First Generation Venture Tech Talk 3 08-20-2007 12:01 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
