jimc1031 Posted August 15, 2012 Share #1 Posted August 15, 2012 Hi Venture Friends I am a newbie to Venture rider I just bought a 1987 Venture 1300_ I bought it cheap and of course Has its problems . All the diaphyrams in carbs are busted no problems with handling this problems. MY BIG CONCERN IS THE TRANSMISSION-'THE REAR WHEEL WAS JUST STUCK ON . I REMOVE WHEEL TO TEST DIFFERENTIAL ETC--FOUND LOTS OF PLAY IN TRANS. I COULD MOVE DRIVE SHAFT APPROX 90 degrees back and forth except for 5th gear in which was nor mal I drain oil no signs of metal in oil . My question what should back lash be when rotating driveshaft- WHY IS IT SO MUCH PLAY IN 1 thru 4 but. 5th to me is nornmal Thanks. Jim C. Carson City. Nevada:bacp Link to comment Share on other sites More sharing options...
Squeeze Posted August 25, 2012 Share #2 Posted August 25, 2012 As long as you don't hear any bad Sounds from it, the Play seems to be normal for me. Link to comment Share on other sites More sharing options...
