User Tag List
Thanks Thanks:  0
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Kumhos are back
  1. #1
    Join Date
    Oct 2006
    Lewes
    DE
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Kumhos are back
    I found a Kumho while visiting my Bro in Kissimmee, FL... I had to pay $82 for it but this will be my 3rd Kumho and should be good for 20,000 miles...
    http://www.discounttire.com/dtcs/tir...Selected=34747
  2. #2
    Join Date
    Jun 2010
    West Bloomfield
    MI
    Post Thanks / Like
    Mentioned
    33 Post(s)
    Tagged
    0 Thread(s)
    Default
    165/80- 16 ? How tough to mount? does it need to be over inflated ? Will the rear still lockup like with a bike tire when you give too much pedal?
    Jay
    Patriot Guard Rider #18267
    '01 RSV......08 Hannigan RSV, 69' Buick GS 400 Conv.
    " Never ride faster than your angel can fly"
  3. #3
    Join Date
    Oct 2006
    Lewes
    DE
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    My RSV uses a 165/80-15...
  4. #4
    Join Date
    Jun 2010
    West Bloomfield
    MI
    Post Thanks / Like
    Mentioned
    33 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by MAINEAC View Post
    Yeah, I knew that... I got wandering fingers
    Jay
  5. #5
    Join Date
    Jul 2008
    Brandon, MS
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by ragtop69gs View Post
    Unless you really prep the wheel it does take a lot of pressure to seat the beads.
    The rear brake will still lock-up but it takes a little more effort. The only time I locked mine was on purpose to see how much effort it took and it didn't just slide like the m/c tire. It was squealing and vibrating from gripping the asphalt so hard.
  6. #6
    Join Date
    Jun 2010
    West Bloomfield
    MI
    Post Thanks / Like
    Mentioned
    33 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by BigBoyinMS View Post
    Could you detail the wheel prep procedure, please.
    Jay
  7. #7
    Join Date
    Mar 2012
    Dallas
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Found a great source for kumho powerstar 758 165/80-15. Found a bunch in the Dallas area at Discount Tires. Still had a bunch in stock when I bought one on 4/14. May be another just so I have one next time.
  8. #8
    Join Date
    Jun 2012
    Washington
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Speed rating on that tire
    My concern for this Kumho 758 tire...165/80-15 is that it has a speed rating that is only a T...which means it is rated for 118 mph. Most bikes run tires that have an H or V rated tires.
    While we do not usually ride at a consistant 118 mph, there are times...
    I would hate to overheat the tire at speed, and have it blow out.
  9. #9
    Join Date
    Aug 2011
    Raleigh
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I put a Kumho on recently(Discount Tire, $82) and it took about 95lb to seat. Thats with lots of goo(I use KY). The solution I use to make it safer is to add a 25' air hose extension with a clip on inflator. That way you can be on the other side of a wall adding air and waiting for the 2 "pops". Start with a nice clean rim, and lube the crap out of it.
    The rear will still lock-up, just takes a bit more pedal to do it.
  10. #10
    Join Date
    Aug 2010
    Brooksville
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default
    if you run the pressure up to around 50-55 pounds and let it set about 10 minutes then let the air back out and run it up again it will "pop" at around 70-75 pounds.
    Love Ya Rick & Shirley
  11. #11
    Join Date
    Aug 2011
    Raleigh
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Rick Haywood View Post
    Mine sat overnight at around 75lb. let it all out and tried again in the am. no joy. I let it down again, re-lubed it, and decided to go until it "popped"; one way or t'other. Second bead seated at appx. 95lb.
    YMMV - sp!ke
  12. #12
    Join Date
    Dec 2011
    Hardy
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I had to search hard to find the Kumho 165/80/15 but I did fine some.... King Tire in Roanoke, Va $55 out the door!!!!!! Said he has stock of 5 more if anyone needs one....Don't know if they ship or not but if anyone needs one and they don't ship, I could facilitate shipping, just msg me.
    Be mounting it tomorrow hopefully, let ya's know the proceedure and how it works out....Oh, this will be my darkside plunge....so I'll be looking for dem cookies cuz i'm crossing over to feel the POWWA of the Darkside!!!!!!
    Thanks to all for the vast amount of information on sizing and mounting and experience.
  13. #13
    Join Date
    Aug 2011
    Raleigh
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thats a good price. Discount Tire carries this tire but they get $82 + tax. Cost me $89 for mine.
    BTW: Mine took ~95lbs to seat. A bit scary if i do say. To make it less scary I added a clip on inflator head & 25 ft of hose and stood inside the garage while the tire was outside the garage. Then I just hit the button and waited to hear 2 "pops". Lots of "goo". I used KY.
    When you go for your first ride it's gonna feel a bit "strange". Loosey Goosey if you will. Give it a couple hundred miles and you won't even notice it anymore.
    sp!ke
    Quote Originally Posted by Blinker View Post
  14. #14
    Join Date
    Nov 2007
    TX, NM, OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default not overloaded
    Quote Originally Posted by Million Mile Rider View Post
    That speed rating assumes the tire is at its maximum weight load and maximum PSI.
    Since darkside use will mean its carrying less than 1/3 or 1/4 of its rated weight, its most likely not gonna turn to rubber shrapnel at 118.1 mph.
    But no gar-un-tees!
  15. #15
    Join Date
    Dec 2011
    Hardy
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Silly Darksiders....you can't do that..... HA! Really liking the CT. Took 95lbs to seat but all is good.....running 38psi to start, may adjust after a 100 or so miles. Really doesn't feel much different... just got to tell my brain to ride like i've always did....guess I'm "supersearching" for any little difference between MT and CT....and I might be a little too careful.....
    Just going to make sure the pressure is rite and ride it....I must say it's a more plush ride, i may have to bump up the rear shock a little but all in all, 60 miles into it so far, I'm pretty much decided I ain't goin back to MT......
    Yeah, I guess they were right, you can't put a car tire on a bike.....ha!
    Come to think of it, that factory goo stuff is probably melted off by now....Got it changed out Saturday, it was 101 degrees in Virginia, on the way home, bank temp sign said 102...
Similar Threads
  1. Im back
    By emt doug in forum Watering Hole
    Last Post: 07-08-2011, 10:39 PM
  2. The way it was back then
    By Steel Horse Cowboy in forum Jokes and Humor
    Last Post: 06-26-2011, 08:02 AM
  3. ok back together now?
    By oldgoat in forum Watering Hole
    Last Post: 06-02-2011, 11:27 PM
  4. The Owl is back
    By Black Owl in forum Watering Hole
    Last Post: 04-06-2009, 10:18 PM
  5. Never Going Back
    By yamahamer in forum Watering Hole
    Last Post: 11-15-2007, 01:14 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
