VentureRider.Org RoadRunner Magazine
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Tech Talk > General Tech Talk
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,658 Entries 0
Members Entries
Threads 52,067 Reviews 0
Threads Reviews
Posts 619,987 Polls 45
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 09-02-2008, 04:14 PM
Pappa Bear Pappa Bear is offline
Location: Find Pappa Bear on Google Maps! Castalia, O- H- I- O
Default V Star oil leak
A friend at work picked up a 2001 V Star 1100. It has a small oil leak on the front of the motor! Is this a common problem with these motors? The leak looks like it might be coming from a small cover behind the front exhaust pipe, the cover looks to be round with 2 Allen bolts on either side to tighten. Does anyone know what hat cover is for? Thanks for the help
  #2
Old 09-02-2008, 04:26 PM
got2mnytoys got2mnytoys is offline
05 midnight venture
Default
It sounds like the cover for the oil filter there is a little o-ring in there that gets worn or pinched sometimes, have to drop the header pipe to change the oil filter and replace that o-ring they sale a filter relocate kit .
  #3
Old 09-02-2008, 05:15 PM
Default
the cover I'm talking of straight behind the front tire and only about an inch across. Where is the oil filter located at on his bike?
  #4
Old 09-02-2008, 05:45 PM
05 midnight venture
Default
the oil filter is on the right side down low where the front exhaust pipe crosses the crankcase,if somebody don't answer this before I go by the storage building I"ll look on one of mine but of the 3, I have never had a leak anywhere except the oil filter o-ring. Is it on the cylinder head or the crankcase down below the exhaust , all the covers have little o-rings.
  #5
Old 09-02-2008, 05:49 PM
pegscraper's Avatar
pegscraper pegscraper is offline
'96 Royal Star
pegscraper has a Profile Picture
Default
The oil filter is in the lower ride side, behind a cover. The exhaust pipe has to be removed to get to it. PIA. Crummy design. But I'll tell you, I can remove the exhaust pipe a whole lot of times for what those oil filter relocation kits cost.
My wife rides one of these bikes, so I went out to have a look. I've never noticed that little cover in there. I have no idea what it's for. I couldn't even find anything about it in the shop manual. A good way to find out is to take it off and see what's behind it. Maybe the cam chain? I don't know. If that's where the leak is coming from, it needs a new gasket or O ring anyway.
  #6
Old 09-02-2008, 08:19 PM
frankc frankc is offline
Supporting Member
Smile Oil leak
The cover behind the front tire with the 2 allen screws holding it on, is the cover for the lifter adjustment. i believe its chrome. Remove the cover and you'll see the valve spring and rocker arm. This is where you make the valve adjustment. The cover has a rubber type gasket around it. You can purchase them from your Yamaha dealer. Replace the rubber gasket and your problem is over. Once you remove the cover, it will all make sence. Good Luck!
  #7
Old 09-02-2008, 09:54 PM
Default
thanks for the replies everyone, I'm sure it will ease his mind having a little more knowledge about it
  #8
Old 09-03-2008, 06:45 AM
Seaking Seaking is offline
Supporting Member
Seaking has a Profile Picture
Supporting Member
Default
Quote:
The cover is chromed and oval shaped? That's the adjuster access panel.. and be gentle with the screws, they can strip out easy.. which is a pain if you adjust the valves a lot.. ; )
__________________
  #9
Old 09-03-2008, 06:22 PM
Default
No, the cover is black and round shaped and is on the lower half of the cylinder, if your not looking for it you will look right past it. I stopped at his place today after work, he said he just got done lookin at it and the bolt on the one side was finger loose! He snugged them back down and was gonna take it for a spin later to see if that was the leak. The dealer said the cover was a tension adjustment cover, and a new rubber gasket was about a buck 50. I'll let ya know how it turns out.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gas Leak Poco Red Second Generation Venture Tech Talk 4 11-02-2008 06:55 AM
To Leak or Not to Leak, That is the Question. igya First Generation Venture Tech Talk 9 10-08-2008 01:41 PM
Gas leak? Help! DNBoll Watering Hole 7 05-24-2008 12:50 AM
Gas leak Help moritz1 Royal Star and Royal Star Tour Deluxe Tech Talk 2 09-19-2006 06:13 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
