VentureRider.Org Jake Wilson
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > General Discussion > Watering Hole
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,199 Entries 0
Members Entries
Threads 50,086 Reviews 0
Threads Reviews
Posts 595,602 Polls 44
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 08-14-2008, 09:18 AM
PGunn's Avatar
PGunn PGunn is offline
2006 Black Cherry Venture
PGunn has a Profile Picture
Supporting Member
Default motorcycle trailer swivel hitch coupler
Has anyone tried one of these yet?
http://cgi.ebay.com/ebaymotors/motor...spagenameZWDVW
Looks like a good idea and with the trailer weight being low at 500lbs the only issue I can see is after a while the pin or the mount wearing out. I think the only thing I would add is some kind of fill under the pin to keep it from rattling when not in use.
  #2
Old 08-14-2008, 09:27 AM
Leadwolf56's Avatar
Leadwolf56 Leadwolf56 is offline
06 RSV " Midnite Cherri"
Leadwolf56 has a Profile Picture
Supporting Member
Default
Quote:
http://cgi.ebay.com/ebaymotors/motorcycle-trailer-swivel-hitch-coupler-goldwing-CHROME_W0QQcmdZViewItemQQcategoryZ33653QQihZ016QQi temZ260273626629QQrdZ1QQsspagenameZWDVW
Do not buy this! I bought one in June, then they "recalled" them because one fell apart on someone. They refunded my money and did not want the item back, I still have it. If you welded the pin in place or put a longer pin with cotter pins on it it might be alright. It was sold before by EZhitches, now I see it's under a different name.
__________________
Kevin
  #3
Old 08-14-2008, 10:03 AM
PGunn's Avatar
Supporting Member
Default
Ok thats all I need to hear... Thanks!!!
  #4
Old 08-14-2008, 10:17 AM
Schlepporello Schlepporello is offline
Default
Maybe I'm wrong, having never pulled a trailer with a bike before, but I fail to see the neccessity of having a ball pivot in this fashion to begin with. I've pulled trailers of various shapes and sizes professionally for the last 20 years. It has been my experience that the ball already pivots to a certain degree within the hitch, that's why it's round. Surely with a standard rigid ball setup there is enough "play" for a rider to still be able to lean into turns half way comfortably. Am I wrong on this?
  #5
Old 08-14-2008, 10:36 AM
Tom's Avatar
Tom Tom is offline
2012 Polaris Ranger XP800
Tom has a Profile Picture
Default
Quote:
I do not ride real aggressive but when by myself and pulling my trailer I lean WAYYYY over in curves and it has never been a problem with the standard ball hitch. That being said I try and not make a habit of it as I realize if a deer runs out in front of me pulling the trailer especially in a hard curve I have 0 chance of getting it stopped.
  #6
Old 08-14-2008, 10:43 AM
Default
That's what I thought. I knew that by design the ball had to rotate within the hitch to a point. If it didn't, the hitch would pop loose every time you hit a dip. Not only does the hitch have to allow for rotation front and back, but on a bike would have to allow from side to side as well.
  #7
Old 08-14-2008, 11:56 AM
Bob Myers's Avatar
Bob Myers Bob Myers is online now
Sittin in the Comfy Chair
Bob Myers has a Profile Picture
Supporting Member
Default
As you stated the hitch is to rotate some on the ball, what is to keep that thing from flopping back and forth at will and causing the trailer to "wag the dog"?
__________________
95 Glodwing/Champion sidecar
86 1300 Royale'
Iron Butt Association #34911
N4RWM
  #8
Old 08-14-2008, 12:42 PM
funrider's Avatar
funrider funrider is offline
Location: Find funrider on Google Maps! Lidgerwood, ND.
Default if you drop
your bike, like in a parking lot or at a sudden bad stop, the standard hitch will probably not allow for enough movement to avoid doing damage to the trailer hitch or to the trailer tong. Trailer setting upright and the bike on its side, is more than what would be able to move with just a standard connection. As has been stated many times, it is not if you will drop your bike, it is when.
  #9
Old 08-14-2008, 01:02 PM
PGunn's Avatar
Supporting Member
Default
Well having my bike fall off the kick stand once while idleing in the driveway, yea I was in a hurry and "thought" it would be ok to do, I can see why you would want it to rotate more then the ball will allow. And the little stunt of leaving it idleing in the driveway well I now have a new outer faring shell and chrome trim and the rest of the "minor" damage is going to be slowly replaced.
  #10
Old 08-14-2008, 03:09 PM
Dandy1
Guest
Default
Having pulled a trailer for several years now I highly recommend a swivel coupler. You can lean over more then a standard coupler will allow and it will actually keep you from leaning over far enough to be able to make your turn. In other words my hitch has bottomed out on the ball before. Also If for some reason your bike falls over it will either screw up your hitch or your trailer tongue or both. You can buy a swivel coupler from Noesho trailers in Mo. for about $80.
Ride Safe!
  #11
Old 08-14-2008, 04:55 PM
Leadwolf56's Avatar
Supporting Member
Default
I would agree that having a swivel coupler is a must. I did pull my camper to the Canada rally without one and it did ok but if the bike would go over it would either tip the trailer over or damage the hitch and tongue. I'll be buying the regular swivel coupler for it.
__________________
Kevin
  #12
Old 08-14-2008, 05:01 PM
VTirelli's Avatar
VTirelli VTirelli is offline
VTirelli has a Profile Picture
Location: Find VTirelli on Google Maps! Mattituck, New York
Default
I've pulled my trailer quite a bit, first trip out, I actually bottomed out the ball to the hitch and almost got pushed into the shoulder of the oncoming lane. As hard as I tried, I simply could not get the bike to lean far enough to turn all the way through. This was at about 35 MPH in a 60 or 70 degree turn. Not overly aggressive but everyone riding behind me thought I was losing it. Luck was with me and I was able to pull out of it.
The day we got back, I ordered my swivel hitch and will NOT pull a trailer without it.
  #13
Old 08-14-2008, 05:18 PM
Brake Pad's Avatar
Brake Pad Brake Pad is offline
2012 Honda Goldwing
Brake Pad has a Profile Picture
Supporting Member
Location: Find Brake Pad on Google Maps! 4820 55th st. Vero Beach, Fl 32967
Default
swivel hitch is the way to go. I can lay my bike over in turns like I'm riding a rice rocket
__________________
  #14
Old 08-14-2008, 07:08 PM
BuckShot's Avatar
BuckShot BuckShot is offline
86 VR & 09 Ultra Classic
BuckShot has a Profile Picture
Supporting Member
Default
Started pulling trailer in 86. Just before I started, I talked with a guy who actually watched his friends bike get pulled over in a hard curve in the rockies. He said it was not a pretty sight and that the outside tire on the trailer lifted off the road and continued to lift higher the more his friend leaned into the curve,untill the bike went down. He said they just misjudged the curve, but was not going overly fast. His friend just leaned the bike over more than the hitch could swivel on the ball. Remember,this all took place before cell phone's and help was a long time coming. They were fortunate that no-one was hurt seriously, just a lot of road rash. Ruined a nice vacation though. I had a mishap one time where I had to lean the bike over hard in a hairpin turn to miss a large pothole in the middle of my lane on a 2 lane state route. The trailer tire hit the pothole and my friend said that tire bounced and went about 3 foot in the air and when it came down the whole trailer(both wheels) came off the road about 2 foot and bounced again and again, each time leaveing the road,but at smaller heights untill everything settled down. I felt the trailer bounce,but did not know how bad untill we stopped for gas. He said it scared him half to death. I credit the swivel hitch. I would not pull without one.
__________________
Dream as if you'll live forever. Live as if you'll die today. (James Dean)
  #15
Old 08-14-2008, 09:06 PM
bryan52577's Avatar
bryan52577 bryan52577 is offline
05 RSV, 97 Spirit 1100
bryan52577 has a Profile Picture
Supporting Member
Default Darn straight!!
I have pulled a trailer for about 14 years now and with 3 different bikes. I would tell anyone going to purchase a hitch for a bike to get a "swivel hitch" or a "narrow shank ball".
I have used the narrow shanked ball and on each bike and (with the help of a friend) lay the bike over to make darn sure I can corner and not have the trailer hold me up! If it ever did I would replace my narrow shanked ball with a swivel hitch before I ever pulled the trailer.
That narrow shaft or swivel hitch will save your life.
__________________
Idiot out Wondering Around
So many places to go, so little time.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
? about a 86 trailer hitch tufftom4 Watering Hole 3 12-12-2008 04:21 AM
Trailer Hitch tufftom4 Watering Hole 3 10-27-2008 10:24 AM
Trailer Hitch Seaking Second Generation Venture Tech Talk 18 08-13-2008 06:40 AM
Swivel hitch for a Piggy Backer Spitfire0049 Trailer Talk 14 05-13-2008 09:36 AM
Neosho swivel hitch? sarges46 Trailer Talk 13 11-29-2007 10:12 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
