User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 14 of 14
Thread: Arrrrrrrrrrrrrrrrrrrrrrrrg Again
  1. #1
    Join Date
    Apr 2007
    McDonough
    GA
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Default Arrrrrrrrrrrrrrrrrrrrrrrrg Again
    So with the new HO Stator, starter clutch, and programmable TCI installed I can't get the bike cranked. After 3 cans of starter fluid the bike will fire only as long as the starter fluid is present but then chokes out.
    The fuel pumps seems to click for long time every time I turn the key on. And the battery drains down to nothing quickly and I've had it on the charger all day. When the charger indicates charged it has 13.5 volts but doesn't last long. The bikes been sitting for about a year.
    I'm thinking I'll probably have to pull the carbs and go through them again. But, I thought I'd get some more opinions before I did that.
    Bob the DragonSlayer
    NUIS HOMO EST INSULA
    (NO MAN IS AN ISLAND)
    NON ILLEGITIMI CARBORUNDUM (DON'T LET THE BASTARDS GRIND YOU DOWN)
    CARPE DIEM
    (SIEZE THE DAY)
  2. #2
    Join Date
    Mar 2007
    Port Aransas
    TX
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    if the fuel pump is running a long time . you got a big leak or no gas getting to fuel pump . i think the latter . open the drain on 1 of the carbs , turn on key see if gas comes out.
  3. #3
    Join Date
    Sep 2008
    Mansfield, Ohio
    OH
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Default
    Do you have a working stock TCI you can check bike with?
    I did check yours and all the 83-89's on my bike before sending them out, but would like to eliminate Ignitech as culprit.
    I am having an issue with at least one of the Ignitech's on a 90-93 single pick up coil bike that won't fire. I had no way of testing the single pick up coil units. That one does run with the stock TCI.
    But if it is firing with starting fluid, I would doubt it is the TCI.
    Gary
  4. #4
    Join Date
    Nov 2011
    Portland
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Make sure the fuel petcock is in the "on" or "reserve" position! If that doesn't work check to make sure there is fuel in the fuel tank.
  5. #5
    Join Date
    Apr 2007
    McDonough
    GA
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by 09RSTD View Post
    Thats why I love you guys and this site. It never hurts to get a second opinion. I knew it was full of fresh gas, I just forgot to turn the petcock on. Started right up.
    I feel like such a rookie dumb A**.
    Thanks for the help.
    Dingy the TCI is apparently good to go.
    CARPE DIEM
    (SIEZE THE DAY)
  6. #6
    Join Date
    Mar 2007
    Port Aransas
    TX
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
  7. #7
    Join Date
    Sep 2011
    foreman
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Sounds like a good time for a donation
  8. #8
    Join Date
    Nov 2011
    Portland
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I was only joking.
    I was only posting as a joke. I do have to admit though that I did take my lawnmower out of the shed and after being completely pooped out from pulling on the cord I looked down to find out that the fuel petcock was in the "off" position. Turned it to the "on" position and fired up on the second pull.
  9. #9
    Join Date
    Apr 2007
    McDonough
    GA
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Default
    So you know how I feel.
    CARPE DIEM
    (SIEZE THE DAY)
  10. #10
    Join Date
    Aug 2006
    Ivydale
    WV
    Post Thanks / Like
    Mentioned
    40 Post(s)
    Tagged
    0 Thread(s)
    Default
    I got here in time to laugh Bob!! I'm not going to say anything about the chain saw I took apart to find out what was wrong with it. cleaned everything set mag put in new plug checked tank. Dry as a bone!!!
    1st GENS RULE
    Faded Blue is the fastest.
    "Blue Beast" will live forever
  11. #11
    Join Date
    Apr 2007
    McDonough
    GA
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Yammer Dan View Post
    I love that line in the Billy Bob Thorton movie "Sling Blade" when his more mentally astute friends are trying to figure out what's wrong with the rotary tiller.
    His retarded but correct answer.
    "It aint got no gas"
    CARPE DIEM
    (SIEZE THE DAY)
  12. #12
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    209 Post(s)
    Tagged
    0 Thread(s)
    Default
    I've never done that.
    Jeff Borowski . . 88 Venture standard
    There are 10 kinds of people that understand binary, those that do, and those that don't.
    Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
  13. #13
    Join Date
    May 2008
    Houston
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    There's a valve to turn the gas off??? How quaint!
  14. #14
    Join Date
    Aug 2006
    Hebron
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I ain't never done nuthing like tat.
    BOO
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
