ediddy Posted July 17, 2014 Share #1 Posted July 17, 2014 I posted previously about my friend that has an 07 venture. He had to have the selenoid switch replaced. Got the bike home and now no sound comes out of the speakers. Split the fairing and cleaned and greased the connectors but still no sound. I read many old post about this problem but none gave the answer as to what corrected this. Anyone have any ideas? Link to comment Share on other sites More sharing options...
Neil86 Posted July 17, 2014 Share #2 Posted July 17, 2014 Have you checked that audio is set to SP (speakers) and not HP (headphones). Hopefully thats all the problem is....however... As I mentioned in your other thread...the starter cranking whenever the key is on issue can originate in the audio system and perhaps something has failed there now. Link to comment Share on other sites More sharing options...
ediddy Posted July 17, 2014 Author Share #3 Posted July 17, 2014 Hey Neil86, The problem with the bike starting without pressing the start button was the selenoid switch. It has been replaced but now there isn't any sound from the speakers. The first thing we checked was if the speaker was set to the external speakers and it is. But there isn't any sound using headsets either. Strange problem. Thanks for your reply. Link to comment Share on other sites More sharing options...
MikeWa Posted July 17, 2014 Share #4 Posted July 17, 2014 Ok due to my activities over the last couple of weeks I have misplaced my service manual. Last place I for sure saw it was in The Dalles. So this is from memory. There is a white rectangular plug under the fairing. Perhaps 24 pin. The speakers are routed through this plug not the round ones. Make sure it is fully seated. Mike Link to comment Share on other sites More sharing options...
Seaking Posted July 17, 2014 Share #5 Posted July 17, 2014 checked fuses behind lower right fairing? Link to comment Share on other sites More sharing options...
Neil86 Posted July 17, 2014 Share #6 Posted July 17, 2014 Don't be surprised if the amp has failed and was the cause of the starter problem is all I'm suggesting. I know the shop replaced the starter solenoid. Link to comment Share on other sites More sharing options...
MikeWa Posted July 18, 2014 Share #7 Posted July 18, 2014 What does the controller read when you turn the volume knob? Mike Link to comment Share on other sites More sharing options...
dacheedah Posted July 18, 2014 Share #8 Posted July 18, 2014 check the aux fuse on left side Link to comment Share on other sites More sharing options...
ediddy Posted July 22, 2014 Author Share #9 Posted July 22, 2014 My friend just called. The dealer has checked everything the yamaha service manual says to check and thinks it is the radio. The radio is $800.00 from yamaha. My friend asked if it isn't the radio can it be sent back. The service manager said no. Once you open the box and remove the radio it can't be returned. The dealer has a midnight 07 for sale and the service manager is going to remove the radio from it and put it in my friends 07 and see if it works. If so then they will know it is the radio. I don't believe it is but will find out. I think it's pretty crappy to tell you that you can't send a radio back if that is what they think is wrong. Yamaha ought to do better than that. Link to comment Share on other sites More sharing options...
ediddy Posted July 22, 2014 Author Share #10 Posted July 22, 2014 Also, when the radio is on and you touch the speakers they are warm. Is this normal? I'm talking about touching the speakers with the fairing removed. Link to comment Share on other sites More sharing options...
Neil86 Posted July 22, 2014 Share #11 Posted July 22, 2014 Have the dealer check the blue/white wire from the audio for grounding....if it grounds it cuts volume. Link to comment Share on other sites More sharing options...
rougeray Posted July 22, 2014 Share #12 Posted July 22, 2014 My friend just called. The dealer has checked everything the yamaha service manual says to check and thinks it is the radio. The radio is $800.00 from yamaha. My friend asked if it isn't the radio can it be sent back. The service manager said no. Once you open the box and remove the radio it can't be returned. The dealer has a midnight 07 for sale and the service manager is going to remove the radio from it and put it in my friends 07 and see if it works. If so then they will know it is the radio. I don't believe it is but will find out. I think it's pretty crappy to tell you that you can't send a radio back if that is what they think is wrong. Yamaha ought to do better than that. Hmm....would not go any further with this shop. They trouble shoot by changing parts. If you can afford it go for it. Link to comment Share on other sites More sharing options...
ediddy Posted July 23, 2014 Author Share #13 Posted July 23, 2014 As I mentioned in previous post, the dealer has an 07 venture for sale. He took the controller off the bike and installed it on my friends bike. Still no sound. The dealer then took the amp from the bike for sale and installed it on friends bike. All works good now. The sound is back. Bad news. A new amp from yamaha is $1,489.99. My friend had a harley and after riding my venture he sold the harley because it was so expensive to have any work done on it and bought a 07 venture. He is pretty disgusted with the venture now saying it's no different than the harley as far as expenses. Last summer he went out west and the shock went bad. Cost him almost $1,000 by the time he paid for the shock, overnight deliver and installation. I hope I never have something like this to happen. Link to comment Share on other sites More sharing options...
MikeWa Posted July 23, 2014 Share #14 Posted July 23, 2014 These things are available from Pinwall and others on E-bay for a much more reasonable price. And they are not very hard to install. Since the bike is running I don't see any urgency to getting the job done. Especially since I will bet the dealer will have to order the parts anyway. Mike Link to comment Share on other sites More sharing options...
RedRider Posted July 23, 2014 Share #15 Posted July 23, 2014 (edited) As I mentioned in previous post, the dealer has an 07 venture for sale. He took the controller off the bike and installed it on my friends bike. Still no sound. The dealer then took the amp from the bike for sale and installed it on friends bike. All works good now. The sound is back. Bad news. A new amp from yamaha is $1,489.99. My friend had a harley and after riding my venture he sold the harley because it was so expensive to have any work done on it and bought a 07 venture. He is pretty disgusted with the venture now saying it's no different than the harley as far as expenses. Last summer he went out west and the shock went bad. Cost him almost $1,000 by the time he paid for the shock, overnight deliver and installation. I hope I never have something like this to happen. That kind of money was spent because he didn't pay his $12 for VR.org. Pinwall Cycle to the rescue. $150.00 Oh, and FYI - Hagan Shocks replacement/upgrade - $400. Rebuildable. Usually in stock in the US. Edited July 23, 2014 by RedRider Link to comment Share on other sites More sharing options...
ediddy Posted July 23, 2014 Author Share #16 Posted July 23, 2014 The $12.00 for venturerider.org didn't have anything to do with it. I have posted several times regarding this issue and received no information that would have kept him from going to the dealer. There are amps on ebay for much less but he is afraid a used amp make not last. Link to comment Share on other sites More sharing options...
ediddy Posted July 23, 2014 Author Share #17 Posted July 23, 2014 Hey RedRider, The part you show from pinwall is the radio, not the amp. The amps on ebay run around $400.00. Link to comment Share on other sites More sharing options...
RedRider Posted July 23, 2014 Share #18 Posted July 23, 2014 Hey RedRider, The part you show from pinwall is the radio, not the amp. The amps on ebay run around $400.00. Upon further review, the part I was showing is the CB control. Hmmm. Here we are. In the manual it is referred to as the Radio Main Control Unit. On the Yamaha phish it is referred to as Amp, Power. This is the part that goes in the faring - correct? Again, at Pinwall Radio Main Control Unit also $150. RR P.S. I was just teasing with the $12 comment - kind of. Don't recall the issue coming up with your friend previously or I would have helped at the time. Yes, it must be frustrating to have a machine with a reputation for reliability cause such expensive problems. Link to comment Share on other sites More sharing options...
Neil86 Posted July 26, 2014 Share #19 Posted July 26, 2014 (edited) The p/n for the power amp for a 2007 is 4XY-88132-01-00 AMP. POWER Look at the sticker on the "Radio" Pinwall is selling....its the same unit. If your friend wants to go to the dealer and ask to see his old amp...compare to picture. Personally I would hate to buy a new $1400 unit and find out something else on the bike fried it. Edited July 26, 2014 by Neil86 Link to comment Share on other sites More sharing options...
