Yammer Dan Posted October 29, 2014 Share #1 Posted October 29, 2014 I have probably a dozen tire air gauges in the garage. Get all kinds of different readings. Is there one that won't break the bank you can trust?? Link to comment Share on other sites More sharing options...
Flyinfool Posted October 29, 2014 Share #2 Posted October 29, 2014 I have the same issue. I just picked one that gave repeatable results and then only use that one. I adjusted my pressures until I was happy with the ride and handling. That is the pressure I use. The tires may not be at the pressure that the gauge indicates, but the pressure that I have works. Link to comment Share on other sites More sharing options...
slowrollwv Posted October 30, 2014 Share #3 Posted October 30, 2014 Dan I use a dial indicator type air gauge. It has w flexible hose and does not loose pressure when checking the tire. I got at Advanced Auto. It is accurate and it is the only one I use. Link to comment Share on other sites More sharing options...
Dano Posted October 30, 2014 Share #4 Posted October 30, 2014 If'n it blows when I fill it up,,,,,,, I know I put too much in there!! Link to comment Share on other sites More sharing options...
