User Tag List
Thanks Thanks:  0
Likes Likes:  0
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Coolant leak
  1. #16
    Join Date
    May 2008
    Albuquerque
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Look at the crankcase segment in the fiche. There are four plugs, one for each cylinder, all identical, cost $4 each from Yamaha Sports Plaza:
    http://www.yamahasportsplaza.com/pag...VZ13TFW_-_2007)
    part is 90338-11152-00
    These plugs usually start weeping after a couple of years. I've made it a point to get new ones whenever I change out the coolant. However, I've never seen one do more than weep a few drops at a time, so it is something that can be lived with eternally, if necessary.
  2. #17
    Join Date
    Mar 2008
    Layton
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile
    Thanks for saving me a bunch of time!
  3. #18
    Join Date
    Oct 2008
    Fayetteville
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have this same leak at the bottom bolt of the fake fins and will try to get a replacement plug tomorrow. How does the old plug come out - just pull it out? Also, will coolant come flowing out while I'm trying to get the new plug in? Any helpful hints?
  4. #19
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default
    Go to this article in the tech section,
    http://www.venturerider.org/forum/sh...ad.php?t=37353
    You can thread an old spark plug into the threaded insert and pull the plugs out, yes coolant will come in rapid fashion when you pull the plugs.
    Steve K
    Edgewater , FL
    And the LORD said "Thou shalt have dominion over all of the animals, Except of course the cat."
    DR. Goldwing; has the antidote for the blues
  5. #20
    Join Date
    Oct 2008
    Fayetteville
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks for pointing me in the right direction.
Similar Threads
  1. A different coolant leak
    By ragtop69gs in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 11-12-2010, 09:43 PM
  2. Coolant leak
    By Art708 in forum Watering Hole
    Last Post: 09-16-2009, 01:09 PM
  3. Coolant leak
    By nascarnutt in forum Watering Hole
    Last Post: 02-19-2009, 11:09 PM
  4. Coolant Leak
    By halfwitt in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 06-03-2008, 01:58 AM
  5. coolant Leak
    By hdroyer in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 09-28-2007, 11:43 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
