venturega Posted April 24, 2014 Share #1 Posted April 24, 2014 Anyone have issues with the operation of the new Dyna 3000? 2005 Venture was popping a little on decel and checked carbs, exhaust leaks, hoses and found nothing so decided to try the ignition module since some have said that stopped popping. Well popping is gone but now there is a hesitation when throttling up in first gear. No power issues and no hesitation when moving. It feels like the bike is choking when starting off and I have to rev it up to keep from stalling. This was not the case until I installed the Dyna 3000 this weekend. I did not modify the curve setting just installed with the default curve (curve 2). No dip switches on this one - it has the USB connection. Ralph Sent from my AT100 using Tapatalk Link to comment Share on other sites More sharing options...
Neil86 Posted April 24, 2014 Share #2 Posted April 24, 2014 Are you certain its firing all 4 cylinders? Link to comment Share on other sites More sharing options...
bongobobny Posted April 24, 2014 Share #3 Posted April 24, 2014 What exactly do you mean by you checked the carbs?? Did you sync them? Color tune them? Link to comment Share on other sites More sharing options...
venturega Posted April 24, 2014 Author Share #4 Posted April 24, 2014 I checked exhaust pipe temps at idle and all are getting hot. Link to comment Share on other sites More sharing options...
venturega Posted April 24, 2014 Author Share #5 Posted April 24, 2014 What exactly do you mean by you checked the carbs?? Did you sync them? Color tune them? Yes. Carbs were synced but I have not removed and cleaned. Bike has 70,000 miles so it can't be gummed up. I ride all winter. Link to comment Share on other sites More sharing options...
MikeWa Posted April 24, 2014 Share #6 Posted April 24, 2014 Yes I had a lot of problems with my Dyna 3000. My bike ran fine with the stock module and like crap with the Dyna. I sent it in to their service dept. twice and they just sent it back saying it was ok. I finally had it checked by the local Yamaha dealer and they confirmed the Dyna was bad. So I sent it to the president of Dyna with a note and never heard back. Mike Link to comment Share on other sites More sharing options...
Neil86 Posted April 24, 2014 Share #7 Posted April 24, 2014 Put the stock igniter back in...if the off idle issue goes away its the Dyna. Does the Dyna have any diagnostics available via the USB or is it strictly for changing the curve settings? Do you have a tachometer to show if idle speed is same with either igniter? Link to comment Share on other sites More sharing options...
bongobobny Posted April 24, 2014 Share #8 Posted April 24, 2014 OK next thing to check is the AIS for proper operation. If it is plugged that can cause popping.. Link to comment Share on other sites More sharing options...
scotta68 Posted April 25, 2014 Share #9 Posted April 25, 2014 Going to follow this one as I put mine in and after first ride, found the same issue... where this didn't exist with stock ECM Link to comment Share on other sites More sharing options...
First_N_Last Posted April 25, 2014 Share #10 Posted April 25, 2014 Anyone have issues with the operation of the new Dyna 3000? 2005 Venture was popping a little on decel and checked carbs, exhaust leaks, hoses and found nothing so decided to try the ignition module since some have said that stopped popping. Well popping is gone but now there is a hesitation when throttling up in first gear. No power issues and no hesitation when moving. It feels like the bike is choking when starting off and I have to rev it up to keep from stalling. This was not the case until I installed the Dyna 3000 this weekend. I did not modify the curve setting just installed with the default curve (curve 2). No dip switches on this one - it has the USB connection. Ralph Sent from my AT100 using Tapatalk ---------------------------------------------------- Try a tank of premium - easy to try. Mine will do the same thing with 87 octane. The advance is high with the 3000. My bike is quiet enough to hear pinging. Try it? JB Link to comment Share on other sites More sharing options...
venturega Posted April 26, 2014 Author Share #11 Posted April 26, 2014 I was trying to avoid taking it back out. Battery box was a pain in the a$$ to remove. I tried the 93 octane and rode to work but still doesn't have the same spunk on throttle up in 1st gear. I may send something in to their tech services. If it continues I'll pull it out and see how the old one compares. Runs great outside of sluggish throttle response - like it lags when blipping the throttle. Sent from my AT100 using Tapatalk Link to comment Share on other sites More sharing options...
venturega Posted April 26, 2014 Author Share #12 Posted April 26, 2014 Put the stock igniter back in...if the off idle issue goes away its the Dyna. Does the Dyna have any diagnostics available via the USB or is it strictly for changing the curve settings? Do you have a tachometer to show if idle speed is same with either igniter? I believe it only has curve adjustments. No tach but turning up idle screw reduces the lag when throttling up. But it is idling too high when I do that. Sent from my AT100 using Tapatalk Link to comment Share on other sites More sharing options...
Neil86 Posted April 26, 2014 Share #13 Posted April 26, 2014 So is Dyna curve #1 stock settings.....did you try it set on 1? Link to comment Share on other sites More sharing options...
venturega Posted April 26, 2014 Author Share #14 Posted April 26, 2014 So is Dyna curve #1 stock settings.....did you try it set on 1? Have not tried the other curve. Think it said something about having engine mods before using the other curve so I wasn't going to try it. Busy the next week or so, so I am not going to get a chance to work on it for a couple of weeks. It rides fine just have to throttle up on take off. Link to comment Share on other sites More sharing options...
uncledj Posted April 26, 2014 Share #15 Posted April 26, 2014 Reading this thread gives me the feeling I should stay with the stock setup. Link to comment Share on other sites More sharing options...
bongobobny Posted April 26, 2014 Share #16 Posted April 26, 2014 I'm starting to think so too DJ! My interest was to improve the performance and economy to account for the extra weight of the Hannigan... Link to comment Share on other sites More sharing options...
Sylvester Posted April 26, 2014 Share #17 Posted April 26, 2014 I have the Dyna 3000 and have had no problems in 9-10 years. It is set on 2. Never needed jets or pipes. Still runs on 87 octane. Just gives me higher revs. Link to comment Share on other sites More sharing options...
First_N_Last Posted April 27, 2014 Share #18 Posted April 27, 2014 I have the Dyna 3000 and have had no problems in 9-10 years. It is set on 2. Never needed jets or pipes. Still runs on 87 octane. Just gives me higher revs. ------------------------ This is not the model you have. The USB model is different. It comes preset with a more aggressive tune & a rpm limit of 7,500. JB Link to comment Share on other sites More sharing options...
Neil86 Posted April 27, 2014 Share #19 Posted April 27, 2014 Isn't there a base setting that is close to stock on the timing but bumps the rev limiter? I thought DYNA didn't recommend the other settings on a stock bike. Link to comment Share on other sites More sharing options...
venturega Posted May 17, 2014 Author Share #20 Posted May 17, 2014 I removed the Dyna and installed the stock ignition module. The lag on throttle up goes away but the popping on decel comes right back. While I was in there I pulled carbs cleaned jets and resynced the carbs. I sent two emails over the past two weeks to DYNA about the throttle up issue but got no reply. I would suggest not buying one since customer service so far is non existent. I will try calling their 800 number next week. Any idea what could be causing the popping with stock ignition module. I have no exhaust leaks, clean carbs, no hoses cracked or leaking, AIS is plugged and has been that way for 7 years with no popping. Could it be coils or plug wires? What else can I check? Link to comment Share on other sites More sharing options...
Neil86 Posted May 17, 2014 Share #21 Posted May 17, 2014 Where is the AIS plugged...right at the exhaust ports? There were a bunch of Ventures around 2005 that had cracks on the exhaust at the Y joint where front and rear join. Link to comment Share on other sites More sharing options...
venturega Posted May 17, 2014 Author Share #22 Posted May 17, 2014 I put stoppers in both AIS lines and then reconnected the hoses. I pulled both exhaust pipes and checked the Y joint - no holes. I installed new gaskets when putting the exhaust back on. Link to comment Share on other sites More sharing options...
venturega Posted May 20, 2014 Author Share #23 Posted May 20, 2014 I called the Dyna people and got some help from the guy there. First off opening the software can be a problem if not opened as the administrator on the computer. Since I was having trouble at the low end RPM he had me change the low end advance as follows (using curve 2): 100 rpm from 3 to 5 800 rpm from 3 to 5 1500 rpm from 3 to 5 He thought these were the stock module numbers. This seemed to make a difference in the lagging throttle at low end rpm's but I only got to ride around the neighborhood a little while before Momma called me in. I am taking a long weekend ride so I am going to leave it alone while I'm ahead and play with it some more next week. Ralph Link to comment Share on other sites More sharing options...
scotta68 Posted May 23, 2014 Share #24 Posted May 23, 2014 Did this with mine... good adjustment, stumble is gone Link to comment Share on other sites More sharing options...
baylensman Posted May 23, 2014 Share #25 Posted May 23, 2014 The old DYNA was the single best mod to my 96 Royal star. Pipes, carbs, valve springs everything! This really perked the bike up, sorry to hear they are now USB instead of the dip switches. Link to comment Share on other sites More sharing options...
