BigRen Posted September 22, 2010 Share #1 Posted September 22, 2010 I hope I am doing this correct. I have recently purchased a 1990 Yamaha Venture Royal, 1300 cc. I would like to replace the spark plugs but can't seem to get to them all. Can anyone help me? Do I have to remove the battery, and air filter? Thank you... Hope i am not stepping out of bounds by reposting this for Slim. Link to comment Share on other sites More sharing options...
Snaggletooth Posted September 22, 2010 Share #2 Posted September 22, 2010 Remove side panels, lower forward fairing and radiator side panels. Use correct spark plug socket with a swivel, then about a 4 inch extention to the ratchet. That's the trick for me. Socket, swivel, extention. Works fine. Link to comment Share on other sites More sharing options...
Venturous Randy Posted September 22, 2010 Share #3 Posted September 22, 2010 Before you remove the plug, take an air hose and blow the area out as good as you can. That may help keep some debris out of the cylinder. Also, make sure you use a little "anti-seize" on the threads before you put them back in. RandyA Link to comment Share on other sites More sharing options...
Dano Posted September 22, 2010 Share #4 Posted September 22, 2010 These bikes take a "slim" 18mm socket to get down in the well, I found that the Kobalt (Lowes) socket works perfectly for this situation. Link to comment Share on other sites More sharing options...
Condor Posted September 22, 2010 Share #5 Posted September 22, 2010 You have to remove the side covers and the front lowers. If you have the OEM tool kit it comes with a double ended spark plug remover, and 2 or 3 large mm box end flat wrenches and handle. Slide the remover in over the plug and take the flat box that fits the remover and break the plug loose. Then take a length of 1/4" fuel line and slide it over the porcilan of the plug and unscrew it. The fuel line really makes it easy. One of the ends of the remover has a rubber piece up inside to hold the new plug. Put the new plug in that end and by hand slip the plug into the hole and wiggle it while starting the threads. This keeps you from cross-threading anything. Once the threads are started pull the remover off and grab the hose again. Thread the plug in the rest of the way with the hose. Put the remover back on and snug the plug down with the flat box. It sounds like it's complicated, but should only take about 5 minutes per plug. Some folks have said they use a thin wall socket... 18mm I think... but I'll be damned if I can find one. I'm sure they're out there but I have better things to do than chase down a thin wall plug. I put them in the same catagory as the 2nd Gear punch mark.... 1 Link to comment Share on other sites More sharing options...
elmicko Posted September 22, 2010 Share #6 Posted September 22, 2010 I had a heck of a time changing the plugs in mine until I tried the spark plug tool in the bike's tool kit. Worked perfectly. Link to comment Share on other sites More sharing options...
keyscruising Posted September 23, 2010 Share #7 Posted September 23, 2010 I just did this two days ago on my 84. It is a bit of a pain but if you follow the wise ideas already losted it will make the job a lot easier. I am now in search of a monkey that I can train for the next time something like this has to happen. I have discovered that whatever I need to get to on this bike it is always at the bottom of the bike and somewhere near the center. Big fat hands with stubby fingers so not work well in this type of situation. Now.... small , slender monkey hands would work fine and because he would be short he would not be spending hours bent over in some ungodly position. He could just stand there and work. Link to comment Share on other sites More sharing options...
mbrood Posted September 23, 2010 Share #8 Posted September 23, 2010 I must be doing something wrong, I use a 3/8 Powerbuilt cr-v 18 plug socket with a short swivel adapter and a ratchet, break it with the ratchet and then use the socket and swivel to remove... but I only remove the side covers to get to the rear plugs and use the hole between the radiator and the lower "leg" of the lowers for the front plugs. Link to comment Share on other sites More sharing options...
CrazyHorse Posted September 24, 2010 Share #9 Posted September 24, 2010 Changing plugs on these is a pain in the butt. Link to comment Share on other sites More sharing options...
Condor Posted September 24, 2010 Share #10 Posted September 24, 2010 Changing plugs on these is a pain in the butt. Nah... Have Boomer send you one of his pixies..... Link to comment Share on other sites More sharing options...
jasonm. Posted September 25, 2010 Share #11 Posted September 25, 2010 A pain the change? These are easier the a newer sport bike...I can change all 4 plugs on my bike in 30-40 min. with a beer in one hand. Using a proper socket & 3" ext. on the rachet. But, If you have large hands or fat fingers...then it's a bit more aggonizing. I have skinney fingers, so the threading in the spark plugs is not an issue for me. Link to comment Share on other sites More sharing options...
