Riderduke Posted November 28, 2014 Share #1 Posted November 28, 2014 Does anyone know if the rear shock on the 04 Venture and a 06 Tour Deluxe interchangeable? I need a new rear shock and I can get a free TD rear shock....I went to a couple of sites and the part numbers are different so I'm thinking NO..... What do you think? Link to comment Share on other sites More sharing options...
M61A1MECH Posted November 28, 2014 Share #2 Posted November 28, 2014 Agreed the numbers are different, the 3 code identifier, first 3 numbers is for the bike model they are different, but the main body of the number 22210 is the same, the remaining 4 digits I believe refer to revision numbers, the 06 version of the Venture shock is an 01, because it is revised from the original design from 1999. All of that said, the TD and the Venture are essentially identical when it comes to the frame and the power plant / transmission, so I would say yes they are interchangeable, the pictures look the same in the ilustrated parts break down. If the one if free what do you have to lose, if you get the one out and it does not match the free one, give it back and buy one that fits. Link to comment Share on other sites More sharing options...
Riderduke Posted November 29, 2014 Author Share #3 Posted November 29, 2014 Agreed the numbers are different, the 3 code identifier, first 3 numbers is for the bike model they are different, but the main body of the number 22210 is the same, the remaining 4 digits I believe refer to revision numbers, the 06 version of the Venture shock is an 01, because it is revised from the original design from 1999. All of that said, the TD and the Venture are essentially identical when it comes to the frame and the power plant / transmission, so I would say yes they are interchangeable, the pictures look the same in the ilustrated parts break down. If the one if free what do you have to lose, if you get the one out and it does not match the free one, give it back and buy one that fits. Thanks for the reply..... I'll try it Link to comment Share on other sites More sharing options...
djh3 Posted November 30, 2014 Share #4 Posted November 30, 2014 Thats exactly what its worth. lol But sure is nice to have the air adjust at times. If Im paying for one Im going Hagon. Link to comment Share on other sites More sharing options...
Riderduke Posted November 30, 2014 Author Share #5 Posted November 30, 2014 But sure is nice to have the air adjust at times. That is why i'm not going with the Hagon.......... paying or not......lol Link to comment Share on other sites More sharing options...
