rutman Posted July 13, 2014 Share #1 Posted July 13, 2014 06 rstd. This happened today all of a sudden with no warning. Coasting down my driveway coming in from my ride today, all of a sudden it seemed to start to lose power. engine started sputtering, kept feathering the throttle but it finally quit. Turning on the key I have power. When I hit the start switch I get a bzzt. sound if that makes since but the engine does not turn over. No warning signs of any kind before this happened. I need help. Link to comment Share on other sites More sharing options...
Freebird Posted July 13, 2014 Share #2 Posted July 13, 2014 I surely would check the battery first thing. Connections and make sure it is not dead. Link to comment Share on other sites More sharing options...
MikeWa Posted July 14, 2014 Share #3 Posted July 14, 2014 +1 check the battery and charging. Mike Link to comment Share on other sites More sharing options...
djh3 Posted July 14, 2014 Share #4 Posted July 14, 2014 Check your battery connections as mentioned. If you have extra stuff wired into make sure your OEM battery cables are first in line on top of battery posts, then whatever is added on top of those. At first I was thinking fuel pump. But if it wont turn over............ Let me know, I got an 07 RSV in the garage I'm troubleshooting a intermittent start problem. Sometimes it does, sometimes it dont. Link to comment Share on other sites More sharing options...
Sexagenarian Posted July 17, 2014 Share #5 Posted July 17, 2014 was it the battery connections? or did you have to start troubleshooting the starter relay, etc.? Curious minds want to know. Link to comment Share on other sites More sharing options...
dogman Posted July 17, 2014 Share #6 Posted July 17, 2014 Any chance it might be your fuel pump? Link to comment Share on other sites More sharing options...
djh3 Posted July 18, 2014 Share #7 Posted July 18, 2014 I think he said it wouldnt even turn over, so I doubt its fuel. sounds to familiar to what I have going on in the garage. Start with battery connections, power and ground. then your going to have to start to work your way thru the different switches etc in the system. Do you have a neutral light? Link to comment Share on other sites More sharing options...
rutman Posted July 19, 2014 Author Share #8 Posted July 19, 2014 UPDATE. Pulled the battery, got out the charger, hooked it up but it wouldn't hold a charge. I bought a gel battery at Advance. 310 cca $102 after my $10 discount. Put it in last night and bike cranks right up. Rainy weather is here in Spartanburg for the weekend so probably wont get to put on some miles till next week. Hope this takes care of the problem. Thanks for the advice and want to give a shoutout to Eck for his help. Link to comment Share on other sites More sharing options...
djh3 Posted July 19, 2014 Share #9 Posted July 19, 2014 Good place to start. If battery voltage is real low bike dont like to stay running as they need like 11.8 or something to fire the ECM. Link to comment Share on other sites More sharing options...
rutman Posted July 28, 2014 Author Share #10 Posted July 28, 2014 Another update. Went on first long ride since Installing battery. Stopped to fill up close to the house. Hit the start switch and all I got was buzzing. Done this 4-5 times then the bike started. Got home and same thing. Buzzing and would not start. Put battery on charger for awhile and it fired right up. Seems like during the course of riding; something is draining the battery. Really need some help on this one. Link to comment Share on other sites More sharing options...
djh3 Posted July 28, 2014 Share #11 Posted July 28, 2014 My suspicions lead me to think there is more at work here than battery troubles. Possibly, but if its killing the battery you will probably need to start looking at voltage regulator and stator. Link to comment Share on other sites More sharing options...
Neil86 Posted July 28, 2014 Share #12 Posted July 28, 2014 You need to do some voltage testing on the battery to prove/disprove thats the issue. Yes it could be the battery was discharged, and charging helped...or it could be its a hit and miss issue elsewhere....voltage testing while it is doing the no start will pinpoint it.. Link to comment Share on other sites More sharing options...
rutman Posted July 28, 2014 Author Share #13 Posted July 28, 2014 Will check battery voltage when I get home What should the voltage be? Should the bike be running when checking?. Can the regulator cause this? I dont even know what the regulator does or where it's at. Link to comment Share on other sites More sharing options...
Neil86 Posted July 28, 2014 Share #14 Posted July 28, 2014 (edited) A fully charged battery thats been sitting for an hour or so should have about 12.6 V. Then if the no start happens...retest battery voltage while pushing start button, see what it does. As for charging system, with the bike slightly above idle speed you should have voltage in the 13.5-14.5 V range. The rectifier regulator, rectifies the AC current your stator produces and makes it DC current so the bike systems can use it, and recharge your battery which also produces DC current. The regulator part of the RR controls the bike voltage from getting too high or low. Stock location for RR is in front of oil filter. Edited July 28, 2014 by Neil86 Link to comment Share on other sites More sharing options...
rutman Posted July 28, 2014 Author Share #15 Posted July 28, 2014 A fully charged battery thats been sitting for an hour or so should have about 12.6 V. Then if the no start happens...retest battery voltage while pushing start button, see what it does. As for charging system, with the bike slightly above idle speed you should have voltage in the 13.5-14.5 V range. The rectifier regulator, rectifies the AC current your stator produces and makes it DC current so the bike systems can use it, and recharge your battery which also produces DC current. The regulator part of the RR controls the bike voltage from getting too high or low. Stock location for RR is in front of oil filter. Voltage with bike parked, 12.9 Voltage with bike at slightly above idle, 12.5 Any advice. Link to comment Share on other sites More sharing options...
Pegasus1300 Posted July 28, 2014 Share #16 Posted July 28, 2014 Looks like you found the culprit. Link to comment Share on other sites More sharing options...
rutman Posted July 28, 2014 Author Share #17 Posted July 28, 2014 Looks like you found the culprit. Are you saying the culprit is this new gel battery that I just put in a couple weeks ago? Link to comment Share on other sites More sharing options...
M61A1MECH Posted July 29, 2014 Share #18 Posted July 29, 2014 If when the bike is running and you rev it up to around 2'000 RPM you do get an increase in voltage at the battery to something close to 13.5 or so then you have either a bad regulator (not letting voltage from the stator get thru to the charging system) or you have a bad stator (not making any AC voltage for the regulator to regulate). If you drop the regulator and disconnect the plug, with the bike running you can check for voltage between the circuits, if you have equal voltage ( something north of 16 volts) on all 3 possible combinations (1 to 2, 1 to 3, 2 to 3) then the stator is ok. The most likely candidate is the regulator, they are known for failing. You can pick up a used on off eBay for amour $35.00 . Good luck Link to comment Share on other sites More sharing options...
rutman Posted July 29, 2014 Author Share #19 Posted July 29, 2014 If when the bike is running and you rev it up to around 2'000 RPM you do get an increase in voltage at the battery to something close to 13.5 or so then you have either a bad regulator (not letting voltage from the stator get thru to the charging system) or you have a bad stator (not making any AC voltage for the regulator to regulate). If you drop the regulator and disconnect the plug, with the bike running you can check for voltage between the circuits, if you have equal voltage ( something north of 16 volts) on all 3 possible combinations (1 to 2, 1 to 3, 2 to 3) then the stator is ok. The most likely candidate is the regulator, they are known for failing. You can pick up a used on off eBay for amour $35.00 . Good luck When I checked it with the bike idled up, the voltage was 12.5? Link to comment Share on other sites More sharing options...
M61A1MECH Posted July 29, 2014 Share #20 Posted July 29, 2014 Ok, you either have a bad regulator or a bad stator, because the voltage with the bike running well above idle it should 13 +volts. Link to comment Share on other sites More sharing options...
Neil86 Posted July 29, 2014 Share #21 Posted July 29, 2014 (edited) It appears your charging system is not performing. So best go to the Tech section and follow the testing method. http://www.venturerider.org/forum/showthread.php?t=81297 even a bad connection could be causing the issue. Edited July 29, 2014 by Neil86 Link to comment Share on other sites More sharing options...
djh3 Posted July 29, 2014 Share #22 Posted July 29, 2014 Thats true on the connection. the connector because of the high voltage are kind of known for melting and corrosion. Link to comment Share on other sites More sharing options...
rutman Posted July 29, 2014 Author Share #23 Posted July 29, 2014 I was getting ready to test my R/R. Unbolted it from the frame and let it hang. Cranked bike and idled it up to check battery voltage before unplugging R/R to test. Voltage was 13.6 which I read was good. Only ran bike for a couple mins, then shut off. Unplugged R/R. Plug looked very good but the R/R was so hot I could barely hold it. Is this normal for the R/R to be so hot with the bike only running a couple mins? Link to comment Share on other sites More sharing options...
Neil86 Posted July 30, 2014 Share #24 Posted July 30, 2014 They do run hot. When you did your initial test and seen the low reading on the charging system yesterday was the bike hot? Link to comment Share on other sites More sharing options...
rutman Posted August 11, 2014 Author Share #25 Posted August 11, 2014 THE SAGA CONTINUES. Took my 2 week old gel battery back to Advance. They load tested it and the battery was bad. Got my refund and went to NAPA and bought a NAPA legend premium gel battery. Put it in and rode about 100 miles. Got home and wouldn't crank. @#&%%^&*^%$. Bought a $32 rectifier on ebay and installed this evening. At rest the battery is 13.0 Idling the battery is 13.6 Increasing rpm's and the voltage goes to 14.2 Rode about 30 miles, got home and the readings are about the same. The R/R was a little smaller than stock but bolted right up. You guys think I'm good now or is my excitement premature? Link to comment Share on other sites More sharing options...
