curtisb Posted December 16, 2008 Share #1 Posted December 16, 2008 Could someone point me to a link with good directions to remove rear wheel on a 2007 venture so i can take to dealer and mount my new avon tire. Link to comment Share on other sites More sharing options...
Freebird Posted December 16, 2008 Share #2 Posted December 16, 2008 Here you go: http://www.venturerider.org/forum/showthread.php?t=515 Link to comment Share on other sites More sharing options...
curtisb Posted December 16, 2008 Author Share #3 Posted December 16, 2008 Thanks. Hate to sound stupid but thought i saw something about a snap ring, but dont see anything on my bike or on these directions. Link to comment Share on other sites More sharing options...
Freebird Posted December 16, 2008 Share #4 Posted December 16, 2008 Yes, that is something that you need to do. Has nothing to do with removing the wheel but needs to be done while the wheel is off. Here you go. http://www.venturerider.org/forum/showthread.php?t=13263 Link to comment Share on other sites More sharing options...
Squeeze Posted December 16, 2008 Share #5 Posted December 16, 2008 That Snap Ring is holding the Hub on the Wheel and you should take the Hub off and grease the six Fingers of the Hub before mounting the Wheel. Grease should also be appplied on both Ends of the Drive Shaft and the Splines between Wheel Hub and final Drive. Honda Moly 60 is the recently prefered Grease to use. Link to comment Share on other sites More sharing options...
Squeeze Posted December 16, 2008 Share #6 Posted December 16, 2008 Dang, i'm too slow in typing ... Link to comment Share on other sites More sharing options...
curtisb Posted December 16, 2008 Author Share #7 Posted December 16, 2008 Thanks for the info. Link to comment Share on other sites More sharing options...
seabeetom Posted April 2, 2009 Share #8 Posted April 2, 2009 Got my Venom X's from SWMO. Best price found, free shipping and were on my porch in under 72hrs. Now! I got the front tire off no problem, but I can't get the rear axle out. I've followed the steps on Jeff's post upto the "remove swing arm thingy" there is a discrepancy in the order of steps.. The manual says to pull the axle first.... before removing the rear brake caliper bracket... Anyway, I can't get the axle out----- I took Naturbar's advice about the allen wrench fitting in the end of the axle, that gave me about a 1/4" play but that's as far as she'll go. I did notice while loosening the axle with the allen wrench that the wrench will turn fairly easy for abot 270* then tightens up for the other 90*. I've been turning that axle for Awhile but she no be a budging. I've taken a block of wood and rubber mallet to the threaded side and tried knocking it thru-but no luck. Yep, loosened the pinch bolt and spread it just a hair extra.. Tried it both in the air and with a touch of ground pressure. By the way, couldn't be doing this without Carbon's stand. Also, how far down do I have to disassemble the wheels to get new rubber mounted at a M/C shop?? Or can they do it just like they came off the bike?? Any help will be appreciated. Link to comment Share on other sites More sharing options...
Squeeze Posted April 2, 2009 Share #9 Posted April 2, 2009 You might loosen the four Acorn Nuts (14mm Wrench) on the final Drive and this may release the Axle. Link to comment Share on other sites More sharing options...
seabeetom Posted April 2, 2009 Share #10 Posted April 2, 2009 You might loosen the four Acorn Nuts (14mm Wrench) on the final Drive and this may release the Axle. Tnx 4 the info Squeeze. About 3 hrs of banging and twisting didn't work sooo I broke out the good ol WD40 and gave the axle a bath... Voila! it banged right out. Problem solved. Now if it will just go back together easier than it came apart.. Link to comment Share on other sites More sharing options...
seabeetom Posted April 5, 2009 Share #11 Posted April 5, 2009 Got the new Avon Venoms on... Went back together a whole lot easier than it came apart... And only one leftover part; The pinch bolt for the rear axle... Tried to torque it down to the 31ftlb as stated on the service data sheet and broke it off... Anyone know the specs in that bolt?? Don't need the part #, just size/length/pitch.. Oh! as an addendum to the front tire removal on the tech pages, I had to let the air completely out of the front tire to get it on/off past the caliper brackets... Tnx. Link to comment Share on other sites More sharing options...
Squidley Posted April 5, 2009 Share #12 Posted April 5, 2009 Got the new Avon Venoms on... Went back together a whole lot easier than it came apart... And only one leftover part; The pinch bolt for the rear axle... Tried to torque it down to the 31ftlb as stated on the service data sheet and broke it off... Anyone know the specs in that bolt?? Don't need the part #, just size/length/pitch.. Oh! as an addendum to the front tire removal on the tech pages, I had to let the air completely out of the front tire to get it on/off past the caliper brackets... Tnx. Tom, You can take the pieces of the pinch bolt to any ACE hardware with a bolt bin and match it up there, I'm not sure on the exact dimentions. As as the front tire the front calipers should be taken off, 2 12mm bolts on each caliper and they will swing right out of the way. If you ever run into a problem feel free to give me a call, I can usually walk anyone through the majority of the repairs on the bikes. Link to comment Share on other sites More sharing options...
hkd51 Posted April 6, 2009 Share #13 Posted April 6, 2009 Tom, Not sure where you got the torque specks for the pinch bolt ... the specks I have are 17ft. lbs. acorn nuts are 30ft.lbs and the axle nut is 110ft lbs. Anyone else confirm these specks? Harry Link to comment Share on other sites More sharing options...
Bummer Posted April 6, 2009 Share #14 Posted April 6, 2009 Tom, Not sure where you got the torque specks for the pinch bolt ... the specks I have are 17ft. lbs. acorn nuts are 30ft.lbs and the axle nut is 110ft lbs. Anyone else confirm these specks? HarryYep. Technically the pinch bolt is listed at 16.6, but my torque wrench doesn't adjust quite that fine. 17 should do nicely. The service manual is available in the tech section. Note that the pinch bolt torque spec is listed in the reassembly text, not on the picture with the rest of the torque/lube info. Link to comment Share on other sites More sharing options...
