User's Login
Main Menu
Mini Stats
11,008 |
0 |
| Members |
Entries |
45,545 |
0 |
| Threads |
Reviews |
537,180 |
30 |
| Posts |
Polls |
0 |
0 |
| Content |
Files |
62 |
0 |
| Links |
Ads |
04-15-2012, 05:26 PM
1987 Yamaha Venture Royal
Supporting Member
Arrrrrrrrrrrrrrrrrrrrrrrrg Again
So with the new HO Stator, starter clutch, and programmable TCI installed I can't get the bike cranked. After 3 cans of starter fluid the bike will fire only as long as the starter fluid is present but then chokes out.
The fuel pumps seems to click for long time every time I turn the key on. And the battery drains down to nothing quickly and I've had it on the charger all day. When the charger indicates charged it has 13.5 volts but doesn't last long. The bikes been sitting for about a year.
I'm thinking I'll probably have to pull the carbs and go through them again. But, I thought I'd get some more opinions before I did that.
__________________
Bob the DragonSlayer
NUIS HOMO EST INSULA (NO MAN IS AN ISLAND)
NON ILLEGITIMI CARBORUNDUM (DON'T LET THE BASTARDS GRIND YOU DOWN)
CARPE DIEM (SIEZE THE DAY)
04-15-2012, 05:34 PM
White 86 / red 2000
Supporting Member
if the fuel pump is running a long time . you got a big leak or no gas getting to fuel pump . i think the latter . open the drain on 1 of the carbs , turn on key see if gas comes out.
04-15-2012, 05:36 PM
83 1st Gen, 03 RSV Hybrid
Supporting Member
Do you have a working stock TCI you can check bike with?
I did check yours and all the 83-89's on my bike before sending them out, but would like to eliminate Ignitech as culprit.
I am having an issue with at least one of the Ignitech's on a 90-93 single pick up coil bike that won't fire. I had no way of testing the single pick up coil units. That one does run with the stock TCI.
But if it is firing with starting fluid, I would doubt it is the TCI.
Gary
__________________
Venture Maximized
VMax
04-15-2012, 05:49 PM
2009 Royal Star TD
Make sure the fuel petcock is in the "on" or "reserve" position!  If that doesn't work check to make sure there is fuel in the fuel tank.
04-15-2012, 06:04 PM
Supporting Member
Quote:
Thats why I love you guys and this site. It never hurts to get a second opinion. I knew it was full of fresh gas, I just forgot to turn the petcock on. Started right up.
I feel like such a rookie dumb A**.
Thanks for the help.
Dingy the TCI is apparently good to go.
__________________
04-15-2012, 06:06 PM
White 86 / red 2000
Supporting Member
04-15-2012, 06:17 PM
07 RSMV
Supporting Member
  Sounds like a good time for a donation
04-15-2012, 06:49 PM
2009 Royal Star TD
I was only joking.
I was only posting as a joke. I do have to admit though that I did take my lawnmower out of the shed and after being completely pooped out from pulling on the cord I looked down to find out that the fuel petcock was in the "off" position. Turned it to the "on" position and fired up on the second pull.
04-15-2012, 06:54 PM
Supporting Member
So you know how I feel.
__________________
04-15-2012, 07:09 PM
83,83,83,84,85,86
Supporting Member
I got here in time to laugh Bob!! I'm not going to say anything about the chain saw I took apart to find out what was wrong with it. cleaned everything set mag put in new plug checked tank. Dry as a bone!!!
__________________
1st GENS RULE
Faded Blue is the fastest.
"Blue Beast" will live forever
04-15-2012, 07:24 PM
Supporting Member
Quote:
I love that line in the Billy Bob Thorton movie "Sling Blade" when his more mentally astute friends are trying to figure out what's wrong with the rotary tiller.
His retarded but correct answer.
"It aint got no gas"
__________________
04-15-2012, 08:26 PM
88 Venture standard
Supporting Member
I've never done that.
04-15-2012, 09:10 PM
'07 FJR
Supporting Member
There's a valve to turn the gas off??? How quaint!
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
