RICK vOBIS Posted August 20, 2014 Share #1 Posted August 20, 2014 Hi Guys, I am asking help for a 2002 RSV Midnight. The problem happened like this. The bike was running very well when there was a fluctuation of the headlight strength. The Voltage regulator was replaced with a new voltage regulator and the problem disappeared and the bike was all good. After a few months of riding the new regulator caught fire burned and also burned the plug on the wiring harness. The harness was repaired (new plug spliced into the harness), 2nd new voltage regulator installed and compete check of charging system completed. All tests were in acceptable ranges. After almost a complete riding season the voltage regulator once again blew the main 30A fuse and melted (this time without burining the wiring harness). (The fuse blew first and the regulator was checked and was found to be warn). A new fuse was put into the fuse holder with the ignition OFF. The fuse blew again and the regulator then melted. I am at a loss. Could this be caused by a bad ignition switch. I do not want to just install another regulator and get stuck (again) on the road. Any and all help would be greatly appreciated. Link to comment Share on other sites More sharing options...
bongobobny Posted August 20, 2014 Share #2 Posted August 20, 2014 By any chance was the regulator a cheap Chinese regulator? They are a waste of money. You should check your stator for a short to ground. I kind of doubt the ignition switch is the culprit... Link to comment Share on other sites More sharing options...
etcswjoe Posted August 20, 2014 Share #3 Posted August 20, 2014 Short would be my guess also. Link to comment Share on other sites More sharing options...
RICK vOBIS Posted August 25, 2014 Author Share #4 Posted August 25, 2014 Thanks guys, Im going to check for a ground and yes it was a cheap regulator off of e bay Link to comment Share on other sites More sharing options...
