User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 5 of 5
Thread: 83 front brake switch
  1. #1
    Dave Rogge Guest
    Default 83 front brake switch
    Hi everyone
    New guy here. I have an '83 Venture Royale with factory cruise control. I need a new front brake light switch. The one I received from Yamaha has only two wires, while the existing one on the bike has 4 wires, and runs through a small block (resistor or capacitor?) before plugging into a four gang block in the headlight shell. The Yamaha dealer I spoke with couldn't find any reference to the different switch, or a part number for it. Anyone had this same problem??
  2. #2
    Join Date
    Aug 2006
    Arcade, NY
    NY
    Post Thanks / Like
    Mentioned
    51 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yes, there are different switches depending on whether you have cruise or not. The second set of contacts on the 4 wire switch is to tell the cruise control controller that the brakes have been applied and to turn off the cruise control. Only the Royale model had the cruise, and the '83 I think was an option. You can try '84 on up for the proper switch. I had an extra but gave it away a couple of months ago...
  3. #3
    Join Date
    Sep 2008
    Mansfield, Ohio
    OH
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Dave Rogge View Post
    Hi everyone
    The way you have described the switch, it sounds like an 88-89 one. They put a capacitor/choke in the ones for those 2 years in an attempt to reduce radio noise.
    The rear brake also has a capacitor/choke, but the clutch does not.
    Cut of schematic attached.
    Gary
  4. #4
    Join Date
    Nov 2011
    Tucson
    AZ
    Post Thanks / Like
    Mentioned
    26 Post(s)
    Tagged
    0 Thread(s)
    Default
    I should have 2 83 parts bikes in a couple of days once I get back from travel. If I have what you need I'll get it to you if you haven't already found one.
    Let me know.
    Bill
    I know the voices aren't real... But they do have some really great ideas !
    The problem isn't the problem. The problem is your attitude about the problem. Capt Jack Sparrow
  5. #5
    Dave Rogge Guest
    Default
    Quote Originally Posted by bongobobny View Post
    Thanks for your help! It appears that my switch is from an '89 model like you said.
    Dave Rogge
Similar Threads
  1. Front brake light switch
    By coltrain in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 09-09-2012, 07:44 AM
  2. Front brake lever switch
    By tufftom4 in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 08-11-2012, 01:24 AM
  3. Front brake switch
    By ricky lopckhart in forum General Tech Talk
    Last Post: 12-30-2011, 02:36 PM
  4. Front Brake Light Switch help ....
    By sgn in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 06-29-2011, 03:11 PM
  5. Front brake switch
    By RoyalStarRider in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 09-18-2010, 09:25 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
