RSV Muffler sound
Ok here it is. You reach in the back of the muffler with a dremmel cutter and cut the pipe. Then just push the pipe out of the way. There are a couple of threads on this.
http://www.venturerider.org/forum/showthread.php?t=41418&highlight=muffler
Sounds pretty good too.
Mike
Looks like this when done.
[ATTACH]87608[/ATTACH]
Edited by MikeWa
Thanks for the info! Much appreciated! :301:
Looking at the above pic and the cut away on the thread, couldn't you just drill some holes through the end caps and accomplish the same thing? Anyone try that?
The design of the muffler is such that you have two end caps. An inner and outer. And yes you could just drill holes. But I wouldn't.
Mike
I would say the majority just find a pair of HD touring mufflers. Anything off a street glide, ultra glide. Ultra classic etc. Most times you can find them for around 20-30 bucks. Sometimes you can get a pair cheap from your local HD dealer as them guys swap them out before the title work is done. Gives it a more throaty sound with out defaning your hearing.
