VentureRider.Org Jake Wilson
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Technical Library - Read Only > Second Gen and Royal Star Technical Library - READ ONLY! > Computer, Lights, Horns, Other Electrical
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,199 Entries 0
Members Entries
Threads 50,086 Reviews 0
Threads Reviews
Posts 595,602 Polls 44
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 02-20-2009, 09:11 AM
Freebird's Avatar
Freebird Freebird is offline
ADMIN - 2013 Road Glide Ultra
Freebird has a Profile Picture
Supporting Member
Default Ignition Switch Wiring Failure
Ignition Switch Failure
A big thanks to Eck Nace for the excellent write-up
Clicking on the pictures will show a larger version.
For those of you who have not had ignition switch failure I recommend that you check this connector as soon as possible.
This is the connector for the Red Hot wire and the Brown & Blue wire that comes from the ignition switch located under the fuel tank.
Luckily, I just happen to “turn” the connector upside down while installing the ignition switch by pass mod in the case of ignition switch failure.
View of ignition switch connector under fuel tank.
This is the connector for the RED wire and the Brown/Blue wire
View looking down at ignition switch wire connectors under fuel tank.
Note: The two wires that you see with RED TAPE are the two wires used to by pass the ignition switch. One of them is the RED hot wire and the other is the Brown/Blue wire.
Mental note: When splicing into the Red wire and Brown/ Blue wires, it is highly recommended that you make your split connection on the “aft” end of both connectors. This way if you ever DO have to remove the ignition switch, you can still unplug the two connectors with out having to cut the two by-pass wires again.
Also, as shown in this picture, if the connection on the brown/blue wire did happen to burn up and where I lost connection, I would STILL be able to use the ignition by-pass switch I installed to start and run the bike.
After I cut the burnt connector out, I installed this connector in its place.
Please note: Only (2) wires go thru this new rubber sealed connector. The RED hot wire and the Brown / Blue wire which both go to the ignition switch. The black wire may LOOK like it goes through this new connector but it does not.
Photo of removed burnt connector
This photo is to show the location of the ignition by-pass switch installed in the case of ignition switch failure.
I wanted the by-pass switch located in a convenient location, where I do not have to get off the bike if the stock ignition switch fails.
__________________
The Following User Says Thank You to Freebird For This Useful Post:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ignition Switch frankc Second Generation Venture Tech Talk 24 11-24-2009 09:15 PM
Ignition Switch r12guy Second Generation Venture Tech Talk 3 09-02-2008 09:39 PM
Ignition switch or other?????? Red1 Second Generation Venture Tech Talk 11 06-20-2008 08:10 AM
Ignition Switch TEW47 Watering Hole 3 03-17-2008 05:20 AM
Ignition switch removal Stanman First Generation Venture Tech Talk 11 07-25-2007 10:11 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
